battery wont hold a charge
Old 04-01-2008, 10:13 PM
grat's Avatar
grat
grat is offline
5th Gear
Default battery wont hold a charge
I have an 81 sportster
its running but only fora few minutes
its got a brand new battery and i have to charge everyday
so something is draining the battery
any ideas
thanks
Old 04-02-2008, 06:13 AM
als88's Avatar
als88
als88 is offline
Default RE: battery wont hold a charge
check your charging system. do a search, you will find some info on how to do it.
Old 04-02-2008, 06:33 AM
sleepneagle's Avatar
sleepneagle
sleepneagle is offline
your stator is probably bad. as als88 said, trouble shoot the charging system and check all connections/grounds to be clean and tight.
Old 04-02-2008, 11:57 PM
Steelknee57's Avatar
Steelknee57
Steelknee57 is offline
An easy way to see if something is drawing from your battery is touse a mutimeter. With the key off and the kill switch off, disconnect the positve lead to the battery and put the multimeter in between to make the connection.
Any more than abouta .7or moreamp draw is too much and will cause your battery to discharge while your bike is just sitting there. .5 or less is good.
Old 04-05-2008, 05:56 AM
HD47knuckle's Avatar
HD47knuckle
HD47knuckle is offline
Ihad a similar problem on my 79 FLH.When I went to do my checks on the systems i found that my plug to my stator had vibrated or got knocked off.A HD manual will tell you how to do your checks.I also agree with another post you recieved check your connection and the most important thing is make sure that you have a very good ground.If you need to know how to do your checks with an multi meter let me know if you can't find the procedure.GOOD LUCK!!
"Keep the shiny side up rubber side down"
Redd-Rider
01-28-2017 11:49 AM
xl8832007
02-12-2014 05:32 PM
Savgator
09-22-2010 05:24 AM
Rugbymikes
06-22-2010 10:34 PM
I8SMK4U
05-11-2009 04:18 PM
Quick Reply: battery wont hold a charge
