- Help Identify Dyna Primary Part?
- Adjustment of Clutch? - Bike Surges/Jumps forward
- Clutch Not Disengaging after opening primary
- hydraulic clutch for my 98 Fatboy, 124 S&S
- Leak Primary Dyna street bob
- Clutch Dragging on 08 Streetglide
- ultima bullshift 5 speed
- Replaced Derby Cover, Clutch Tension is wrong
- Please take a look
- 86 FLHTC clutch adjustment. Help please
- Finding neutral again
- 2009 sportster 1200 problem
- Starting noise, shut down noise
- Tranny pan thread
- primary gasket bad experience
- primary knock
- dissasembling 6 speed
- Initial Setting of Harley Auto Chain Tensioner
- stripped thread inner primary
- wide tire
- Starter gear keeps getting chewed up
- Shift levers keeps coming loose!
- Trany mainshaft runout question
- stuck in first! shift lever will not move...any ideas?
- Changing Drive Belt on 2001 FXDX
- Open primary thought?
- scrapping noise
- Road Glide Clutch Pack
- 1984 evo fxr dry clutch primary question
- 1986 FXR does it need adjustment?
- Primary Shoe Replacement
- 2003 RKC Drivetrain Issue
- very stiff clutch lever
- 6 speed tranny
- clutch or trans
- Ran Out of Belt Adjustment
- 83 fxrs dry clutch with chain
- Dropped a screw into Transmission... uh oh
- Clutch or Need Adjusting?
- 2000 SE RG comp and chain
- Primary Noise
- Fluids?
- Primary Leak
- Compensator, starter, starter clutch oh my!
- Transmission Bearing Noise
- 06 ultra leaking tranny oil after oil change
- EVO 1340 - front and rear sprocket
- primary locking tool?
- Routing clutch cable on 2011 Street lide
- Clutch not disengaging
- Questions regarding transmission
- Evolution Industries Diamond Terminator Stage 1 Clutch
- Gear locking with four speed transmission 1977 FXE Shovelhead
- starting problem
- belt drive questions
- 08 SG - rear drive sprocket loose?
- 1984 Harley - Drive Issues
- 2009 dyna foward controls
- Late '84 tranny
- sportster 1200 89 transmission
- Noise from Primary
- Drive belt question...
- Bike shuts down when clutch is released after start
- Jim's 6 Speed Trans Top Cover Gasket
- 1991 883 stuck in 5th
- Hydraulics???
- 2009 fat bob primary/tranny
- S/E clutch or the Barnett clutch
- Jackshaft bolt unscrewing itself
- new to forum/ clutch cable/tranny cover
- stripped starter bolt hole
- Home made suicide clutch on a fxr
- Best shifting options
- vibration-at what piont does normal harley engine shaking become cause for concern?
- Primary chain alignment...
- hard shift
- Weird noise when shifting from 2nd to 1st
- 09 FLHTCU Clutch Adjustment
- Tranny case stripped drain hole
- Compensator?
- differently sized dowel pins in aftermarket covers?
- tranny output shaft oil leaks 2004 harley sportster 1200
- Compensator Sprocket bolt backing out
- adventures in leak chasing
- Clutch Hub Failure
- What is WORKING diameter of a 32T countershaft pulley?
- Help identify 5 or 6 speed transmission
- hrome to black gasket sealer or not?
- Chewing nails
- Sqeaky when wet
- '13 clutch bearing gone bad....WTF?
- 2008 Roadking
- Need Help. Missing gears after broken shifter shaft 883
- should never have ordered from Debrix. Help please!
- burned up the clutch help!
- 1999 RK trans issue
- [NEED HELP]Rare clunking noise from Transmission or Clutch?
- Switching from Dino to SYN3 in Tranny
- new clutch,whining and slipping
- Need some tech answers on changing final drive ratio
- Quad seal
- Harley down
- Low-Fling/Non-Fling Chain Lube
- belts and pulleys
- Primary fluid leak!
- Best output gear for an 07 bagger
- Pull MDG seal
- Jackshaft question
- Hear clanging noise on left side of bike.
- Mainshaft wrench
- **My DIY 6 speed tranny rebuild.**
- Bike shivers when taking off
- Baker od6 builders kit in 05 Road king custom
- Drive Belt
- need help finding a clutch cable and lever
- Rear Pulley
- drive belt recommendations
- 2005 Cam Chain Tensioner - Opinions (pics)
- help please.
