- snapped bolt in transmssion outer case
- transmission skipping
- Clutch Cable Replacement Troubles
- Cover removal...
- Cover removal...
- Cometic or James 5 hole derby cover gaskets?
- clutch plates
- out of wack clutch?
- I'm going into the primary, what should I replace?
- 75 ironhead gearing
- Changing Primary Chain Questions
- Clutch Slipping on 1995 FLSTC
- Primary Chain Slap
- 94 1200XLH trans
- Transmission and clutch fluid question...
- Clutch cable
- Silicone sealant on O ring?
- drive belt warranty
- changing inner primary on 83 fxrs things i need to know
- kickstart
- Clutch adjustment issues
- help with clutch adjustment on 1990 FLHS
- Primary chain slip?
- One-time use pulley bolts?
- when to change trans fluid
- '08 FLSTC Shifting Problems
- Clutch Removal 2009 Fat Bob
- Attempting oil seal repalcement, help
- Ultra overall gearing
- Speedo inop after DD-6 install
- Metal shavings?
- issues with 06 dyna street bob trans
- Slight rub/fray on my braided clutch cable
- FXSTS Clutch Diagram 1989 Springer
- make your own gaskets
- Help needed on changing clutch lever
- Clutch cable seems "stretched out" after Clutch adjustment.
- 5th Gear Mainshaft Seal - How To Remove?
- Compensator and clutch question
- belt to chain conversion help
- need recommendation on new trans
- right hand side oil leak
- 2010 RK / What's the size of the clutch lock nut?
- Engine Difference Question?
- main shaft length/hub width.
- Who's Using Race-less Inner Primary Bearing?
- Compensator won't stay tight
- flhtk 2010 primary noise
- Ratchet shifter position
- 1967 Clutch Problem?
- Question about 07 Ultra Auto Tensioners
- Cant get to neutral
- 4Speed Clutch Rod Question
- Can't keep balls in place
- Chrome gearcase swapout
- Speedo error correction!!
- softail primary cover
- Ran Road King with little trans oil
- Help with 2009 Dyna Primary
- Clutch cable issue on 11 Heritage
- Secondary drive help
- Stripped torx
- adjusting clutch cable on 08 nightster
- clutch cover leaking; helicoil??
- '78 Shovelhead lurches
- Need Help With Gearing I borke Another Belt And Im Going Chain Drive Please Help
- drivebelt question???
- 78 steelhead lurches
- I dunno question!
- ?did the easy method clutch adjustment?
- Stripped splines on shift lever shaft
- just adjusted clutch easy method!
- 07 softail clutch issue
- Shifting problem/False Neutral/No Neutral Indicator Light
- To gear down or not to gear down?
- 1990-1997 clutch bearing play
- Transmission cover bolts
- inner primary bearing
- For all you clutch experts?????
- Need help to identify this part???
- Metal in primary
- torque spec for 94 fxr clutch
- Transmission crossover
- blowing fresh oil
- Baker Torque Box
- need help identifing transmission
- Clutch-Pack lock nut dimensions?
- If you just losen the Clutch cable do you then have to ajust it?
- Chrome Inner Primary Swap
- shovel comp sprocket
- Diaphragm Spring and Spring Plate
- I'm no chemist but......
- 6 speed?
- belts.?
- mechanical speedo drive conversion to electronic?
- Evo 1340 with Ratchet Top Transmission
- aftermarket shifter cover
- Diaphram Spring Pressure?
- Drive Belt - Pulleys too?
- 1992 fxlr.
- is this a major problem?
- Help with a pimary leak
- HELP replacing clutch plates
- Dyna249...Street Bob
- 3.37 gearing on 99 FXSTC....????
- Water in transmission oil
- Fatboy Clutch (cold)
- Need help identifying clutch??
- Separating clutch hub from shell-Arbor press
- clutch cable leaking oil
- Drivetrain project help needed
- Overfilled primary
- FXD main shaft bearing race
- Shifter fork shaft set screw removal issue
- clutch doesn't work when engine is hot
- Cam Bearings from Fuel Moto??
- clutch hub bearing
- Cam sprocket Torque?
- 1997 road king have shifting problems
- Rear belt too close to exhaust pipe
- shifter problem
- 1955panhead
- Primary cover removal...
