1990 Ultra Trike
1990 Ultra Trike
I have a 1990 ultra that I have considered putting on a trike kit. My concern is the 80ci engine going to have enough power for a trike. My engine was rebuilt with new .5 over pistions Andrews 27 cam, new lifters, pushrods, Dyna 2000p ign, Dynojet CV carb, K&N air filter.
I wouldn't want to put a trike kit on it and find out it was a dog, due to the smaller engine. Any comments or has anyone already tryed this.
I think you would be able to compensate for lack of power by gearing it different. Changing sprockets. Your top speed will be reduced but Unless you will be drag racing
it it shouldn't be too big an issue.
Or you can build/buy a huge
Cube evo. That may be your best bet. S&S sells them iirc.
Good luck with your project. Don't forget to start a build thread with pics.
I like seeing the trike builds. Some of the innovations guys have to incorporate to make things work can get pretty cool.
Good luck
Good luck
I converted my 1991 FLT with a Frankenstein rear end. It has stock motor with 68,000 miles, ride two up with wife most of time, and have no power problem. Your 1990 already has the lower gearing many later model owners are installing. Be sure and change out triple tree or it will not handle correctly as is.
I have a friend that put a sidecar on an 80 inch EVO. So under powered that he had to go to 100 inch, change gears, etc. and it is still under powered if he runs Interstate a lot.
With the 80 inch he was always in 4th gear. I know the sidecar is heavier than the trike, but you are still going to be under powered, especially two up.
Bill
Bill
I wonder if a sidecar is more of a strain on the engine then a trike body. The sidecar is way off center and being dragged along by the bike. The trike axle is pushing the bike forward, and is where the power meets the road. It is also centered and not such a drag on the entire bike.
Anyone ever own both, and have the answer?????
The trike my wife has is a 2012 with 103 inches, 6 speeds, and lower gearing and while it is quite adaquate, it is not over powered by any means.
An 80 inch needed some work to be really good in a two wheeler, mine had a cam, carb work, air cleaner, and pipes, and it would not have handled a trike to my satisfaction. My 88 inch had pipes, air cleaner, and remap, and it would not have been enough for a trike if you want to run interstate speeds or climb the Rocky Mountains on a regular basis.
Not trying to rain on your parade,but if you are used to a two wheeler 80 with the mods you are showing in your sig, I am betting that you are going to be really disappointed in your conversion unless you go to a bigger engine.
Bill
I built a 74' trike in the early 70's and loved it. I had no power issues.
I just finished a '92 softtail 80" Evo 5 speed., havent gone thru all the gears yet, that will happen Monday. I'll let you know how it go's and if I can figure out how to get the pic's out of my phone I'll post them. :-)>
