Sissy Bar INSTALL - HELP
Hello everyone,
Excuse me if I'm posting in the wrong section, just new to the forum and I am a bit confused. So, I've purchased One piece Detachables Sissy bar upright Part Number 51146-10A. I am still waiting on the Sissy bar itself but I bought the docking hardware and I installed it today. I have 2016 Sportster Iron 883. I didnt have anything to lift it with, which I've read would make the install a lot easier. But, being me, really inpatient I decided to still go ahead and do it. As expected, it was really tight back there and I was not able to fit most of my tools. Anyway, I managed to do it (see pictures below). I played around a little bit, but eventually took the stock bolts and installed the docking hardware. So, my question is do you guys think I installed it legit? I mean, is it tight enough? I was not able to tight the lock nut, I was only able to hold it while I was tightening the screw from the outside. I tight it to a point where I was not able to go any more, but I am still not sure if it is done right. Attached are the pictures so you can get an idea how I installed it. I basically managed to put the little piece inside, hold it with the pliers and unscrew the screw from the outside. Any help would be greatly appreciated, I dont want my girl to fly of the back one day because the thing is not tight enough. Thanks!
