Major problem with bike jack...
I have a major problem. I have a Torin Big Red m/c jack. I jacked my Dyna as high as it could go and I released the handle to let the jack sit on the last stop on the jack (instead of the bottle jack itself). Now.. when I pump my jack the handle is completely free as if there is NO pressure at all in the bottle itself. This means I can't jack the bike up high enough to release the arm that is holding the jack in place. Basically.. my bike is stuck up in the air on the jack.
WTF?????
WTF?????
Received 47,785 Likes
Also, be sure that the lock is fully engaged ( so the jack cannot come down ) and check to see if you can open the hydraulic release. Let the piston retract fully and check to see that the fluid is at the proper level. You may have a low hydraulic fluid situation and refilling the fluid will resolve the situation.
Received 5,193 Likes
Yep. I've forgotten to close the valve after opening it to let the stops come into play
Keithhu
03-12-2010 01:56 PM
