Raked Neck Cups.
Raked Neck Cups.
HI all..
well.. that tax return check should be in next week, as soon as it is i'm placing my oder with Mystery.
In the meantime I've been superbusy with researching this whole project. Budget wise, I can not do the complete front end like I'de like to this year. Eventually I would like either a 5 or 7 degree raked tree, with 4" over tubes.
but for now I have found that they make raked cups. I know that to get the wobble out rakign is necessary and though it won't be as raked as I would like, for the $179.00 dollars I could at leat make it a little longer and safer this year.
Does anyone have experiance with raked cups ? It will not be my final anwser, but Pro's and Cons would be apprecieated and installition info if anyone can help..
thanks again all..
I will post pics of my build as soon as i start it.. thanks.
Kevin.
[align=center][/align]Raked Chrome Neck Cup Kit.Fits 1988-up includes longer stem 3 degree rake requires longer fork tubes
thanks again all..
Kevin.
RE: Raked Neck Cups.
hey, dive. i can't help you with the idea of raked cups. i considered them, but went ahead and went with my raked trees and extended front end. i have heard that raked cups work fine and for the price, you should see some improvement in the handling.
have you considereda steering damper, for the speed wobbles? i was very close to purchasing a steering damper, but couldn't find one that would give me a proper fit. if i can recall, you have a sportster, and Storz makes something you might find beneficial.
check it out!
http://www.storzperf.com/np_Sportsterdamp.html
check it out!
Thanks again Grimm.. I've not considered them.. only because i hate the way they look.. "ya know as they say, It is better to look good than to geel good"........ I would.. for safety sake in a last ditch effort. but if i can get the results from a raked cup, probably about the same price anyway..
ORIGINAL: dive328
I,m not going to run longer tubes, at least not yet. I'm going to sqautt this thing as low as possible. If the handling is not as improved as i want, then eventually I will add longer tubes.
kurt84
07-13-2009 09:21 AM
