Harley Service Schedule*
Old 10-13-2005, 04:27 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default Harley Service Schedule*
Here's a printable link on a dealer page to show the services performed at the different miles on the various models... HERE
Here's also the wrenching section on the HD web page that you fill in the vin number and mileage and it will give you the services to perform, plus any recalls also... HERE
Old 04-13-2009, 03:18 PM
CHGO5OH's Avatar
CHGO5OH
CHGO5OH is offline
After reading this thread, I will be doing my own maintenance. Thats a lot of money to be spending on just inspections and oil.
Old 04-13-2009, 04:27 PM
Arizona's Avatar
Arizona
Arizona is offline
Yes that's pretty much what it is. I'll try to attach my 10,000 mile checklist that I made for myself (I just tried and can't get it to downsize to fit what will load here - if someone wants a copy PM me and I'll send you one via email).
It's essentially changing all the fluids and oil filter, cleaning the air filter element, checking the torque on critical fasteners (motor mount bolts, frame bolts, brake caliper bolts), inspecting the brake pads, inspecting the brake, fuel and oil lines/fittings for leaks. Checking the brake fluid levels, inspecting the tires, greasing the steeringhead bearing, checking the clutch adjustment, inspect exhaust system for leaks, inspect the drive belt condition and tension, inspect and lube the jiffy stand if necessary, check operation of the electrical switches, lights, etc.
Old 04-13-2009, 05:48 PM
BigGdawg's Avatar
BigGdawg
BigGdawg is offline
Thanks! That is valuable info that everyone should have.
Old 04-13-2009, 08:13 PM
hogginit's Avatar
hogginit
hogginit is offline
Great to see so many doing the maintenance yourself.
Downside to this is now the dealers will recognize the loss and raise the price of the service manuals from around $60 to $500 each.
Old 07-07-2013, 08:23 PM
SteviJ's Avatar
SteviJ
SteviJ is offline
Every rider should have a service manual. Period. Changing fluids is easy, it saves money better spent on chrome, alcohol, or whatever, and it gets you to know your bike. I am amazed at supposedly big boy Harley riders that act like a girl when it comes to maintaining it. Disgusted, actually. Man up and change your frigging oil!
arrowslinger1980
07-09-2014 03:31 PM
cbudge
05-18-2010 09:51 AM
Navy Mustang
02-19-2010 12:00 PM
Bluegrasser
03-18-2009 04:54 PM
BoomSoon
08-08-2008 08:34 AM
Quick Reply: Harley Service Schedule*
