step by step walk through of rocker cover gasket replacment
Old 08-21-2016, 03:05 AM
joelsdaddy's Avatar
joelsdaddy
joelsdaddy is offline
Stage I
yes the back is difficult especially if you have a solid mount motor because it is internally balanced motor. you must remove the rockers with the spacer in place then remove the spacer, one remaining bolt and the rocker box.
Originally Posted by im
For what it is worth.
The rear cover is difficult to work on.
Some bikes have very little space.
If that is the case.
Consider removal of front bottom motor mount and stabilizer..
This will drop motor forward and give about 1/2 inch or more to work rear allen bolts off.
Use cut allen bits (just a little more than the L part) or stick a cut small piece of a 3/16 ?? allen size bit into allen bolt and use a sears midget 3/16 ??? wrench set to turn allen bolt..some bikes are next to impossible to torq all four to speck on the bike..
J and P cycle has a slim tool that could be used to check torque if you want to.
Old 10-06-2016, 09:16 AM
Avizba's Avatar
Avizba
Avizba is offline
1st Gear
Hey guys, what year did they quit putting the rocker spacers for the sportster 1200?
Old 12-04-2018, 10:41 AM
Kent Maynard's Avatar
Kent Maynard
Kent Maynard is offline
1st Gear
Default James bottom rocker box gasket
Originally Posted by old skool1983
the sealent was overkill..you will be fine.
This gasket comes with instructions to not use any sealant. I think using sealant on the other gaskets (the rubber ones) is an excellent idea.
Old 12-04-2018, 11:02 AM
Andy from Sandy's Avatar
Andy from Sandy
Andy from Sandy is offline
Received 3,736 Likes on 2,401 Posts
If the mating surfaces are clean and have never seen a sealant then it shouldn't be necessary to use any. If you have dinged the mating surfaces getting an old gasket off then a very thin smear to fill them is all that is required.
The OP picture looks like way too much to me.
Using a sealant can actually make matters worse trying to clean it off the next time the parts are separated.
Old 12-04-2018, 12:04 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,255 Likes on 3,627 Posts
Hopefully the guy got his bike back together. Last post was over 2 years ago.
Old 02-05-2020, 03:54 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,198 Likes on 895 Posts
Well hopefully no one else ever sees this then. You don't use any sealant especially silicone and for gawd sakes NO RED LOCTITE.
There's very few instances you ever use red loctite on a bike period. You don't even need blue loctite here.
NiteOwl
Engine Mechanical Topics
08-23-2016 07:36 AM
HD100
09-21-2011 07:38 PM
SpicOfTheDevil
01-01-2011 03:11 PM
professor_aquino
07-31-2009 04:03 PM
Quick Reply: step by step walk through of rocker cover gasket replacment
