Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
new side car, need correct bracket
Old 10-25-2012, 12:02 AM
LoneRock's Avatar
LoneRock
LoneRock is offline
5th Gear
Default new side car, need correct bracket
I just picked up a 2002 Ultra TLE sidecar
I am going to mount it on my 06 Ultra.
It came with "most" of the mounting parts.
Seller said he was told it was previously mounted to an 01 Ultra.
The rear bracket that came with it is a 3 bolt type.. As far as I can tell the 3 bolt rear bracket was only used till 91 or so..
The question is, Where can I find the 2 bolt bracket separately. I believe the part # is 87114-02. My local Harley parts Dealer says he cant find that part#.
Thanks in advance for any help..
Old 10-25-2012, 12:20 AM
LoneRock's Avatar
LoneRock
LoneRock is offline
5th Gear
pic of parts that came with sidecar
Old 10-26-2012, 07:24 AM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
FLTR2008TRIKE is offline
Looking at my 2008 parts book the rear mounting assembly part numbers you need are
87157-87A rear mounting assembly
87159-83 Rod end
87150-02 Stand off
87152-02 Nut
87701-79 Ubolt ( You need 2 )
7775 Locknut ( You need 4 )
87162-01 grease fitting
As per my parts book these are the needed items to attach the rear frame section of the sidecar to your bike frame
In your picture you have the air baffle , the steering dampner, the stabilizer mount that goes between the lower section of the front of the bike frame and the upper connection to the front of the bike frame.
The wiring harness looks to be cut in your picture and the replacement part # 70221-99 page 229 in my book
Unless the brake line is still attached to the sidecar you will need to get the brake line assembly to integrate the sidecar brake caliper to your brake system and the parts book shows a rear brake master cylinder assembly for sidecar equipped bikes that you will also need.
All these part number I found in my 2008 touring models Harley parts book page 218-223
Old 01-29-2016, 03:03 PM
luther's Avatar
luther
luther is offline
6th Gear
Just wondering if you ever found the rear mount you were looking for? I'll be needing the same mount when I attach my side car.
Old 01-31-2016, 10:46 AM
chromepony's Avatar
chromepony
chromepony is offline
Try RONNIE'S HARLEY DAVIDSON.
Old 02-08-2016, 06:36 PM
Lee H. Mann's Avatar
Lee H. Mann
Lee H. Mann is offline
87114-93A is the bracket.
Bob_fxdb
01-12-2020 06:49 AM
Chris Sigo
Shovelhead
11-23-2017 07:17 AM
rdunkin1986
05-04-2017 04:27 PM
jcanrun
08-02-2016 02:20 PM
latnyte
09-12-2014 10:48 AM
Quick Reply: new side car, need correct bracket
