vacuum line? Please help!
Old 10-05-2016, 10:45 PM
Brummy's Avatar
Brummy
Brummy is offline
6th Gear
Default vacuum line? Please help!
Hey all, while cleaning I found a, i guess, vacuum line just sitting behind my air filter. It is coming form the rear next to 3 other lines (the bottom one). She seems to be running fine, though my experience is very minimal!
Any idea??
Old 10-08-2016, 09:35 AM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
Looks like the carb bowl drain line to me
Old 10-08-2016, 10:33 AM
Brummy's Avatar
Brummy
Brummy is offline
6th Gear
I believe it's from the charcoal canister ( im in CA...) but my filter housing does not have the hole in the back for it to mount to.
Old 10-08-2016, 10:53 AM
Ed Ramberger
Then what exactly is the point of the OP?
Old 10-08-2016, 11:31 AM
Brummy's Avatar
Brummy
Brummy is offline
6th Gear
Well? Let's see? Probably to find out if this is required to be connected or something. If you can't help then troll elsewhere sir. I'm here because I'm new to Harley and to motorcycles. I was unsure if this being disconnected would cause an issue with the bike.
Old 10-08-2016, 11:42 AM
nevil's Avatar
nevil
nevil is offline
Let's try to narrow it down. Tell us what year and model you have. Also any mods you're aware of.
You might be able to look it up on the parts microfiche diagram:
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old 10-08-2016, 11:51 AM
Brummy's Avatar
Brummy
Brummy is offline
6th Gear
It's a 06 Sportster xl1200c. The only upgrade that I can tell is the screaming eagle slip on's.. The air filter assembly looks newer but I cannot tell. I cannot feel a hole in the back of the filter assembly for the line to go into. I did trace the line back and is the clean air out of the charcoal canister. I am just concerned that it might cause an air/fuel issue if this was not connected. Do these "need" to be connected or is it just a ca emissions thing?
Old 10-08-2016, 06:46 PM
Gozzie's Avatar
Gozzie
Gozzie is offline
What's the other end of the line go to ? Does it just vent to the atmosphere ?
Old 10-09-2016, 10:52 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Most likely to be an engine breather IMHO, which suggests the air filter has been changed at some time and that pipe left dangling. It may be possible to identify it on-line here.
Old 10-10-2016, 04:13 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,742 Likes on 928 Posts
That would be my guess also. I bet a new air cleaner has been installed. YD
Quick Reply: vacuum line? Please help!
