Wiring, lights and plugs - Oh my!
Rented a trailer to haul my new-to-me pull-behind motorcycle trailer home yesterday because I wasn't able to figure out a way to connect the 5-wire round trailer plug to my 4-wire flat plug on my Jeep. Backed the Jeep up to the rental trailer, attached the coupler to the hitch, plugged in the wiring (4-wire-to-4-wire) and away I went. Simple. I still have to get my bike fitted with an appropriate hitch, wiring adaptor and isolator for the trailer so I couldn't use my bike to pick up the trailer, but as soon as I install these items I'll be able to hook up the 5-wire motorcycle trailer to my 5-wire Ultra and go. Simple. Not so if I want to tow the motorcycle trailer with my Jeep, or any other tow vehicle other than my Ultra that typically uses a 4-wire plug. Is there a 5-wire-to-4-wire adaptor available out there that would enable me to pull my 5-wire motorcycle trailer with a 4-wire tow vehicle? I've searched the internet far and wide and haven't been able to find what I think I need. Shouldn't this be simple to do, too?
First off, I hate those round plugs...never had nothing but trouble from them. They seem to get loose and end up with a bad connection.
Anyway, I had a shop owned show me some from Car Quest, they are square 5 wat plugs, seal tight and don't come disconnected, never an issue since I started using them.
As for the 5 to 4 way plug I would check with any locat Camping ot Motorhome outfit near you, they should be able to get you what ever you need...I did see these on eBay;
http://cgi.ebay.com/ebaymotors/Wesba...item2eb18788ed
Don't know if this is what you need or not.
As for the bike, get the jumper plug that goes between the rear section of the bike's tail lights and gives you the needed wires for hooking up the trailer. No splicing or cutting your bikes wires and easy removeable for warranty work at dealership....
here's a link to the plug from your trailer company,
http://www.shop.american-legend.com/...4?categoryId=8
Thanks for all the replies/help.
Mike in Wooster, OH
dirtdobber
02-28-2014 03:26 PM
