How much oil in engine??
Received 3,988 Likes
Got a question about how much oil to run in the engine crankcase. 2014 SGS with 120R engine.
At my motor's 5000 mile service the dealership tech asked me how much oil I wanted put in the engine. He explained that the MoCo several years ago started advising to run 1/2 quart less oil in the engine to fix a problem (I don't remember what he said the problem was...).
He said he would fill the crankcase with how ever much oil I want. Either to factory-recommended level or the older 1/2 quart more.
I told him to put in the extra 1/2 quart. It's now at above full level.
My engine has the SE +1.5 quart oil pan. Don't think that makes any difference but anyway...
Any advice on the topic is appreciated.
I don't have the specifics on the SGS with the +1.5 quart pan but I know on my 103" I don't worry about the hot check; only the cold oil level check. I want it no more than 3.5 hash marks on the stick; exactly half way on the stick. When I do an engine oil change that's just under 2 quarts for my bike.
Run the oil too high and you can start to have carryover problems. Check your stick when the bike is cold; half way on the stick, no more. That's the correct level, 88, 103, or a 120 engine...
Edit: do they have a different oil stick for the +1.5 quart pan? I have no clue on that. hummm...
Sierra977 (01-15-2017)
On a oil and filter change. Hit it with a three quarts. Start it up and when the oil light goes off, turn it off and let it set a few. Guess your's say, check on stand. Now top it to middle of stick. Next time, it's blistering hot. Top it off to top of stick mark. It will be fine till next oil change.
Don't know the answer about oil dipstick being different for the +1.5 quart oil pan. It was there when I had the motor built new at the dealer. The oil stick is the one with oil temperature indicator. Now it reads "Oil Level High" and that has my attention.
Breather lines are re-routed to a drip can.
I may drain off the extra oil and take it down as you recommend.
My thinking was the extra 1/2 quart would improve cooling but after more thought I'm not so sure.
There is no difference IMHO in servicing your 120R from what the owners manual says for your stock bike. Having owned bikes for half a century I always fill to the half mark, then run the engine for a while and top up if required - then take a decent run out (helps if it's a nice day!) and finally check and top up when back home.
Ignore the quantity thing, fill to the dipstick - don't just pour in umpteen bottles of oil. Any quantities given in the manuals are simply a guide, in other words have at least that much to hand when refilling. All three holes have clear and unambiguous guidelines in the books on the correct level for us to fill up to. That way if you have a bigger oil tank the quantity required will obviously be more, but the level on the dip-stick is unchanged. Simples!
Pulled half-quart of oil out of the oil bag this morning with evacuation pump. Plan to ride one day this week, get engine up to temp and check oil level.
Sierra977 (01-17-2017)
