Sportster not running smoothly
Old 07-30-2014, 05:16 PM
dawroz's Avatar
dawroz
dawroz is offline
Default Sportster not running smoothly
Hi. I have 1987 Sportster converted to 1220. Everything was ok after the conversion. Now - after 4 months of riding - I feel that engine is not running smoothly. It's ok while accelerating, but during peaceful moderate ride I feel kind of pulling (at about 2200-2600 rpm) and I see turbulent movement on my tachometer. Decreasing speed is also uncomfortable. The engine is twitching.
I tried everything - 3 different carbs, different nozzles, clutch adjustment and I still feel it. I heard its bad old fuel, so I cleaned my previous carb and tank. It's much better but the problem still exists. What is it?
Old 08-01-2014, 04:53 PM
dawroz's Avatar
dawroz
dawroz is offline
I saw something today.
I have automatic promary chain adujster. Working good.
Its look like: clutch many times is some faster from my crank shaft and chain is not tense on the upper side. This is no sense.
HALP
Old 08-04-2014, 07:05 PM
vaxt's Avatar
vaxt
vaxt is offline
Maybe you have some tight links in the chain. Check each link for freedom of movement. You may also have a loose chain. When is the last time that you adjusted it? How many miles on the chain?
steambc
10-15-2014 10:12 AM
Jmarcher
02-20-2011 03:49 AM
JustDave71
11
06-12-2010 11:08 AM
Wstar425
06-27-2008 06:35 PM
jgcable
02-14-2008 07:28 AM
Quick Reply: Sportster not running smoothly
