- 83 shovel stuck in 2nd
- Primary screw thread size
- Derby Cover question
- Shifter Shaft Seal Leak
- clutch release point changes as it gets hotter
- Right side drive conversion
- 2011 compensator wear. Baker or HD ?
- how can i add a kickstart to my 1988 883 standard
- Clutch went out
- Difference in H-D Primary Chain Tensioners
- 03 Dyna trans rebuild
- what trans is this ?
- Softail engine- transmission removed/installed together
- Speedometer Calibration Units
- hydraulic clutch adjustment help
- SE vpc equals which Aim vpc
- Found a small stone in belt, how serious?
- Baker 7
- clutch slipping
- EMD primary cover
- bdl open primary question please help
- Stuck in Neutral
- primo clutch question
- Rekluse EXP issues
- '01 Ultra Classic Hydraulic Clutch Conversion
- Softail Hydraulic Clutch Conversion
- Open Primary Pros/Cons
- Sportster Tranny Question
- transmission leak
- broken compensator bolt. bad news
- stripping trans to powder coat
- clutch noise when engaged
- Vendor Market place
- any builders out there might know?
- pulleys question...
- Stripped bolt
- Reduced effort clutch. A good Mod?
- clutch cable replacement
- 91 Sportster 883 Transmission Removal Help!
- Spark timing affect compensator?
- Clutch Question
- Clutch failure
- Many Thanx to Baker Drivetrain.........
- Reaching Out to Drivetrain.....
- Cost or regearing ?
- Rear Drive Belt Replacement
- Sprocket kits/ Chain drive vs. belt
- 2000 road King with no gears
- Clutch Adjustment Issue - 2007 FXD
- Road King want go
- Neutral light issue w/ Baker N1-OD6
- Compensator failure and lugging. The other reason your comp is failing
- Vibration on deceleration
- Trouble with 3rd Gear
- 2013 cvo clutch
- 2 1/4" Trans sprocket nut
- jackshaft issue
- Bad Clutch Hub Assembly?
- probles with clutch engaged it just goes!
- 2006 Ultra clutch stops working while parked
- Oil change after clutch disc kit install
- Bike won't upshift
- Gearing on old shovel
- reverse
- 2012 Electra Glide Primary(?) noise when Cold
- Clutch Adjustment - Torquing Needed?
- Wet Clutch question
- Trans advice on 01 screaming eagle road glide
- 89 electroglyde clutch inop
- Help. Shifter not resetting
- Belt slip / Stalling under heavy load
- Compensator Install Question
- primary noise?
- Gear change
- softail 2006 outer primary fits 2007?
- Primary Chain and Tensioner Questions.
- Chain upgrade from belt
- 5 speed to 6 speed
- Stock clutch strength?
- Oil pan and cam housing
- Transmission input shaft play
- Baker Special Deals?!
- Can't pull Clutch after belt change
- rotor question
- Baker Comp Question
- Compensator Sprocket nut????
- Something's slipping...
- 2006 dyna primary chain and auto tensioner replace
- Belt change trouble
- Clutch Hub Nut Torque
- 139 tooth Drive belt
- vss question
- Compensator Picture request
- 2006 DYNA Clutch
- Primary Chain tightening 03 Road King FLHRSEI2
- few questions about gear ratios (6spd tans)
- Clutch engages when starting
- Question about Baker OD6 Standard, Optional and R-Ratios
- ClutchWiz AND Muller Power Clutch?? Will it work?
- Shift Shaft Oil Seal Replacement 2001 Sportster
- 25K and need to replace my inner prim bearing and compensator
- Calling Mark, calling Mark@BakerDrivetrain!!!
- 2015 FLHXS 5th gear slipping
- Rattle Can Noise in 6th gear 2007 FLHT
- Different sound coming from primary...
- how to offset primary on a 99 Twin cam runnin wide back tire
- Inner primary removal
- 6 hole derby cover on a 3 hole evo primary
- Shovelhead transmission main oil seal
- 46 to 49t clutch sprocket
- Lock up clutch
- 1994 police special 1340cc automatic trans.
- Inner Primary bearing issue ?
- Synthetic 20W50 in primary
- Leaking clutch cable
- Time for new clutch pack? Which do you prefer?
- Low Oil Level in Primary, FLSTC 1999 Evo
- Oil leak
- A Ghost Click?
- Clutch Pack Assembly
- Compensator replacement
- Baker SBD (Primary Belt Drive for soft tails)
- Somebody help ! 05 deluxe twin cam problems
- trans making noise...no clutch?
