Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Side car retrofit
Old 01-14-2013, 10:25 AM
golfdog's Avatar
golfdog
golfdog is offline
Stage III
Default Side car retrofit
Can a HD factory sidecar be fitted to the new 2012 Ultra?
Old 01-17-2013, 01:56 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Good question! Probably. I suggest you call in the Hacked forum and ask there, that is where all the three wheeler brigade hang out.
Old 04-11-2015, 12:59 PM
46u's Avatar
46u
46u is offline
Yes if you have the correct mounting kit.
Old 04-12-2015, 06:10 AM
DianneB's Avatar
DianneB
DianneB is offline
Or the skills and tools to make your own
http://www.diannebest.com/Projects/M...s/Sidecar.html
Old 04-12-2015, 09:41 AM
SIDECAR BOB's Avatar
SIDECAR BOB
SIDECAR BOB is offline
What year is the sidecar? the area that would concern me would be the rear mount that mounts on the swingarm bracket, you may have some alignment problems if the frame is wider on the newer frame. If the outside width of the bike frame is the same as the older frame where the swingarm mount it should work. You probably will just need to fabricate or change a couple things , when I put a 89 sidecar on a 07 bike the only significant change was the rear master cylinder had to have the remote reservoir lit to function , on some bikes you may need to extend the oil pressure sending unit to clean the front tube on the hack
Old 02-25-2017, 02:57 PM
scottconway7's Avatar
scottconway7
scottconway7 is offline
2nd Gear
all except brakes dot 4 on your bike dot 5 on sidecar and can't mix brake fluids it will ruin seals in caliber
Old 02-25-2017, 03:00 PM
scottconway7
2nd Gear
I am in search of update caliber o rings my self since I have 2002 side car (DOT 5) and fitting it on my 2010 ultra limited (DOT 4)
Old 02-28-2017, 11:51 AM
scottconway7
2nd Gear
Never mind after doing the research you can hook up the sidecar and use the brakes because the books call for the same caliber rebuild kit whether it is dot 5 or 4
olcrazy1
08-29-2015 05:50 AM
Noble Jim
13
05-18-2013 07:32 AM
Richard Osborne
05-07-2009 12:38 AM
Smokeater
13
07-10-2008 11:50 AM
Bill6750
03-12-2008 06:37 PM
Quick Reply: Side car retrofit
