Cruise Control Adjustment
Old 08-12-2005, 09:31 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default Cruise Control Adjustment
Cruise Control
On ‘97 models only, if cruise does not set above 60 mph or speeds up from 60 to 70 mph and then
cancels, check cables for proper adjustment. If the adjustments are correct, the cruise module may
need to be replaced. For replacement use P.N. 70989-98 and use existing cruise cable.
If you change an induction module P.N. 27202-98, it has the new ‘98 cruise cable connection. The
‘97 and earlier cruise cable requires that the throttle actuator plate on the ‘98 module be replaced
with the one from the previous module. Use the instructions in the Service Manual listed for ISC
replacement to accomplish this.
The ignition module on carbureted bikes does fire (at TDC) for the first few revolutions and does not
ignore the first three sensor inputs as described in the cruise diagnostics.
Source: Private
FNFAL
Electrical/Lighting/Alarm
10-02-2017 08:02 PM
tmac61
11-09-2014 08:42 PM
Padickie
General Topics/Tech Tips
06-18-2012 04:54 PM
Bobby9700
11-16-2009 06:48 PM
D1
07-24-2006 01:41 AM
Quick Reply: Cruise Control Adjustment