- 2007 FSSTSSE Chaincase Leak
- Friction disk
- Excessive
- Clutch assembly- are those 16 rings aligned with each other in particular order?
- 2015 tranny whine
- BDL closed primary drive system 94' EVO common problems?
- Bike will not go into first gear
- Gearing and sprockets??????
- Dd6 & 124"
- Amsoil Sever Gear Anyone?
- 2001 trans road King swap
- Easy derby cover swap... Not. Way to go noob!
- clutch adjustment
- How to check primary oil level
- Primary self adjuster
- Clutch slipping, 4-speed, shovelhead, dryclutch
- Primary chain pecs
- Compensator going out already?
- Compensator Chain Sprocket Eliminator
- Occasional Noise in the primary
- Baker why no N1 ignition kill drum switch for 06+
- replacing my clutch
- Jims Trap Door kit.
- Final Drive Pulley Q
- Pulling in neutral
- Replacing Broken Shifter Centering Spring
- Clutch problems
- Primary Noise - Advice
- Small leak 2010 ultra
- 5 gear or dd7
- Baaaaaaaaaaad sounds under load
- Grey trans oil
- Inner Primary Bearing? It sounds like I put a Pro Charger on my bike!
- Oil leak from BDL open primary
- Clutch Hub and Plates Question
- Baker/Stock trans
- O-Rings for Tsubaki Sigma 530 Chain
- Does low clutch fluid influence the clutch point?
- Clutch Question
- o2 classic
- 2014 harley flhx problem
- Gasket question
- primary
- Where the *$%@# is neutral???
- What thread is the pinch bolt for the gear lever?
- Too much fluid in primary; not enough in transmission
- 06 Primary Leak
- Kicker is stiff all of a sudden?
- 2013 Iron 883 with an intermitten soggy gear lever
- Help with starter ring gear
- Front Brake Chrome Banjo Bolt
- What Would Cause This...?
- Clutch will not disengage gears on 2003 Sportster
- upgrading to a 111"....want to up the gearing...
- 64 mainshaft
- New clutch, anything else I should do at the same time?
- jerky take off?
- bdl open primary cover
- 2012 Street Bob knock in Primary
- locked ramp?
- High Pitched squeal from primary??
- 24t comp sprocket review
- Strongest 14mm x 1" drive belt?
- Now No Clutch!!
- Transmission Drive Sprocket
- Compensator or something else??????
- Pimary Compensator
- Main shaft seal
- Broke a Bolt
- cluch cable
- Clutch Plate Alignment ??
- Clutch Problem
- Howl coming from Primary??
- Shifter Centering Spring Broke?
- Compensator?
- Sticky/ catchy cluch lever after lubing with pb blaster
- Overfilled Primary - HELP PLEASE
- Is Clutch Damper spring seat needed?
- Transmission Compatibility 1997 FXD Dyna Super Glide
- I need educated opinions
- Transmission Q
- Shifter Shaft Question
- Shifter Shaft Seal Removal - Help Needed
- Softail standard floorboards
- Transmission Diagnosis Part 2
- Oil line on '06 FLHT
- Metal chips in Primary fluid
- slight "clunk" on declaration and acceleration
- SE spring installed
- General maintenance question...
- 2007 RK Classic Clutch missing Damper Spring Seat ???
- uestion About D Compensator
- Oil Leak--HELP!!!
- Is it the clutch or ...
- 30T pulley, another belt question
- compensator
- will this inner race bearing tool work?
- Clutch adjustment after bearing replacement
- Best final belt
- Primary issues - need expert opinions
- Quick question about forward controls.
- DYI transmission side door gasket?
- Primary cover bolts
- Primary slack
- whine in gear under load only
- SE vs. AIM Variable Pressure Clutch
- 2010 FLHXXX clutch problems advice needed
- weird slack in front pulley - 07 fxdb
- Neutral light on in 5th gear
- Extra Clutch Plate
- Rear 20mm Pulley swap question
- comp. sprocket
- Trans fluid thinning.... in persuit of the quiet shift
- Driveline Clanking
- pulsating clutch lever
- Installed Baker FF Hydraulic Side cover
- 1990 fxrs selector spring
- 1995 flstn
- drive belt ?
- Help! Fxr transmission
- Primary oh oh!
- '04 Dyna Tranny Failure
- losing power in gear
- 01 harley sportster clutch wont disengage
- 07 Ultra - Primary problems??
- Question regarding primary.
