Woods TW 6-6 cam specs.
Call Bob Wood at Wood Performance. He is a great resource and will set you up with exactly what you need.
Drop Ins
I don't believe that one is a drop in, springs minimum and list for the 110 or SE Heads. Would require going a little farther for a correct installation.
Thanks Coupe. That's what I wanted to know. I guess I'll just stay with the TW 6-6 since that has been recommended by Bob Woods for the TG. Thanks also to msocko3.
The Gear
Still getting feedback on the W-6-6, some say it helps, some are not so impressed. I would hate to think we would have to do both to get these dogs off the line a little better and a usable 6th gear.
Have we give up on the gear change or are we still researching! I know it's early yet but was wondering if anyone had found out how involved that change over would be. Since I am not going to do the cams until winter I've got a little time to see which way I want to go.
Either you can go in and DIY it or wait on the R&D by others. Either way doesn't help much right now.
Time is on my side
I was told by one aftermarket rep that his company is making a gear change kit for the TG. He wouldn't elaborate when it would be available and they needed to do further testing. Sorry, I can't divulge who at this time.
Kinda figured you guys were keeping abreast of the trans gear change out!
i have 30t pulley ordered and gaskets, already have tools. ordered last week so should be here soon , will let everyone know outcome after install but think its going to be same as was on my '07 RK/Hack. it takes same parts just dont need to change belt(i hope on no belt change). im running 3k rpm @70 mph 6th gear same as was reported on '11 tri
