- Time to change the belt?
- Clunking Sounds When Shifting from 1st Gear
- Compensator Oil?
- Primary chain auto tensioner - Replace?
- Primary locking tool dimension.
- Shifting issue
- Charging system on 1988 sportster
- Rear Pulley for 2002 FLHTC Touring
- Compensator bolt question
- How much oil in the primary?
- Sportster clutch slipping??
- A Sad Story About My Compensator Nut and Some Questions
- Compensatornsator for 2001 FLHRI w/S&S 124
- 97 Road King Clutch
- Knock in motor
- Transmission trouble
- Is this a compensator issue?
- Whirl noise
- My shifter fell out?
- drive belt life
- 97 883 clutch bearing
- Baker OD6 Help Please!
- no compensator!!!!
- shift shaft leak
- Clutch pulls hard
- Tranny plug stripped
- 14 1200 custom sporty
- new gasket leaking
- Trans case ## what is this
- Strong clutch basket?
- hot start clunk then slow start
- inner primary case stuck
- Transmission Leak
- I may have finally found my "squeaking" noise (hopefully)
- Need new transmission
- Rushmore gear linkage problems
- deluxe starting problems
- Compensator & Chain Tension
- "Metallic" Grind Randomly on Start - '13 Fat Boy Lo
- Slipped in to gear while doing timing
- Neutral's a bitch
- Starting problem
- 2009 ultra noise in neutral with clutch pulled
- Taping noise when 1st started
- Grinding noise
- Pulley fittiment question
- Evo stator rotor broken at splines
- Ultima belt drive
- clutch cable slack increases as bike get hot
- Clutch diagram spring 1990 sportster
- Lubrication
- Compensator
- 84 xlh1000 clutch help
- Baker DD7
- Clutch issues!
- Downshift issues - May or may not engage
- Leaky Primary
- 08 rear pulley for road king
- 850 mi from home, shifter problem.
- Why was this Thread removed ???
- 2000 dyna transmission mounting bolt spec
- Possible clutch issue, please help!
- Rekluse on bigger motor
- New clutch
- Clutch basket sprocket wear
- 14 Ultra & Evo Industries 49 tooth???
- Compensator what brand & why?
- Darkhorse Compensator
- Clutch Pull Effort
- Loud Screech from front of motor when taking off
- Occasional Dead Shifter 1985 Evolution
- Removing
- How to stop the clunking noise when shifting into first from neutral.
- need clutch help/diagram
- Rekluse Torq drive
- Gear shifter sticking and rough shift
- No Shift Shovel....
- LA Choppers twin peaks 10
- 07 6spd problem
- Clutch for Police use question.
- BDL Primary Issue
- Loose clutch lever on RKC
- Spring rates
- Whining noise during decel
- Clutch upgrade for 116/116
- Heel & Toe Shifter
- Unusual metallic rattle from primary area on acceleration
- Stock cam 2014 -2015 Street Glide Special
- Wide Glide whine in 3rd & 4th gear
- Vibrations at in between 2 and 3 k rpm.
- burnt clutch?
- 01 flstc fixing starter run-on
- Clutch slipping
- Adding electronic speedometer
- '94 Dyna Low Rider puking trans fluid...
- Transmission jumped out of third gear, WTF!
- Compensator?
- Derby cover 1999 evo fatboy
- Loud Clunk on Warm Start
- Rough primary chain
- Burning clutch
- I'm a dumbass
- S&S Electronic Speedometer Calibrator
- No neutral!
- No 6th gear?
- Post Primary Fluid
- First time chain breaker use
- Primary chain measurement...
- 5th gear whine, 09 Road King
- Baker Compensator install on 12 twin cam
- Clutch replacement.
- Clutch not engaging fully and throttle sticking.
- Clutch Question
- 'N' light on in 1st and 2nd, off in neutral
- Baker comp and chain adjuster
- 07 transmission gremlin
- noise in neutral
- the Clutch blues
- More compensator issues
- Inner primary bolt(s) part number?
- Starter Clutch replacement in Bike with Reverse Gear
- Rivera Primo 6-Speed Transmission
- Evo Transmission swap.
- Squealing drive belt at rear sprocket
- Clutch adjustment question
- Shift lock out?
- Primary adjuster PLZ HELP!!