- best sprocket setup for 65FLH
- primary oil
- primary/clutch maintnace
- Road King Classic clutch lever
- Exile Cycles Open Primary
- Over Drive Tansmission
- clutch perch swap???
- Sealing Cases
- Change Front Sprocket from 32T to 30T?
- Best Primary Belt For Shovelhead ?
- Hayden M6 BT07 Review
- 92 heritage 6speed swap
- missing bearing in inner clutch ramp
- 2006 Street Glide Clutch Adjust Situation
- Inner primary swap
- 1986 flhtc primary cover
- Open primary/compensator
- TC 5 Speed Shifting Between Gears
- one piece jackshaft
- New Ultra 6 Speed
- Broken Fifth Gear
- RSD Chain Guard
- BEST Primary fluid for SE Compensator & Kevlar Clutch
- Primary Cover Gasket installation
- Faulty belt
- Threading New Clutch Cable Into Trans Cover
- First time primary clutch fluid replacement
- Auto tensioner vice manual
- Trans locked, what did I do?
- New cam chain tensioners
- 6 th gear bearing failure
- 73 Ironhead Sportster Project
- Help to overdive the bike
- help
- Loud whine in 4th gear. 02 FXST
- What clutch to get????
- I've come for confession-and a little help. (primary leak)
- Baker 189-56 question
- 84 FXST primary clearance issue
- Torque Specifications for Clutch Mainshaft nut.
- 2011 FXDC transmission case
- Compensator Issues
- Changing to a 6 speed transmission
- Barnett Scorpion clutch kit
- '07 Super Glide Downshifting Issue
- Baker 189-56 bearing question and findings
- Forward Control to Mid Control Conversion
- 01 gearset in a '00 case ???
- 09 fat bob main bearing
- 09 fatbob main bearing
- 1997 Softail clutch issue
- maintenance bulletin
- Clutch Question
- se compensator 42200064
- Starter and Compensator Problems
- Main shaft nut size
- primary leaking from derby cover
- Is 20w50 really ok to use in HD Transmission?
- Changing Out Tranny Pan '07 SG
- RSD Baker 6 speed - any way to convert it to LSD?
- clutch problem i think
- clutch problems i think
- SE Stage 4 Clutch Spring vs. Variable Pressure Clutch
- Andrews? Baker? or someone else
- Slack on primary chain
- Filling the primary
- Nother clutch question
- primary case removal
- Mid controls for a crossbones.
- Removed the Primary, put it back together...annd problems
- belt versus chain?
- 1987 Sportster clutch help Please
- Removing input/output shaft seal?
- Sportster Front Pulley Stripping
- Transmission noise
- Ultima 4 speed
- 2014 Primary Noise?
- Cam chain tensioner...
- Motor to
- Machined Hole in chain inspection cover What The?
- Diaphragm spring
- 2007 softail deuce rear tire conversion
- What is this Chirping sound??
- New clutch won't disengage
- Does this look familiar to anyone? Leaking from bottom of bike
- "whirring" from the rear end
- HD Variable Pressure Clutch
- 03 Sportster shift issues
- Need some advice
- Final drive belt alignment problem
- FXSTD Transmision stripped drain plug
- Lotta new sounds
- HELP 2004 FLHRCI Bad Vibration
- Barnett Pressure Plate removal, damn Loctite....HELP!!!!
- Streetglide is ill
- 4spd kicker
- Main shaft seal replacement? Jims 5 speed
- You guys tell me
- Can't shift to second
- 2011 dyna primary fluid change
- Unusual sound and slight vibration
- Compensator reimbursement Street Glide
- help with noiseproblem
- Noise in the primary
- Primary drive chain
- noise in primary only when I first start out
- Cam washers
- transmission pulley wobble
- How tight should the belt be?
- Drive belt Preference for an Ultra classic...
- Fluid leaking from clutch cable at adjuster/ Primary Vent clogged
- Baker seven
- Open Primaries...
- 6 speed shifter shaft bushing
- 81 FLT Clutch adjustment
- Gearshift thrust washer
- New primary chain adjuster
- 97 RoadlKing clutch replacement repair
- 81 FLT Transmission, Clutch and Rear Chain Oil bath
- thick grey oil
- "Tink"....what the....
- old oil in bike
- Shifter linkage adjustment problem
- 1979 FLH 80 primary help
- Trans issues when downshifting.
- Jackshaft help
- ironhead clutch adjuster
- 89 heritage softail need help primary bolts
- Installing variable clutch ?
- primary
