Adding only a Screaming Eagle Heavy Breather to a stock 96ci Street Glide
Old 03-12-2017, 12:15 PM
LT Shipwreck's Avatar
LT Shipwreck
LT Shipwreck is offline
Stage I
Default Adding only a Screaming Eagle Heavy Breather to a stock 96ci Street Glide
Folks,
New dude here... I know there are a million discussions about adding a heavy breather. I am going to do a Stage 1 in full here soon when I do my 10k service. That said, I have a great deal on a brand new Screaming Eagle Heavy Breather intake. If I bolt this thing on now, with no pipes (stock exhaust) and no tuner, am I going to jack anything up? Will there be any improvement/issues. I'm not looking to do it for looks, looking for performance. That said, I acknowledge this is only part of a stage one and the full stage 1 is opttimal, the rest will come later (pipes and tune). Thoughts? Thanks for your help.
Old 03-12-2017, 12:23 PM
bad tappets's Avatar
bad tappets
bad tappets is offline
The instructions that came with my SE heavy breather ('06) states it needs a tuner. Factory motors run lean, a freeer flowing AC isn't going to help that. If your looking for performance, wait and do a full stage 1 at the same time.
My 2 cents, YMMV
Old 03-12-2017, 01:45 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is online now
Received 1,811 Likes on 1,064 Posts
You can install it now if you wish. It's not gonna jack anything up as long as you're running the OEM exhaust.
Old 03-12-2017, 01:50 PM
perki48's Avatar
perki48
perki48 is offline
Received 4,099 Likes on 1,913 Posts
I've been doing it for the last 10 years, but did put on a Dobeck TFI to stop the lean surge. The surge was there even before the A/C change.
Old 03-25-2017, 11:49 AM
big- mike's Avatar
big- mike
big- mike is offline
I would wait and do it lol at once. Or if you want to do the a/c now do a programmer at the same time and use one that you can update the map as you go. I know the FP3 will let you do that and I think the power vision will also. Even a stock bike can benefit from a programmer because they are so lean from the factory
Old 03-26-2017, 01:43 AM
13RoadKing's Avatar
13RoadKing
13RoadKing is offline
If your bike has O2 sensor, I don't think you need to do anything, just install it. O2 sensor will send signal to ECM to add fuel if necessary.
Old 03-28-2017, 11:31 AM
big- mike's Avatar
big- mike
The o2's will signal the ecm to the point of running at the same lean condition as the factory setting if you are planning more upgrades I think the benefits of a upgradeable programmer would be worth it. Your gonna need one sooner or later anyway. Just my opinion
rangerwwc72
05-07-2019 12:04 PM
cchuck3537
2018+ Softail Models
05-06-2019 09:51 AM
tt_ksu
11-25-2014 07:39 PM
ridinlow
07-06-2009 08:44 PM
09BlueRoadKing
12-13-2008 08:46 PM
Quick Reply: Adding only a Screaming Eagle Heavy Breather to a stock 96ci Street Glide
