- Determine actual speed after pulley or size tire changes
- when do you need to change the clutch? Or is it even that?
- 86 Sportster Andrews Transmission End Float
- 1986 Sportster Outer clutch ramp
- how to install a kick start on my 4 speed?
- 30-tooth transmission pulley on 5-speed bagger
- Clutch adjustment questions...!!!!
- 2008 dyna clutch hub nut won't come off!!!arghhh.
- All trans oil the same
- Primary case (inner)
- Taller 1st Gear With Pulley Change?
- chain and speocket conversion
- Shifter Shaft replacement
- compensator nut
- Tire width opinions
- Road King Clutch Trouble
- kicker cover
- R&R Kickercover 4 speed
- Need help ASAP - transmission drive pulley question
- 23 tooth compensator sprocket for 3.42:1 final
- Primary noise question
- starter problems
- laundry machine noise coming from primary case
- primary leak and squeal
- A.r.t. Dominator parts???company info???
- What actually moves?
- 2000 RK 2000 Dyna
- Help...2000 road king/installing chrome cover behind engine
- Can't identify 5 speed transmission
- 1988 FXSTC tranny fitment to newer bike help?
- Transmission compatibility
- speed sensor
- WTF?!? HELP!! New Clutch cable install/oil change service
- 30T/70T Pulley With 48H Cam-Downside?
- Slippage
- 2010 street glide, squiling when its cold
- Replacement Transmission
- Adjusting shifter linkage
- Adjusting clutch
- down shift issues
- Final Drive - Evo/5 Speed
- what would you suggest
- Leaking Primary Fluid
- clutch adjustment?
- help with clutch
- Tranny for 2010 WG
- How to find the correct rear drive belt length
- finding neutral
- Handlebar difference for hydraulic vs cable clutch!?
- 2008 FLHTCU Transmission
- Help - shifter problem
- Shifter shaft splines stripped, heel/toe loose.
- Help!? Clutch problem after crash
- Clutches, Who do you use?
- clutch cable
- Weird "churning" noise
- Help With Clutch Issues Needed
- Pinion shaft gears
- jack shaft keeps coming loose
- screaming eagle Big twin compensator
- reassembly of inner primary parts
- clutch chatter
- Primary problem is....
- Need help with dipstick
- Transmission plug cross threaded
- chain slap in primary
- chain slap
- Curious Belt Movement
- Tranny Leak Help Please
- Oddball clutch challenge
- need help diaging an inner primary leak
- Chain Tension on 1978 Super Glide keeps loosening
- Inner Primary Help Please
- Need help removing inner primary
- Clutch Removal
- Primary Cover heat situation?
- stripped lever at pawl assembly
- clutch issues
- Having a problem with "Them All"
- Leaking inner primary
- Inner Primary
- BDL belt drive
- Clutch Pack Adjustment
- chatter (06 super glide)
- Neutral light flashing
- Compensator spring pack questions
- 1981 fxwg chain and sprocket
- Hydralic clutch issues
- Hayden tensioner
- heel toe shifters stripped
- compensator
- What's the noise?
- Shift Linkage Heims Joints
- And yet another transmission clunking question!
- compensator sprocket
- Clutch issue?
- 3rd gear issue
- Primary Oil Change Help
- shifting issues
- shifting issues
- trans fluid
- compensating sprocket nut
- finding neutral
- oil leaks from primary when ideling
- Primary noise 96 Springer-help please!
- Please help
- Inner Primary
- Whining noise now growling
- New clutch lever
- Noise in primary...Need help PLEASE!
- solenoid installation 87 flhtc
- transmission leak
- Shifting from 2nd to 3rd won't go
- starter pinion gear
- Final drive Ratio parts?....
- The old gear-driven cams vs hydro tensioners question
- Goodyear BDL Falcon belt failures
- Sportster Clutch Sounds Like Marbles
- 99 FLHT Starter problem
- 5th gear change out
- Rant..sorry
- Ultima clutch ?
- Instructions for 06 Ball and Ramp??
- radium 240 kit on 07 night train help
- What's different.
