- Hydraulic clutch adjustment ?
- Drive train lash
- Transmission Identification
- Harley makes grinding noise once motor starts
- Proceedure for starter ring gear replacement
- Diagnose compensator going bad?
- Missing teeth?
- instaling 6 speed trans in a ...
- New Power train Install Started
- new guy from washington st
- Replaced shift shaft, now have primary/power issues
- After accident, bike won't shift out of nuetral!
- Aftermarket clutch plates
- New Baker Black Bully Primary Cover
- Problem Shifting and disengaging
- Slipping 6th gear after cams
- Possible IPB problem
- 5 speed to 6 speed
- custom length primary chain?
- Help! Something happen to my HOG
- baker compensator Ordered
- Bike takes off when put in gear
- Fluid change
- 2015 Street Glide Special and Clutch Wiz
- Shift pedal not engaging
- 83 fxsb inner primary belt
- Clutch drag when hot
- lost all gears
- Side Cover broken bolt
- What is this nut called?
- Drive belt dressing
- One Piece Inner Primary Bearing
- Trouble shifting 3rd & higher
- Switching from Suicide Clutch and Tank Shift to Stock
- Clutch not working
- Primary Chain
- Tranny clatter-Self adjuster, compensator? 2013 Street/G
- Sqeaking sound from primary area
- Great clutch adjustment video
- SE Componsator kit
- Starter pinion gear and clutch shell keep breaking
- SE Compensator?
- Inner Primary Leaking, need advise
- 2014 Deluxe ? Drive Train, Help Me out Please
- trans help
- New 2007 dyna super glide clutch noise
- 04 RG Max Tooth Drop Stock Belt
- clutch engagement are small
- HELP! Found Compensator Nut Completely Loose
- Not good
- Odd Primary Drive Sound
- Thread size???
- frame
- vibration issues with 97 road king
- 1973 Shovel, Clutch, Trans, Kick start??
- 2000 XL883C clutch problem
- chipring
- reverse
- 07 sporty goes into gear but doesnt move?
- Mainshaft bearing removal
- Inner primary seal????
- Another Clutch Question
- Sportster makes grinding noise when pulling clutch
- Locked out of neutral
- Grinding clutch
- clutch question
- Finding Neutral Difficult
- Inner primary bearing help
- How does that pesky clutch cable come out?
- inner primery seal replacement on 91 Tour glide
- Shift Lever Not Engaging While Down Shifting
- Primary Oil Level
- Thick Red Tranny Fluid
- Loosing Clutch
- 1"x 139 tooth drive belt
- Primary Belt Drives????
- 2006 heritage softail compensator?
- primary swap to belt.
- 2000 heritage softail transmission question
- Why would a tranny go out at 41K miles?
- 91 tour glide with Rivera pro clutch slipping after 3200 RPM
- Message to all Revtech tranny owners...
- Transmission drain plug question
- 1988 softail cracked inner primary
- Gearing Upgrade?
- Rattle in IDS
- clutch rod failure
- all balls bearings
- 2002 FLSTF rattle from shift rod lever
- Belt sprocket wobble
- jingling sound in primary after SE comp install
- heel shifter lever loose
- Pressure plate throwout
- Left stranded
- Removing trap door locknuts
- 2000 FLSTC tranny question
- 2014 ultra slight rattle noise from primary case
- Filling primary
- Cracked pressure plate on inner clutch hub
- Can't start bike in 1st *help!!*
- 2006 compensator torque
- Sourcing used drive pulley
- Rear and Trans sprocket alignment questions
- starter trouble
- Starter pinion and ring gear conversion
- Shifter Randomly Locks Up During Shifts
- Torque Setting for Primary Cover Bolts
- clutch cable free play question
- 79 FLH cannot shift into neutral or first
- appreciate a little advise primary
- 2007 Road King Compensator Nut Removal
- Fitment question
- What's wrong with my clutch
- 08 flhtp rear axle comes loose?
- Shovel/early evolution 4 into 5 speed transmission
- ATF with stock clutch
- shifter problem
- At wits end regarding clutch, can anyone assist?
- Main Gear Seal'
- Bert decided to test the Baker Compensator for himself.
- Transmission Identification.??
- Sealant on Primary Gasket?
- New comp install problem........HELP!!!!!!
