Ultra//Trailer/ Wiring ??s
A ?? for all you Ultra/ Cargo Trailer Gurus........Here goes; On your bike do you use a converter to adapt the bike's 5 wire setup to the trailer's 4-wire ? (& if so, does it work ok & what converter ?) or
Do you just wire all 5wires to the trailer lights ? (and if so, what lights/LEDs? ) The only lights/LED I can find commercially available are the standard 4-wire variety...........
Since I'm basically wiring the trailer from scratch ; I'd prefer not to use an adapter & wire all 5 to the trailer & use LEDs...??
Thanks in Advance..........WD
RE: Ultra//Trailer/ Wiring ??s
My trailer's 4-wire/4-plug that plugs from Voyager kit to bike. When I plug the trailer to the bike all lights work but the brake light. Do I need a converter on bike to convert to 4-wire (trailer)? Some say yes, some say no. I have the aux module on bike for brake/turn signal/run lights. Will this conflict with a converter? Cargo-Mate has a converter that I should order?....thanks for any help you can give (I know nothing about electrical).
I've tried to post a resposce to ya Spudster a couple of times, but this forum keeps going into internet outer space on me!
Kuryakn makes a plug and play for your situation. I (very recently) found out that the turn signal to brake/turn/run converter has a load equalizer in it. The plug in goes right in line with that and is wired to the female plug on your bike. Quick and easy.
I initially used a converter but it caused major issues. I rewired my cargo trailer with a set of independent turn signals. This is alos like the set up on my aspen camper. So now, i am straight 5 wire from the bike to 5 wire on both trailers. No more rapid blinking turn signals when i disconnect the trailer harness. I use the Kury connector with my kury hitch.
ORIGINAL: jbhawley
JBH, did you install separate lights for turn signals ?
