step by step walk through of rocker cover gasket replacment
I just used these instructions. They were very helpful. I really like the pics. They help a lot. But I do believe these instructions are for 2004 and newer Sportsters. My 2003 doesn't have a breather and it also has a spacer between the bottom and top rocker. But the instructions still worked well
The only thing I would add is I had to reuse the rockers inside the bottom rockers. I had to pound out the pins and use them on the new bottom rocker. You do have to align the pins correctly to get the bolts to go through.
I replaced the bottom rockers and top rockers with chrome ones. I kept my black spacers. But thanks for the help.
Thanks!
EXCELLENT walk thru OLDSKOOL THANKS!
There were a couple of differences between the manual and your description but I think these differences were basically cosmetic (minimal). Most notably, the manual calls for re-seating pushrods later in the process. But you, I think, had set that up earlier by beginning with leaving them in the lowest position to begin with. The manual also complicates that process by calling for the lower box to be tightened, then re-seating the pushrods, then retightened. Seemed like overkill to me. We'll see when I start it up...hehe.
Also, the stock gasket kit includes a couple of extra gaskets which is confusing.
But overall I found your walk-thru to be extremely valuable. THANKS AGAIN!
uh oh :((
So, I think I have a bit of a problem....
I had a friend that was replacing the rear gasket and have snapped a bolt off.....
He went to do it again...same thing...even with a less than spec torque..
He then thought it would be a grand idea to rethread the part of the head and put a bigger bolt...when he was tightening this, it snapped like a twig and didnt tell me...was riding today and it was leaking bad, took it apart to find this.
Can anyone give me a sign of hope here feeling like **** about this and just want to ride
Can I fix this?
Can I fix this?
Can I fix this?
Can I fix this?
after doing this i got some rattle for a little bit but then it went away after a few minutes of idling is this something to be concerned about? also i snapped a couple bolts but was lucky enough to vice grip em out went to oreillys and got new ones definately was hesitant to use my torque wrench so the bolts are as tight as i felt comfortable tightening them
I am getting ready to perform this on my 2006 HD Softail Deuce.
Bill
