Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Pulling Trailers
Old 03-10-2017, 05:57 AM
2007wing's Avatar
2007wing
2007wing is offline
Stage I
Default Pulling Trailers
Please steer me to Harley owners who pull cargo and/or camper trailers. I have a 2008 Bunkhouse cargo trailer and interested in the suggested models of Harleys to pull this unit with.
Old 03-10-2017, 06:02 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,324 Likes on 3,269 Posts
Any touring platform will pull it but make sure your hitch can handle it. Depending on your motor, a different set of cams might be better as well.
Old 03-10-2017, 06:03 AM
foxtrapper's Avatar
foxtrapper
foxtrapper is offline
Received 1,239 Likes on 808 Posts
I've pulled heavier trailers with a 750 Honda. There isn't a Harley made that can't pull it.
Goose_NC (01-10-2020)
Old 03-10-2017, 09:10 AM
Boomer1143's Avatar
Boomer1143
Boomer1143 is offline
I pull my trailer with my 2012 FLHTK.
Old 03-10-2017, 09:11 AM
rick-e-b's Avatar
rick-e-b
rick-e-b is offline
I have a RG and used to pull a Harbor Freight trailer with an EX-Cargo clam shell. You can carry a lot of stuff in a trailer like that. There is no problem pulling a trailer with a Harley. I had to angle my mirrors down so I should not forget it was back there. There are a couple of things to note. #1 always get your weight more to the front of the trailer, otherwise it will tend to wag its tail like a dog. That is unsettling at highway speed. #2 Although they pull very well, they do extend braking distances, be aware and avoid panic stops. #3 be aware of curbs in parking lots, driveways, and gas stations. You do not want to catch you trailer wheel on curbs. Otherwise enjoy and ride safe!
shoboli nan tanna (12-17-2019)
Old 03-10-2017, 11:08 AM
GoofySB's Avatar
GoofySB
GoofySB is offline
There is also a Trailering forum here
https://www.hdforums.com/forum/hacke...railering-100/
Old 03-10-2017, 11:11 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
Old 03-10-2017, 02:34 PM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is offline
Received 1,563 Likes on 1,082 Posts
Any HD touring model should work for you. Keep in mind the following:
1. If you plan to tow a trailer, you should only look at motorcycle models that have dual front disk brakes.
2, You'll probably need to downshift a gear or two if you ride through steep or hilly passes.
Old 03-10-2017, 08:54 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
dont spend money on extra warranty, harley won't honor it if u pull a trailer.
Old 03-11-2017, 03:54 PM
deadhawg's Avatar
deadhawg
deadhawg is online now
Received 1,723 Likes on 664 Posts
First choice would be a big twin, though any Harley can pull it. I have a friend who pulls a good size cargo trailer with an 883 Sportster, though that would not be my first choice.
I've pulled an Aspen camper all over the country with a 2000 Roadglide. For me, the best improvement for pulling the trailer was to drop the front belt pulley from 32 to 31 teeth, gives better pulling power without having to downshift as much.
I later added a sidecar to the bike, the knees and ankles just ain't what they used to be.
The following 2 users liked this post by deadhawg:
ABQ-Jammer (11-13-2019), smitty901 (01-20-2020)
Quick Reply: Pulling Trailers
