What Lubricant for Throttle/Clutch "Cables" ?
Old 02-12-2007, 11:11 PM
UmpOne's Avatar
UmpOne
UmpOne is offline
Default What Lubricant for Throttle/Clutch "Cables" ?
The Service Manual for my 2007 Street Bob calls for SUPER OIL (HD-94968-85TV) when lubricating cables & hand levers. The H/D parts guy tells me they haven't stocked thatOIL in the last 12 months. He didn't know what to use. Service dept. closed on Sundays, so no help there, but I knew someone on the forum would know.Will WD-40 work or is there a better product?
Old 02-12-2007, 11:24 PM
wesd41's Avatar
wesd41
wesd41 is offline
Default RE: What Lubricant for Throttle/Clutch "Cables" ?
I've used wd40 for years with no problems, just started using dedicated cable lube a year or so ago, works really well too.
For lever pivots I remove and clean them with wd40, then give 'em a dab of water proof grease.
Old 02-12-2007, 11:49 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
There are far better lubes than WD-40. WD-40 dries and leaves little lubricant and more of a protectant.
I use Rem Oil...
http://www.remington.com/products/ac...lubricants.asp
Old 02-13-2007, 12:06 AM
shortfatboy's Avatar
shortfatboy
shortfatboy is offline
WD 40 has many uses, but is NOT a lubricant. Fact is, it will attract and retain more dirt than about anything You can use.. Tri-Flow, or a similar teflon lube is suitable.
Old 02-13-2007, 12:28 AM
bobcowan's Avatar
bobcowan
bobcowan is offline
About 6-7 years ago, I bought a largish can of chain and cable lube for about $8 at the local motorcycle shop. I lube the cables on the bike, my car clutch cable, and anything else that looks like it might need itonce or twicea year. It works well, stays lubed for a long time, and I still have at least half the can left.
Old 02-13-2007, 06:45 AM
OneBlackFly's Avatar
OneBlackFly
OneBlackFly is offline
If your cables are stock (black), look for Dri-Slide, aka Bike-Aid - it contains graphite (black). If you have clear braided cables, look for Gunk w/ teflon - nothing w/ graphite - you want a clear lube. As another member mentions, WD-40 leaves little lube, better to try to find one of the suggestions.
Old 02-13-2007, 11:22 AM
UmpOne's Avatar
UmpOne
UmpOne is offline
Thanks for the help. Off the the store one more time.
Old 03-22-2007, 08:20 AM
pjbolo's Avatar
pjbolo
pjbolo is offline
if you can get your hands on it, thers a product called zep 45 made by zep mfg works great...
Old 03-22-2007, 05:36 PM
thrillseeker's Avatar
thrillseeker
thrillseeker is offline
I use Dri Slide. I like it. Its got a nice little needle applicator the fits down into the sleeve
Old 01-23-2008, 07:25 PM
VTwinJaxFL's Avatar
VTwinJaxFL
VTwinJaxFL is offline
I just used the dri-slide, nice applicator that doesn't create a big mess. I'm not sure how much to put in there, I just gave it a good squirt and figured that was a enough. Didn't want to put too much in there. Any feedback on that?
Quick Reply: What Lubricant for Throttle/Clutch "Cables" ?
