Will 96ci top end fit 06 88ci
I bought a 09 96ci top end.
I wanted to know if these cylinders, pistons and cams will work on my 06 88ci
engine without a lot of modifications.
Thanks,
Unkwaldo
Thanks,
Unkwaldo
A 96" is basically a TC88 with 103 stroker flywheels. Cams are not interchangable, but pistons amd cylindrs should the same as a TC88. Also, the cylinder heads and the intake manifold are different, they changed them in 2006. They will mount, but the angle of the intake and the injectors are different, and of course in 2008 on the FL's they went to a 50mm throttle body, and that needs no more explanation.
