Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Trailer wiring harness
Old 12-25-2012, 01:35 PM
greybeard.3's Avatar
greybeard.3
greybeard.3 is offline
6th Gear
Default Trailer wiring harness
I have a 2012 Tri- Glide, am considering purchasing a trailer to pull behind it. Anyone have suggestions for a wiring harness,trailer hitches,or problems?
Old 12-25-2012, 01:53 PM
bronxbill's Avatar
bronxbill
bronxbill is offline
I have a 2011 Triglide, I got my hitch from www.mchitch.com. Most hitch makers can set you up with the correct wiring harness. I haven't had any problems.
Old 12-25-2012, 04:27 PM
greybeard.3
6th Gear
Thanks,I see you got the rear lift kit . How do you like it?
Old 12-25-2012, 07:43 PM
bronxbill's Avatar
bronxbill
Greybeard,
I really like the lift kit; I haven't draged the pipes since I installed the kit. Also, I think the handling improved since more of the weight was transfered to the front wheel. That's just my opinion, I don't have anything to prove that.
Old 05-17-2014, 03:12 PM
bandjw01's Avatar
bandjw01
bandjw01 is offline
2012 Tri Glide. 5 wire trailer. Rivco Plug-In Trailer Wire Harness for Touring Models. Can't find trailer light plug on my Tri Glide? Can you tell me which plug it is?
Feeling Stupid!
Bob
Old 05-20-2014, 07:41 AM
cochon's Avatar
cochon
cochon is offline
I also have a 2012 TriGlide. I bought my hitch from a dealer on Ebay.The hitch came with a wiring harness that plugged directly in line with the existing electrics. Took only a couple of minutes to install. The hardest part was routing the wires to the back of the trike. I also have installed a lift kit on mine. I consider it a necessary upgrade if you are going to haul a trailer. It brings the rear up a little higher, improves ride and handling. I bought mine from tGlidestuff. The parts were flawless and the customer service was top notch. If you get a lift kit, you might also consider getting the shim kit, that they sell, to level out the TourPack. It kind of completes the look.
Old 05-20-2014, 11:31 AM
bandjw01's Avatar
bandjw01
bandjw01 is offline
Could you give me brand name or part number or even e-bay seller? I found parts by Khrome Werks #720760 but can't find anyone that carries this one. my 2012 Tri Glide has an 8 pin Multilock connector for the rear lights. All I can find have 6 pin Molex connectors? The trailer I bought has a 4 pin flat connector so I have to go from 5 wire on the Tri glide to 4 wire at the plug. I called J&P Cycles and they were unable to help me??? Said they had nothing for 2012 Tri Glide?
Old 05-21-2014, 07:32 AM
cochon's Avatar
cochon
cochon is offline
The hitch that I have was made by a company named Curt. I did a quick web search and didn't find anything offered from them. However, I typed in, "Harley Davidson TriGlide trailer hitch", and got all kinds of hits. The hitch that I bought included a plug in wiring harness that took me from the 6 pin molex to a 4 pin flat connector with no problems at all. Really, it was a snap to install. While I didn't see Curt hitches offered, thar doesn't mean that they aren't available, but I wouldn't hesitate to buy a different hitch from another reputable company either.
Old 06-07-2014, 08:12 AM
bandjw01's Avatar
bandjw01
bandjw01 is offline
To Those interested in Cheaper hitches and trailer wiring for 2012 Tri Glide (should fit all years Tri Glide). I bought my hitch on E-bay for $107. I ordered Rivco part # HD007-12 from J&P Cycles for $26.99 and bought Hopkins Universal 5 wire to 4 wire Converter part # 48895 for 24.95.
The Rivco part has the 8 pin multilock connector to fit the Tri Glide. Then you need to use connectors to hook the 4 wires to the Hopkins converter. The ground wires from each part are put under any bolt on the frame.
No need for a isolation unit if you have led lights on the trailer.
Hope all this is helpful to someone! Took me some time to figure out what to buy and I did order a few parts that did not work Kuryakyn does not have anything for this application. J&P Cycles tech Support was no help, nor was any Harley dealer. After I got the right parts it was easy to install and it all fit nicely under the seat.
My trailer is a Shadow from Mini Trailer USA. Made in Cushing Oklahoma.
Ride Safe and God Bless
Bob
Old 06-07-2014, 08:14 AM
bandjw01's Avatar
bandjw01
bandjw01 is offline
I forgot to mention the Hopkins part came from O'Reilly Auto Parts.
BinIdaho
03-29-2019 04:01 PM
Casper
05-27-2015 07:28 PM
Powderhorn09
01-27-2015 06:16 PM
Powderhorn09
01-26-2015 10:39 AM
RoadHog659
09-14-2012 01:01 AM
Quick Reply: Trailer wiring harness
