Help???
Help???
Ok,
So the other day I decided to finally install the cruise control on my '07 Electra Glide Standard. Everything was going ok until I went to install the new right side controls. I pinched the wires (dumbass) and so when I went to start it, I kept popping fuses. So I pulled it all apart tonite and cut out the pinched wires and soldiered them back together. No more blowing fuses (at first) but I had no turn signals, and no starter. So I checked EVERYTHING 10 times and couldn't find anything so I finally hooked everything back up to the handlebars and hit the right turn signal, and my radio went crazy and then the accessory fuse blew. Now, I have the security light on solid on the dash (has never been on before, as a matter of fact, the security system has not been active up until this point) and I also have the following codes (in the order they appear)
PN-34455-07c
No RSP
U1255
Pn-67349-04a
pn-67348-04b
I am at a complete loss and really need this bike running again as it is my primary transportation. Any help is greatly appreciated!!!
PN-34455-07c
No RSP
U1255
Pn-67349-04a
pn-67348-04b
