manual starter lever
Old 03-11-2016, 12:36 PM
monckywrench's Avatar
monckywrench
monckywrench is offline
Thanks for the useful thread.
Here's a pic of my test cover. They cut easily with a hacksaw (spray WD-40 on teeth to avoid clogging) if that's all ya have.
I found the rod in the manual setup dragged on my starter drive lever (the stock noid setup has more slop) and was able to cover the clutch basket and adjacent area with a shop rag then easily grind more clearance in the installed lever. Beat pulling my stock FXS oil bag to remove the lever.
  #32
Old 03-11-2016, 05:10 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,004 Likes on 2,817 Posts
I Installed one of them on my Shovelhead several years ago and it went together slick as c_m on a gold tooth. It's basically nothing more than a manual solenoid. Most expensive starter switch I ever bought and worth every penny.
  #33
Old 04-04-2020, 03:14 PM
CluelessGeek's Avatar
CluelessGeek
CluelessGeek is offline
Originally Posted by Denis O'Brien
Does anyone have a photo of the setup inside the primary.....?
Seconding this. Seeing an actual picture of installed would be amazing.
  #34
Old 04-21-2020, 10:43 PM
CluelessGeek
Where in the smeg do you mount the big starter relay you're supposed to have bought to go with this thing?
  #35
Old 04-21-2020, 10:44 PM
IzzoQuazzo's Avatar
IzzoQuazzo
IzzoQuazzo is offline
Retired Admin
Received 9,039 Likes on 3,711 Posts
You're the first person to read this thread in 4 years. I don't think you're going to get any response,
CluelessGeek (04-21-2020)
  #36
Old 04-21-2020, 11:01 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,919 Likes on 17,474 Posts
Bottom of the battery box towards back end is the usual spot. You will need to find or make some cables if want a decent clean setup.
  #37
Old 04-21-2020, 11:02 PM
CluelessGeek
Ah. Well, considering this bike has an aftermarket setup, I'm going to have to scratch myself with a lug wrench for a bit to think of something.
  #38
Old 11-08-2020, 07:25 PM
shankman's Avatar
shankman
shankman is offline
i need help you still around? Lever solenoid
guitarman023
Shovelhead
11
08-03-2015 06:39 PM
duallram03
EVO
05-25-2013 08:06 AM
zeke47
01-03-2013 10:12 AM
hebbes
Electrical/Lighting/Alarm
05-21-2012 12:37 PM
Delawaredave
10-26-2009 06:58 AM
Quick Reply: manual starter lever
