Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Transport trailer
Old 11-13-2015, 07:53 PM
artsbest's Avatar
artsbest
artsbest is offline
Default Transport trailer
Wife has a CSC conversion Goldwing trike. I have a new Breakout that we customized (turned out beautifully). Any input as to what length of a covered trailer I need to haul both of these machines?
Old 11-14-2015, 07:26 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Measure the length of the bikes parked liked they are in a trailer.
Then add some space in the front and rear.You will need to have room for tie downs.
Keep in mind anything extra that will go on the floor.
Some smaller stuff can go in hanging cabinets on the sides.
Old 11-16-2015, 09:18 PM
artsbest's Avatar
artsbest
artsbest is offline
The trike takes up a lot of space but when backed into the trailer it leaves some more room. I'm trying to go as small a dual axle trailer as I can. But the trike makes it difficult.
Thanks for your input.
Old 11-16-2015, 10:02 PM
tnriverluver's Avatar
tnriverluver
tnriverluver is offline
I would think 16 x 7 would be about as small as you could go and that is assuming you can get the Breakout over to the side of the front of the trike. If possible angle the trike in at the last moment. If you have to loaded them front to back centered you will need an 18 footer. Wheel chock and tiedown placement would be much simpler straight front to back!
Old 11-17-2015, 10:27 AM
artsbest's Avatar
artsbest
artsbest is offline
I looked at a Haulmark low hauler v-nose trailer. Placing the trike front first allowed for more room. The Harley would have to be placed at a side type position. I believed the trailer was a 7X16?
Old 11-17-2015, 01:56 PM
tnriverluver
You should be able to get the 7x16 to work with a little figuring. Most any 1/2 ton truck will pull it OK also. If you happen to own a 3/4 ton so much the better.
Old 11-17-2015, 01:58 PM
tnriverluver
The only real issue I see might be tongue weight with the trike up front. That can be helped by loading some other heavy stuff towards the rear of the trailer along with the bike.
Old 11-17-2015, 10:27 PM
artsbest's Avatar
artsbest
artsbest is offline
Exactly. The guy from the trailer joint got out his calculator and with the bikes weights came up with a loading configuration mostly focusing on just what you stated. The tongue weight with the v-nose trailer would be too heavy thus a need for more weight in the rear of the trailer. I own a F-250 diesel so there's no problem pulling it. These new trailers are aluminum builds and weight very little for their size. Thanks for your thoughts. Much appreciated.
Old 11-18-2015, 04:59 PM
tnriverluver
Glad it sounds like you have a knowledgeable and honest salesman. Most RV and trailer salesman would tell you a Geo Metro could haul that trailer
Old 11-19-2015, 08:06 PM
artsbest's Avatar
artsbest
artsbest is offline
Yes he was honest. And the outfit he works for does a good business selling trailers and motor homes. Some of these big units in excess of $800K. I'll pass thank you.
Quick Reply: Transport trailer
