Sportster - Problems Finding Neutral
Old 05-22-2003, 02:25 PM
Jeff Boyer's Avatar
Jeff Boyer
Jeff Boyer is offline
Stage I
Default Sportster - Problems Finding Neutral
Dear Forum:</P>
I am glad I found you folks. Hey, I am having trouble finding neutral on my new 2003 Sportster 883 R. It goes right from first to second too many times and it is getting embarrassing.</P>
I have adjusted the clutch cable a couple of times now (to disengage the clutch more) and still can't find neutral on command. I have moved the "Cable Sleeve" towards the engine to make the cable tighter and still have some problems. Some guys have told me I have to "live with it" until it breaks in.My son's 883Custom has never had any problems shifting. Isthere a "starting point" to start over on my adjusting?</P>
Sitting in a parking lot trying to find neutral is a pain in the rear or driving around in little circles trying to do the same.</P>
Help!!!Jeff</P>
</P>
</P>
</P>
Old 05-22-2003, 03:14 PM
Gearhead99's Avatar
Gearhead99
Gearhead99 is offline
6th Gear
Jeff,</P>
Welcome to HD's. They are a bitch to find neutral sometimes. As you get more miles it loosens up some. Synthetic oil will help some too.</P>
But all in all it can be a real PIA.</P>
Old 06-30-2003, 02:39 PM
Harley Dude's Avatar
Harley Dude
Harley Dude is offline
<img border="0" src= smileys/smiley16.gif>Jeff,</P>
I have a 2002 XL883H and it took about 5000 miles to get her where it now goes into N without too much problems. It's just kind of a trick to get her in. Give it some time, if you are still having trouble I'd take it back to the dealer and have them take a look. But I think it's just a BREAK-IN thing.</P>
Good Luck,</P>
Steve</P>
Old 07-02-2003, 09:47 PM
RWNBLUE's Avatar
RWNBLUE
RWNBLUE is offline
Stage I
Yep that's pretty much it.... My sportster was the same.... Stiff Virgin and is still somewhat tight</P>
Old 12-15-2015, 10:38 PM
DakiHD883's Avatar
DakiHD883
DakiHD883 is offline
2nd Gear
I have the same problem too. I just bought a 2016 883 and I am having trouble finding neutral
Old 12-17-2015, 10:47 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Wink
Problems selecting neutral can often be traced to clutch adjustment, however the correct way to do that involves adjusting at the clutch itself, not only the cable. We have a Sticky here, which should help those of you with older bikes. With your new bike Daki, see if you can get through to the first service, then ask your dealer to check and adjust it. If it is too troublesome now, then take it in sooner, don't suffer!
Old 12-20-2015, 08:53 PM
spiritwarrior's Avatar
spiritwarrior
spiritwarrior is offline
Next time use a good synthetic oil. Mobil 1 the problem will go away.
Old 12-23-2015, 08:06 AM
just plain john's Avatar
just plain john
just plain john is offline
Synthetic primary fluid did wonders for mine, although it's not a Sportster.
Old 12-23-2015, 08:24 AM
JustDave13's Avatar
JustDave13
JustDave13 is offline
Received 15,090 Likes on 6,141 Posts
I had the same problem with my bike and it's actually two different factors causing the same problem.
One factor is the owner not quite familiar with with the bike and the other is break in.
Seeing as the bike is a 2003 and Jeff didn't tell us the mileage we can assume it's already broken in.
This leaves the new owner getting to know the shifter.
Old 12-23-2015, 08:39 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Maybe you need a new clutch cable...??
Quick Reply: Sportster - Problems Finding Neutral
