Help: Minor Corrosion on chrome
So I did some research on here and I didn't really get a definite answer. I found plenty of threads about polishing your chrome and making it look nice, helpful, but not quite what I was looking for.
I unfortunately have some chrome on the back...wheels..risers..and some of the fork yokes that are starting to corrode. Nothing really heavy, like pitting or any damage to the metal. Some parts have very small amounts of surface rust and a lot of the chrome is starting to oxidize and get that hazy white material over the chrome.
For some reason my father in law recommended using 3M Imperial Hand Wax and said it works pretty good, that was a waste of 20 dollars. I am trying to find something that I can use to scrub and get that stuff off, especially the rust. Someone told me to use balled up aluminum foil and get it wet, I am not trying that until I get a definite answer it will not scratch my chrome. I do need something abrasive though that won't cause damage.
Let me know what you guys think and thanks so much in advance!
I would try some Nevr Dull first. Then if that did not work I would suggest Maas Chrome Polish. If either helps get rid of the stains then once done coat everything a couple times with Turtle Wax carnauba cream wax.
If your parts are beyond saving, you can send them in and we can re-chrome them for you. We offer special discounts to forum members!
Received 47,745 Likes
Chrome Cleaner ... That's what it's made for and it does the job. Once cleaned you do it again with a Quality Chrome Polish ( Dupont ) for the final shine an it leaves a protective coating. The Mothers and Never Dull products are primarily for aluminum and contain a more aggressive ( abrasive ) composition.
Iv'e always used #00 or #000 steel wool with WD40 and then wax. Metal polish removes some of the chrome, thats the black color on the rag.