- wideglide tranny question
- Clutch slipping
- Help! Stripped Bolt in Gear Box cover
- Thunk from transmission area when hitting brake?
- Barnett scorpion clutch install
- Triglide axle clunk
- Replace Compensator Springs Only?
- Shifter linkage moves but does not engage gears
- Rekluse clutch's, anybody try them?
- Need more torque
- Yet another Compensator Pulley Thread
- any ideas of what type of friction plates are these???
- 07 FXDB Grinding
- Doh, In a rush n put 1/2 quart of primary in oil
- Which Compensator
- primary
- Primary chain broke
- Primary Case Capacity
- Sprocket Teeth
- Clutch basket question
- Inside of Primary Chewed Up
- 1997 Wide Glide Transmission Problem
- Transmission issue and traveling
- Lost my clutch after taking apart primary
- Slim disengages 5th when full throttle
- Bike jumps a little when starting it up.
- Help! Can't get new SE Clutch to fully disengage
- Weird Primary rattling?
- Primary Clank
- Typical 6 speed transmission life?
- "Clunk" noise when heavy braking.
- Gear oil,engine oil and petrol in primary case
- Freakin' Rattle At Shifter Linkage on 98 RK
- HELP! rear belt 131T and sprocket for FAT BOB
- All balls bearing question
- Foam in tranny fluid.
- 2014 Iron 883 won't roll with clutch in
- Gearing question.
- what makes the Clunk sound putting into 1st gear
- I just got a 72 shovel the other day and I need some advice
- Shovelhead clutch cable install with 5 speed kicker
- Kevlar or Carbon fiber clutch????
- 2002 Fatboy with stock tranny problem
- Changing original clutch at 91000 miles. What to look 4
- Clutch won't engage, burnt oil
- Clutch lever is stiffening
- shovel primary problems
- alignment issues
- 6 speed fitment ?
- 1990 sportster clutch issues
- False Neutral Below 1st gear on 6 speed
- Primary Fill Level?
- Primary fittment help?
- Starting the bike & starter clitch
- Easier Clutch Pull Options
- 2016 FLHR Road King - Slipping Clutch
- Gear set swaps 5 to 6 speed
- Where is Everyone?
- Transmission won't engage
- Replacement schedule for tensioner?
- Motor Trike Reverse - my installation
- broken tooth
- 2008 super glide pulley
- Help with clutch
- Dyna with first gear problems
- Question on primary
- AIM VPC Question
- 1200T bent shifter shaft
- Rebuild Kits
- Inner Primary Bearing Install Question
- 1976 fxe superglide harley shovelhead clutch issue please help
- Questions about belt alignment
- 2015 Dyna Lowrider Strong Vibrations
- bullet proof tc 5/6 speed tranny
- New cables
- Auto Clutch?
- New Baker six speed
- Transmission oil weight
- driveline
- transmission issues
- questions for big power
- Hyd clutch on a RK??
- Touring
- Transmission problems
- Primary cover oil leak
- Questions about the Rivera Primo Game Changer
- Clutch hub removal
- OEM clutch question
- 95 Heritage Softail transmission issues
- Anyone identify this plug?
- Trans locks up in 1st and 2nd
- Torque info (rear axle) Fatboy & Breakout
- Clutch adjustment question after cable change
- oil leak
- Compensator may be bad?
- Rear Pulley ?
- Questions About Transmission and Rear Drive Sprockets
- Bad main drive gear seal? Change tranny sprocket?
- New Primary Chain Question
- This dang clutch
- Gear change
- Metal pieces in Primary Oil
- 10k mile service made my tranny slip in 5th&6th?
- SE clutch spring feel in hydraulic clutch
- 72 FLH kick starter
- New Clutch
- Any options for a cracked inner primary on an 87 Softail? No replacments avail anywhr
- do i have an offset kit on my softail ???
- 2006 Sportster Transmission question
- Shifter linkage - excessive play
- Back Cut gears on a Harley
- MDG Needle Bearing Walked
- Thunderheart Programmable Speed Sensor.
- Cracked evo inner primary
- Speedometer is off after tranny rebuild
- 83 shovel stuck in 2nd
- Primary screw thread size
- Derby Cover question
- Shifter Shaft Seal Leak
- clutch release point changes as it gets hotter
- Right side drive conversion
- 2011 compensator wear. Baker or HD ?