- Jumping out of third gear
- tranny life
- 1974 ironhead shifting problems
- Finally,what looks to be a viable fix for hd's compensator oiling issue!
- Baker Auto Transmission?!
- love the new Baker compensator! Works great! Pics.
- Tapered mainshaft to splined?? good idea?
- Twisted off DS Cable
- how to drive a speedo on 90s softail trans.
- SE comp with new clutch fluid qestions
- Drive belt size options with 68t pully
- 81 Shovel Pressure Plate question
- compensators
- Sportster jumps out of 1st gear
- won't shift from first to second
- starter issues.
- cant get past second gear after drop
- Primary gasket?
- Variable pressure clutch
- Belt adjustment with 30t front sprocket
- Shifting problems
- New motor, what clutch?
- Clutch Leaking!!!
- Clutch not engaging
- Motor and trans alignment
- Please Help - Clutch slipping since engine build
- Gasket choice
- Baker Primary chain tensioner
- Hydraulic from cable
- Shifter Shaft Seal Replacement
- Shovelhead clutch pushrod
- Need Primary tooth advice
- Baker Attitude adjuster on Limited Low?
- Gearing question
- Bandit primary oil options
- 2007 sportster
- primo 1000a pro clutch install tips
- BDL open belt drive, (sometimes) leaking at sprocket shaft
- Primary chain adjuster
- Need More Clutch Cable Slack to change Lever
- 2015 Derby Covers
- Trans oil in primary?
- inner primary race
- 7K mile HD belt broke
- Why do I get this when i do a search?
- aligning final drive on project...
- Whirring noise on decelleration
- not much adjustment
- PBI Sprocket Set Screw
- 02 Softail Standard oil saturation, tranny/lower end
- Knocking in transmission on sportster
- All balls primary bearing
- 07 RKC whinning while coasting
- Forward to mid controls
- Question on SE 40100061 Compensator
- ultima starter jackshaft ??
- Trouble getting bike into neutral
- Clutch Basket
- Chain conversion and ratio?
- Dry Dyna tranny.
- inner primary bearing? only 1 retaining ring?
- 6 speed whine
- Main shaft socket
- o-ring on inner primary cover
- Should the clutch "slip" on to the tranny shaft?
- Looking for a little better low end with change of pulley
- primary chaincase cover leakage
- Third Gear Slip
- Clutch issue 2008 crossbones
- screaming eagle race clutch
- Breakout clutch exchange
- 2007 Heritage Belt 133 to 131 tooth
- Towing capacity
- 30T Trans pulley change?
- OD6 - N1 Shift drum
- Hey Mark at Baker 95 FXST Question
- decision on primary
- Starter clutch grinding!!
- Primary Fluid Oops
- Primary Cover for a FL
- jack shaft problem
- Instant 1/2 clutch cable slack
- Harley 6-spd transmission
- 1991 FLHTC clutch cable
- Switched to Hydraulic, Adjustment Question
- Shifter play
- Clutch Gone
- lost woodruff key
- 1984 FLHTC Clutch pushrods questions
- Baker High torque bearing PN 189-56
- Stripped Derby Cover Threads and Bolts
- Should I change my cam chain tensioners
- 1986 Softail Clutch Basket needed!!!
- updating FXR4 clutch
- Quality Clutch Hub Bearing
- '93 Below Primary Different from '95 Up????
- Thanks, Y'all!
- My Barnett experience
- Shift shaft bushings ????
- inner primary oil seal
- trouble finding shifter pawl springs
- Clutch Problem on nearly new bike
- Trans/primary torque questions 03 dyna low rider
- 3" Primo Open Primary Leak
- darkhorse compensator
- street on skipping gears
- 5spd 80ci on the hwy
- Sprocket Shaft Oil Seal on S&S for open primary.
- Hayden M6 Chain Tensioner
- chain tensioner
- Sledge hammer vs. Blowtorch?
- 180 rear tire
- fluid servicing 2002 heritage converted to trike
- Wider rear wheel and tire
- O-Ring Dimension
- 2008 Street Glide, 30T pulley and Cruise Control question
- New clutch spring, cable???
- To eliminate or not eliminate... compensator...
- clutch whinning
- transmission noise?
- primary drive questions
- Clutch bearings
- Primary Cases Etc.
- 2001 Road King Neutral Switch Problem. Please HELP
- Clutch basket interchangeability
- replacing transmission seals
