Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
trike on lift table
Old 02-16-2010, 07:24 PM
62hdbiker's Avatar
62hdbiker
62hdbiker is offline
Default trike on lift table
Anybody modify their air lift table for the wider trike?
I am concerned how stable it would be. Anybody had experience with this?
Old 02-16-2010, 08:19 PM
62hdbiker's Avatar
62hdbiker
Sorry, Tried to delete reply this but couldn't
Old 02-16-2010, 09:55 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
If you have a Handy Lift, the Extension kit provides all the stability you will need, be it the extension wing kit, or the trike wings.... I have used both and are very good kits...
Old 02-16-2010, 10:05 PM
coupe55's Avatar
coupe55
coupe55 is offline
Default Tank Shift & Foot Clutch
Who has this set up or is it home made? I got a bad left foot from a previous wreck, dead nerve's in foot. Could clutch with better than shift with!
You may have posted and I missed it but I would like to see a close up of that set up!
Old 02-16-2010, 10:44 PM
62hdbiker's Avatar
62hdbiker
trike on lift table-dscf0268.jpgI fabricated the whole set up. I have limited use of my left hand and arm, from a fall from a warehouse roof to the sidewalk, so I cant use a hand clutch. I used the stock clutch cable routed under motor up to a bracket by the stock shifter. Hooked cable to foot shifter- now a foot clutch. Used a police shifter for a panhead with 5 gallon tank. (Got it from J&P Cycles) it is maid to mount to down tube- but I fabbed a bracket to move it back toward me a little. You can see it in the pic. If you want I will take a close up and give a better discription.
Old 02-17-2010, 06:04 AM
msocko3's Avatar
msocko3
msocko3 is offline
That is one of the things my dad and I keep tossing around. We have a Direct-Lift which is rated at 1,000. The Handy they have at the dealer is rated at 1,500 and like Shovelhead Bob said has the trike wing kit on it.
Old 02-17-2010, 08:05 AM
ON-3's Avatar
ON-3
ON-3 is offline
I made my own extensions out of 3/4" plywood stiffened with a 2x8. For the rear cross support I used a piece of 1" pipe w/solid 3/4" round stock inside of it. for the front I just used a piece of conduit since it doesn't really have to support any weight. All of the weight is carried by the rear support.
Attached Thumbnails trike on lift table-lift5.jpg   trike on lift table-lift6.jpg   trike on lift table-lift7.jpg
Old 02-17-2010, 08:30 AM
62hdbiker's Avatar
62hdbiker
That is a nice setup that almost anybody can make. Does it feel real secure when it is up?
Thanks
Old 02-17-2010, 09:58 AM
TheJimer's Avatar
TheJimer
TheJimer is offline
Mike;
If you have the ceiling height in your garage, I would suggest that you consider a car lift and modify it to accommodate the trike. There seems to be a price war on in the car lift industry right now and prices have fallen by over 50%. I suspect that you can pick up a car lift now for slightly more than what a MC table lift cost!
The advantage of a car lift are several fold:
1) It is multi-functional, you can use it for your 4 wheel or 3 wheel vehicles!
2) You can adjust the height to any level you wish and work on the trike without bending over!
3.) With the exception of the front wheel, the entire bottom of the trike is open and accessible, unlike a table lift!
4) Mine is weight rated at 7,000 lbs. and has casters to move it around the garage if necessary!
5) You can double deck and stack two vehicles on top of each other!
Attached Thumbnails trike on lift table-100_0195.jpg   trike on lift table-100_0196.jpg   trike on lift table-100_0197.jpg
Old 02-17-2010, 11:00 AM
ON-3's Avatar
ON-3
ON-3 is offline
Thanks
Haven't had any problems. It would be easy to add a longer piece of angle iron to the base to increase stability if you had any concerns.
My lift is only rated @ 1000 lb. but it doesn't have any problem lifting the trike.
Quick Reply: trike on lift table