- Broken drive belt...again
- IPB on an 05 Softail Springer
- Screamin' Eagle Compensator in an 05 Softail Springer?
- Clutch ramp issues ... maybe
- 1/2 or full turn
- 2009 Softail Gearing
- night train open primary drive belt?????????
- CLUTCH push rod
- 68t rear pulley
- 68t rear pulley
- SE Compensator and Oil Grooves
- clutch hub
- main shaft seal leak 98 heritage softail classic
- Problems shifting from netural to 1st
- No fifth gear
- 5 speed tranny clutch
- Ring Gear replacement
- Name that noise...
- Clutch
- Compensator nut and clutch nut torque for 2007flhx
- Possible clutch noise question
- HD Evo Transmission Questions
- Clutch Life
- compensater spring tension. 03 fatboy
- Transmission top cover Gasket
- primary under pressure
- Andrews 30T Question
- clutch adjustment problems
- Transmission oil leak.
- Clutch
- Is this normal on a clutch plate.....?
- Have you ever seen this kind of damage....
- clutch issue during reassembly clutch buffers?
- dyna twin cam clank then white smoke
- Wont go into neutral at idle
- 6 Speed trans Swap - Whole Case or Just Gears?
- 97 883 transmission removal
- shifter wont spring back
- Whining 4th gear Road King 2006
- Inner Primary- Special Tools?
- Removing primary cover
- primary chain tensioner
- primary noise when warm
- first harley
- whats going on with my heritage springer at higher RPM?
- 2003 fatboy oil
- Any “tricks” to reset the ball ramp?
- Starter replacement on 07 FXSTC
- primary chain adjustment
- Indian Trike
- Help, Please! Hit Snag. Size of Clutch Hub Nut?
- 06 FLHX - motor making noise?
- Help
- Should I replace the Starter?
- 06 Dyna Street Bob ... griding trans?
- noise in primary
- anyone tried 40287-07 compensators
- Delayed neutural indicator
- SE compensator
- Sticks in third when downshifting
- Automatic Primary Chain Tension Adjuster
- Hard shifting
- copensator sprockets
- Clutch Bites It
- Belt question with new 30t
- 2000 RK "Historical" error code question
- 1977 shovel primary/trans questions
- Changing Primary drive spockets
- pulls while starting (clutch lever fully in)
- engine light coming on
- Unidentified clutch parts
- Creating an Open Primary on an Ironhead...?
- 6 gear ratio change
- 82' Shovelhead FLH Belt size?
- Ideal cruising speed for 2001 fxsti
- Compensator
- '95 sporster shifter issue
- Clunk When Engaging 3rd Gear
- Real head scratcher! Pics
- Sticky clutch on 883
- Clutch out of adjustment ??
- Evo with a 4 speed kickstart??
- Cam Kit
- Roller Bearing 5 Stud Clutch Hub?
- FLD switchback heel toe shifter? unicorn part?
- Changing gear set
- No neutral/can't upshift at stop when hot
- Removal Inner Primary
- Shifting/clutch issue
- Rear pully/sprocket broke !
- losing alot of tranny fluid?
- Reverse shift pattern
- TwistGear anyone?
- push rod for clutch
- pulley?
- 92 motor crate motor and 5 speed in rigid making noise
- clutch problem
- 1999 Dyna Primary
- Stater ingagment
- How do i adjust my '85 flh clutch
- Probably a stupid question, but here goes.
- Is it an Evo or a Twin Cam?? (primary)
- Reduced effort clutch?
- Inner Primary Transmission Mainshaft Bearing?
- Clutch Feathering
- Losing compression
- oil from crankcase breather
- shifter went limp,
- Wear in side my primary?
- After 1K, 2011 Ultra Clutch Binds
- primary case oil
- im stumped....
- I need HELP on my primary cover
- 01 1200 sporty lower end whirling,squeeling
- transmission
- 03 Sportster Tranny Squealing
- Cam question
- Need a little help identifying an enclosed primary belt drive
- Drive line trouble--shuddering
- Help ID this rear wheel sprocket
- Rivera Primo Pro Clutch TPP Installation Snag
- Would a 2011 Ultra limited 103 have...??
- riveraprimo 6-speed gear set
- bike shakes below 1500 rpms
- stalling and whistling from my primary
- Leaking!!!!arghhhh
