What connector part # is this ?????
Old 01-28-2017, 08:26 AM
flanigans45's Avatar
flanigans45
flanigans45 is offline
It looks like A triple clamp ground Part# 72364-06 . Wire size 10-14 gauge / cost .88 cents.
Old 02-08-2017, 11:20 AM
linelock's Avatar
linelock
linelock is offline
1st Gear
Spot on with that p/n that is excellent. I broke two out of four trying to disassemble the turn signals. You dont happen to know the p/n for the light socket crimp terminals on the violet and blue wires also do you?
Old 02-08-2017, 06:33 PM
flanigans45
Taillight at the 4 pin connector that has 3 wires in it. If so it part # 73191-96.
Old 02-08-2017, 06:44 PM
flanigans45
If not post A picture. And I'll try to find it.
Old 02-08-2017, 08:37 PM
linelock's Avatar
linelock
linelock is offline
1st Gear
Looking for the connector on the black wire that sockets up into the reflector, and also for the connectors on the blue and violet wires that contact the bulb.
Dealership tried really hard but they couldnt drill down into the diagram far enough to come up with a number.
Attached Thumbnails What connector part # is this ?????-img_20170208_192010951.jpg
Old 02-08-2017, 09:57 PM
flanigans45
Did you brake the piece that the wires went into. If so that is part #68497-07 Socket assy. with mount. HD don't sell the button contact. You might haft to go to parts store get a taillight socket with the same button in it / cut and solder it in.
Old 02-16-2017, 11:15 AM
linelock's Avatar
linelock
linelock is offline
1st Gear
Does the socket assembly kit that you referenced have the wires in it?
I mean...somebody manufactures these crimp connectors. I have a molex crimper...Just need the terminals
Old 02-16-2017, 05:08 PM
fatboy9nc's Avatar
fatboy9nc
fatboy9nc is offline
i was able to put it back together after powdercoating.
thanks everyone for all the help. appreciate it.
Old 02-19-2017, 07:15 PM
linelock's Avatar
linelock
linelock is offline
1st Gear
I'm still working on this, but not getting anywhere.
For the late model dyna, 68904-00 (front) and 68905-00 (rear) are the socket assemblies that have the wiring pigtail already in them. HD definitely does not sell the crimp connectors individually, and I'm not sure that a p/n exists for them.
That being said, I reiterate that these terminals are manufactured, somewhere. Because I broke a couple, it would be much easier to just re-strip the wire and crimp a new terminal on than to run a whole new socket assembly and route all the pigtail through the handlebars and all that. But it depends on being able to identify by correct name, and purchase these connectors.
jdobson
Shovelhead
01-02-2019 10:36 PM
esteboatan
04-26-2017 12:11 PM
PaPaBlista
Ironhead
03-07-2016 09:34 PM
galaxyfe
07-06-2015 09:08 PM
99HarleyFXR
06-14-2012 06:27 PM
Quick Reply: What connector part # is this ?????
