Posi or Open End?
Posi or Open End?
I am curious about the type of rear each trike conversion provides. I have the DFT. When I take off hard. I leave two visible, same length peal out marks on the road way. I was at a HD open house and was talking with one that had a champion conversion kit on their bike. He was telling me that his is posi. Where as, depending on the price one pays for the HD Tri-glide. It will be either a posi traction rear or an open ended one. ( One rear wheel drive). Is this true? About posi or open ended rears on the tri-glide?
RJ
RJ
i've always been under the impression that posi was not recommended for trikes in that they will greatly affect turning due to the tendency to want to continue tracking straight. as far as i'm concerned, there are no mass produced trike kits that come in posi, for that reason. i know for a fact that the Triglides aren't posi as the rear ends are made by Lehman and the use a single drive.
that being said, my Frankenstein rear end is not posi, either...
grimm
grimm
My DFT has the slip rear. But as I stated earlier. I will leave a dual peal out mark.
grimm
grimm
trike posi
equal tire marks on pavement does not mean that it is a posi unit, it means equal traction at each wheel.
to check for a posi lift tires off of pavement and spin one side, if other tire spins same direction than it is a posi,if opposite tire spins opposite direction it is an open differential.
I dont think I would want a posi unit on a trike, stearing would become more difficult.
Let me rephrase my question. Does the new tri-glide have only one of the two wheels as a drive wheel or does it have the slip rear?
conversions, differential, frankenstein, harley, kit, motortrike, open, posi, positive, rearend, rearends, run, traction, triglide, trike, trikes
