Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
2014 Limited Hitch and Wiring
Old 08-31-2013, 07:37 PM
blairsimister's Avatar
blairsimister
blairsimister is offline
5th Gear
Default 2014 Limited Hitch and Wiring
Anyone have any idea about a NEW 2014 Ultra Limited?? Will the existing hitches and wiring work (2009 and up) on the new bike?
Old 09-02-2013, 07:36 AM
madmustang4's Avatar
madmustang4
madmustang4 is offline
I'm picking up a 2014 Limited on wednesday and one of the first things I want to do is hold the hitch up near the bike and see if it will work. My inittial thinking is that it will fit. The bigger issue for me is that I have and Ultra Classic with the rubber bumper on the back, so there will probably be a gap between the hitch and the bottom of the fender. I dont that that gap will impact the hitch, but it will be a gap none the less, so might have to get creative on how to fill that gap. Will give feedback and pics once i get more info
Old 09-02-2013, 11:12 AM
blairsimister
5th Gear
My 14 will arrive in a week, I am coming of a 08 so I need to buy a new hitch anyway.
Also interested in the make that works well with the new frame (09 and up)
Thanks
Blair
Old 09-02-2013, 03:00 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 47,744 Likes on 18,543 Posts
I put a Bushtec ( Pin Type ) Hitch on my 2009 FLHTCU ( I have a Bushtec Quantum Trailer ) and aside from some minor discrepancies with the installation instructions it fit well ... I used the Hidden Receiver Type Hitch along with their Isolator and wiring ( Plug In Type ) harness and it works great.
Old 09-07-2013, 02:32 PM
madmustang4
I have a Bushtec Roadstar and i've used the hitch on my 09 and 12 ultra classics. Today I went out in the garage and held up one of the side brackets to my 2014 UC LTd.
The side bracket has 3 holes that need to be connected to the bike.
It appeared that 2 out of the 3 holes would line up on the new bike but not all three. Im going to contact Bushtec and get their input on how it looks from their perspective. Hate like heck to have to buy a new hitch, but guess ill do what i have to do. Fi anyone has anymore info on the Bushtec setup would appreciate it.
thanks
Old 09-07-2013, 02:57 PM
blairsimister
5th Gear
Let me know what they say, find out if they are modifing their unit to work on all 3 holes.
Thanks!
Blair
Old 09-07-2013, 03:07 PM
madmustang4
will do blair. Im ok with drilling a hole if that will fix the problem and assuming the angles would be correct. Ill take a pic of how it looks and post it
Old 09-07-2013, 04:17 PM
madmustang4
here is a pic of me holding the bracket up to the bike. I just dont see how this bracket can connect to all 3.
If a person could live with just 2 holes, and assuming the angle was ok and assuming the electrical hooks up ok, then maybe it might work.
Attached Thumbnails 2014 Limited Hitch and Wiring-bushtec-3.jpg   2014 Limited Hitch and Wiring-bushtec-1.jpg   2014 Limited Hitch and Wiring-bushtec-2.jpg
Old 09-07-2013, 05:04 PM
Uncle Larry
That was the quandary that I ran into installing the Bushtec Hitch on my 2009 FLHTCU. After beating my head against the wall I contacted Bushtec and they said that the "NEW INSTRUCTIONS" show that the front bolt is not used ... It works fine and I just finished a 4,000 mile trip with no problems what so ever. Properly positioned the bracket should be parallel with the angle of the shock. I should note that I do not have a Quick Disconnect Tour Pak ( I believe that the instructions are different for it ) PM me your e-mail address and I'll send you a copy of the installation instructions if it will help.
Old 09-08-2013, 08:18 AM
Uncle Larry
Here are a couple of pictures. Notice that the top forward hole is not used. This picture is from the left side ( primary side ) of the bike ( 2009 FLHTCU ). Also, behind the bracket ( side plate ) there are two different spacers that mount between the inside of the side plate and the chrome cover that is over the frame. Hope this helps.
Quick Reply: 2014 Limited Hitch and Wiring
