Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Heritage Trike Conversion
Old 09-03-2016, 11:32 PM
OldTimer's Avatar
OldTimer
OldTimer is offline
Default Heritage Trike Conversion
Been a while since I was here. Got a question on the electronics box under the rear fender of a 2011 heritage.
I converted to a trike using a Frankenstein Trike Kit. It's a great kit and I am happy with it except for one problem!
The belt rides very close to the electronics box under the rear fender. So close that I had to take a Dremel tool and cut away some of the mounting bracket so the belt would not rub.
My question is can this box/bracket be moved over a bit or relocated.
Thanks for any help on this!
Old 09-05-2016, 06:07 AM
FreedomRider's Avatar
FreedomRider
FreedomRider is offline
I have a Frankenstein kit on a 2008 Sportster and my drive belt runs in the stock location, I would think yours does as well. Your drive belt should be no closer to the box/bracket as it was before the kit was installed ... it's just that now you can see it due to the rear wheel being removed.
If you need to move it I wouldn't think that should be a problem. As long as everything plugs in correctly ... where it is mounted shouldn't make any difference.
I'm just not understanding how the belt could be closer now than it was before ... belt angle and location should be the same as it was before installing the Frankenstein kit.
Old 09-21-2016, 10:19 PM
OldTimer's Avatar
OldTimer
OldTimer is offline
No. The belt is not in it's original position! It is now about half a belt's width to the inside. It's been that way since day one. Enclosed are photos of it before I took a Dremel tool and notched the mounting bracket for clearance. there is about 1/8th inch clearance between the belt and the box!
Attached Thumbnails Heritage Trike Conversion-imag0210.jpg   Heritage Trike Conversion-imag0211.jpg   Heritage Trike Conversion-imag0188.jpg   Heritage Trike Conversion-imag0193.jpg
Old 09-21-2016, 10:32 PM
OldTimer's Avatar
OldTimer
OldTimer is offline
Photos of the finished product before the fenders!
Attached Thumbnails Heritage Trike Conversion-imag0293-copy.jpg   Heritage Trike Conversion-imag0294-copy.jpg
Old 09-26-2016, 05:43 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
looks to me your belt isn't tracking right,might have the set up looked at.
dramatik
03-01-2013 07:30 AM
37sportster
03-26-2011 08:49 AM
fireman02
06-01-2009 01:56 PM
BGHFD
03-24-2008 11:46 AM
hmmr
01-27-2008 11:41 PM
Quick Reply: Heritage Trike Conversion
