Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Safety chains?
Old 02-09-2009, 07:58 PM
nocarb's Avatar
nocarb
nocarb is offline
Default Safety chains?
When hooking up trailer to bike do you hook to a solid connection or a break away type connection? Like a cable tie.
Was thinking about a local guy, had chains hooked up solid and trailer came loose and popped rear tire going down the highway. He did not survive. Would have a break away type connection helped or not. Let's just say trailer hit tire several times and then broke beed on tire. What would happen in a break away type connection? Possibly hit bike once and off goes the trailer.
Just thinking out loud.
Old 02-09-2009, 08:22 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
FLTR2008TRIKE is offline
Good question.
I have a hitch reciever on my Motortrike kit, but had a carry tray made to haul a folded wheelchair if needed in the future. Having a trailer behind me wasnt a first choice because of my situation
Old 02-10-2009, 06:36 PM
2007 ultra c's Avatar
2007 ultra c
2007 ultra c is offline
Mine is hooked firmly, I would hate to lose my trailer and it take out some one else.
Old 02-10-2009, 07:42 PM
nocarb's Avatar
nocarb
nocarb is offline
I have always hooked mine up firmly also.
I would hate to take someone out also but if I had to chose it would be someone else.
Old 02-10-2009, 08:05 PM
kentuckydave's Avatar
kentuckydave
kentuckydave is offline
Default breakaway chains??
In most states, if you get caught with a breakaway system you are in deep hocky!
In Omaha a guy lost a small trailer behind a car. It crossed I80 and speared a car on the other side of the interstate. Trailer tongue went right through the drivers chest.
If I am pulling the thing, I feel it is my responsibility to control it at all times.
My question is why did it come loose in the first place??????
Not trying to cause trouble, just voicing an opinion.
Old 02-10-2009, 08:22 PM
nocarb's Avatar
nocarb
nocarb is offline
I don't know why it came loose. I don't think you are causing trouble and opinions are OK.
Old 02-10-2009, 09:23 PM
SLP24's Avatar
SLP24
SLP24 is offline
Kentuckydave; Its not an Opinion, it is VHT&S Law! Trailers must be secured to the tow vehicle via chains. Personally, on bikes, I make sure those chains can not come off so I don't use S hooks.
If you have concerns over pulling a trailer with the bike to the point where you don;t what to hook it properly, you should not be towing. Chances are you will have other problems with the trailer before it unhooks and blows out a tire.
Old 02-11-2009, 07:05 PM
nocarb's Avatar
nocarb
nocarb is offline
Not a concern just a question, I have heard both ways are better.
As said before, I hook to a solid connection, not a break away connection.
Old 02-19-2009, 04:21 PM
DB10881's Avatar
DB10881
DB10881 is offline
I have considered using some sort of device that will allow the trailer to break away, figured if the worst does happen and somehow the trailer separated from the hitch i would be better off losing it. I never gave much thought to the damage it could cause to someone else in this scenario....definitely making me rethink things now.
ISLANDER1089
13
01-01-2016 10:12 PM
dakotabobcat
09-17-2014 09:57 PM
SG_Jim
05-28-2014 09:05 AM
wrongway2
11
08-29-2010 05:54 AM
SOCALHD
06-21-2009 09:06 AM
Quick Reply: Safety chains?