- Stator/inner primary
- Clutch cable adjustment on an '10 FLHX
- 2009 electra-glide gearing change
- 4 speed gear box oil leak from main shaft
- SE 37951-98 HD clutch spring
- new noise /transmision?
- Primary tensioner shoe wear
- 10/40 motor oil okay in primary?
- Clutch issues
- 6th gear hwy trouble
- Noises from the primary
- Clutch upgrade
- 2 clicks from 1st to neutral
- Easier Way to Remove Transmission Plug?
- Sporster rear wheel locked up.
- Excessive vibration puzzle or not
- New guy needs jackshaft help
- clutch cable
- Clutch noise
- Stripped splines?
- Clutch ramp and balls 18 and 21 deg
- New Clutch at 16K on '12 FLTRX???
- Install trans gears
- transmission fluid change problem 99 dyna
- Starter Drive Problems- 1979 FLH
- 81 Shovel
- '03Dyna compensating shaft
- Inspection Cover leaking
- Transmission end cover gasket...
- Clutch Help!
- 07 dyna lowrider
- CLUTCH Upgrade
- time to install baker dd7 transmission...
- FLH Starting/neutral problem
- Another bad compensator?
- Clutch adjustment
- Noise not from motor!!?
- Big Transmission Oil Leak. 2003 Heritage
- In Gear but nothing happends
- Home Engineered Tools
- 1973 FLH BDL belt drive
- Fluids for 2003 softtail deuce 88b
- Another clutch problem
- No more starter grind????
- need help with transmission
- shovel nose cones....how to tell...
- throttle cable help
- Wont shift!!!
- Tuner wouldn't tune my bike because of bad compensator...
- not the same old clunk
- Transmission Info
- Primary Alignment help
- Help!!!!!
- son's 883 sporster
- John
- 1980 FXE 4 speed tranny parts
- Driveline Feels like it is jumping a tooth on the belt
- Six speeh tran and cruse problem
- Primary Alignment question
- IDS will it help?
- Should a main shaft bearing be noisey?
- Ring Gear, Pinion Gear devourer
- Sprocket/Pulley change ???
- Secondary drive belt
- Shifter shaft or Main seal???
- 79 xls Tranny Sprocket
- '87 FXSTC - Primary Drain Plug
- compensator question
- Chain Case Overfill Issues, maybe???
- 1988 solenoid plunger boot
- Baker Frankentranny kick start
- Softail Evo Tranny Knock
- barnett scorpion clutch install
- Gearing Questions
- What is the normal sound
- Deceleration at 90 mph
- Deceleration chirping noise
- shovelhead ratchet top transmission
- Clutch Hub Bearing failing
- 2012 sportster 48 rear pully/sprocket.
- cant pull clutch in
- 05 Sportster Shifting
- Final Drive Belt Question
- clutch not releasing evenly, catches
- Overdrive options
- Tranny repair. 1st timmer
- Twin Cam upgrade
- Still Leaking
- 4th & 5th gear problem on 07 FLSTF
- Clutch adjustment
- 2004 FatBoy cruiser swingarm removal!
- run away softail
- Harley 6 speed
- dd7 with 120r motor in 2007 flhx
- Pre-2006 Clutch Pull
- Shift rod lever removal
- To engine brake or not to engine brake
- Primary Chain case leak
- Question for you wrenches out there
- Shift lever slipped off the trany (TURQUE?)
- Drive belt too tight
- 95 Softail Trans Problem, need advice
- Screaming Eagle VS AIM Variable clutch
- 04 sporty clutch prob
- 06 FLHX Unknown Objects fall from Primary
- Clutch
- torque spec.
- Trouble down shifting
- 02 transmission noise normal.
- What type of screw does Harley use on my timing and primary cover
- starter grinds
- Clutch basket/drum with gear
- Primary Fluid Leak?
- Clutch basket and bearing '09 FXD
- Can I use an 02 up touring trans on an Evo 98?
- primary oil level
- shifter linkage to Trany on '08 Road King
- Main Drive Gear Bearing Removal
- evo softail chain tensioner
- shifting problems
- SE Compensator & Hayden Tensioner Replacement
- clutch pack rebuild
- transmission oil change
