Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Will a 2002 TLE Sidecar fit a 2000 FLHT?
Old 12-13-2010, 03:40 PM
davet2's Avatar
davet2
davet2 is offline
Default Will a 2002 TLE Sidecar fit a 2000 FLHT?
Are there any special modifications required to fit a 2002 HD sidecar to a 2000 FLHT? Thanks in advance for any feedback, Dave
Old 12-17-2010, 04:26 PM
Ultra 08's Avatar
Ultra 08
Ultra 08 is offline
None if you have the right mounting kit.
Old 12-19-2010, 07:34 PM
davet2's Avatar
davet2
davet2 is offline
Default Thanks
Thanks for the reply, it should be a fairly straightforward installation, I think.
Old 12-20-2010, 05:37 AM
Ultra 08's Avatar
Ultra 08
Ultra 08 is offline
You should try to find a sidecar service manual. It has the installation instructions for mounting, including brakes, electrical and alignment. Good luck!
Old 12-27-2010, 09:03 PM
Noble Jim's Avatar
Noble Jim
Noble Jim is offline
Default Sidecar Service Manual
You can often find these on ebay...or get one from your local stealership.
Old 12-29-2010, 01:01 PM
imac380's Avatar
imac380
imac380 is offline
Stage I
I've got a 1997 TLE mounted to a 2008 Ultra Classic. Worked fine and did the install myself with the instructions that came with the mounting kit from Harley. The only thing I can advise is that you should look into raking your forks to make the steering a bit easier. It's not that difficult to steer but the extra rake would be nice.
Good luck!
Old 01-09-2011, 10:00 AM
davet2's Avatar
davet2
davet2 is offline
Default Thanks
Thanks for all the responses, I did get a manual from an ebay listing and I think it tells me all I need to know. The install should start pretty soon.
Old 01-09-2011, 10:44 AM
Ultra 08's Avatar
Ultra 08
Ultra 08 is offline
Keep us posted on your progress
Old 01-12-2011, 12:11 PM
Double's Avatar
Double
Double is offline
Good luck! I tried picking the brain of a few HD mechanics that has set them up over the years as well so if your local dealer has set any up they might be able to help you out too.
Kozmo
EVO
21
12-14-2017 05:53 PM
KrakkyDoo
Motorcycles For Sale
10-11-2015 05:48 PM
Schaub85
04-08-2010 03:32 PM
KeithB
08-13-2007 10:01 PM
pascowg
07-19-2007 07:25 PM
Quick Reply: Will a 2002 TLE Sidecar fit a 2000 FLHT?
