- Easy Pull Clutch Update
- Clutch will not engage! please help.
- bike wont shift into netural hile running
- ULTIMA 6 speed trans failure........
- buell tick
- Sounds like a turbo on decel?
- hope someone can help
- Transmission gear not returning
- Clutch pack slipped when adjusting. Softail wants to die into 3rd gear now.
- 6 speed trans on a 2001 FLHTC 95
- shifter not returning to neutral position after shifting
- Compensator noise ???
- trans plug
- Inner Primary?
- Acceleration pulls slack out of clutch cable
- Counter shaft threads
- ok help me out here, 2000 sportster
- Trans question
- Transmission poping netural
- In need of tranny help
- Conversion 5th spur to helical?
- down shifting problem
- 4 speed rebuilds?
- ATF in primary
- clutch cable install question
- RPM Calculator
- Need help checking my primary chain tension.
- Clutch Line
- 75/140 full synthetic gear oil in trans
- transmission leaking into clutch
- Need order of installation.
- se 6 speed
- .900 offset sprocket hits inner primary
- Tranmission upgrade questions
- 78 fxs clutch problems
- Broken Flywheel tooth....
- stuck in first gear...help
- SE Heavy Duty Compensator
- FLHX GearBox Chatter
- Power Clutch/Easy Pull Clutch
- Import aftermarket chrome primary cover
- Primary drain plug problem ...
- clutch or Trnay problem?
- Primary Cover question
- 03 Dyna Transmission diagram
- Alignment question
- primary oil
- Why is the transmission pulley so wide?
- 30 Tooth Pulley Debacle
- Open Primary: Please Educate Me
- 6 spd Transmission questions
- Compensating nut size?
- Clutch Engage vs Lever Position
- Powdercoated belt pulley teeth
- 31T or 30T install costs
- Re-Tapping Primary Derby Threads
- Vibration in 4th gear, 08 Dyna Street Bob
- Vibration then broken belt?
- Primary noise
- neutral or 1st...does it matter?
- neutral-first...does it matter?
- Powder coating Resevoir top ?
- SO nice to have the bike back together, but...CANT GO ANYWHERE! NO GEARS!
- Stator plug
- 5th and 6th gear problems
- Bearing Squeel
- Too much oil and leak on right side
- Crankshaft Repairable?
- Spacer between compensator / rotor - required?
- Motor oil question
- Why a chain primary verses a belt?
- Softail clutch problems
- 2003 Road King Drive Belt - How many teeth?
- Looking for a good clutch
- whining sound from belt
- Is this normal for the 1000 mile service?
- My super smooth Clutch not to smooth anymore
- Whaaaa?
- one-piece inner primary bearing - having a hard time getting it to fit over mainshaft
- Inner Primary Bearing
- When loosening trans bolts...
- Loss of gears
- Starter ring gear / pinion gear - how should they mesh?
- Belt chewed up
- Barnett Carbon Fiber Vs. Kevlar?
- Hard shifting problems 06 FLHTCUI
- striped out the foot shifter on 05 dyna SG
- shifting into neutral
- 4 speed kickstart conversion
- putting new belt on
- Clutch release plate retaining ring size
- swapping out clutch and brake lines
- Question about RKC clutch
- Shifter Shaft Oil Seal - does this one look like it's leakin?
- 30 T Pulley - Andrews or Ultima
- primary cover gasket
- Rear Belt adj.
- Timer Cover Screws size
- fitting an e-z clutch
- Baker 6 speed push button switch
- belt drives
- Clutch issues.
- Andrews 30 T 2003 RK w/ 6 spd gearset
- Any difference in same length clutch cables?
- Green fluid 2004 wide glide?
- how to remove inner primary on 2006 flhpi-road king
- how to put a new belt on?
- wheres the hole
- Hauling sound from primary Evo 97.
- 99 EVO How much primary fluid?
- Clunk In All Gears
- Clutch balls / Clutch problem???
- Since the inner primary is off...
- Wise or not wise
- cpensator sprocket or crankshaft?
- Loosen trans/ engine when removing inner primary?
- Gear box problems.
- Pink Goop!!??
- Bagger Transmission Oil Change Links No Good?
- Lighten Counterbalance weights on B Motor
- Oil Pump and Sumping
- Starter / Solenoid Clicks Won't Turn over
- Transmission Oil
- What will and wont fit an FLHT?
- 92 Herritage tranny drain
- Back again with more questions...
- ultima open primary
- Changing gear in primary
- transmission and primary oil
- which compensator
- primary oil level
- Improper Andrews Trans Sprocket Installation?
- need advice on where to order a custom clutch cable asap
- Pulley tooth count
- Primary Drainplug Magnet
- Excessive play in shift linkage
- Tool Needed
- verttical nurl adjustment
- Final Drive Ratio change - Pulley swap
- pulley compatability
- Starter ring gear chewing up inside of primary
- Checking Tranny Fluid!!!!!
- '05 Dyna Super Glide Can't Downshift
- 07 dyna 6 speed in 06 softail 5 speed case ?
- Troubles with clutch
- Main Drive Gear Bearing
- Tranny locking..
- Whats in my tranny?
- 883 converted over to 1200 can i paint my inner primary?
- Main Drive Gear Seal ?
- Age impact on Belt Drive?
- Need help finding out why Neutral is gone
- clutch recommendations?
- Shifter Shaft seal other numbers
- Clutch issue (All of sudden, it was gone)
- IPB case dowel pins, 06 Dyna
- clutch/tran issue after oil change
- HB Wedge
- Not Friction - Clutch Steel Plate Thickness
- Clutch Thickness
- Eastern VA riders - 2-1/4" deep socket?
- belt primary lunging ahead
- shift lever
- 72 FLH Tranny Oil
- Buell Blast Primary Cover Removal
- Tltrievel@hotmail.com
- 75w/140
- What clutch to use?
- Which Trans Oil Kills 5Th Gear Whine?
- Primary oil change (different issue)
- road king wound tight
- Clutch Problem 09 Sportster
- 09 Dyna tranny into 06 ultra?
- primary clunk while hard breaking
- Easy Pull Clutch for Softail
- Solid Compensator for 07 Softail?
- Clutch cable replacement
- Neutral light comes on slowly
- Spacer Behind Sprocket
- 09 motor and trans
- Drive Sprocket Nut
- Thinking of installing electric easy shift kit
- Clutch cable
- Cable clutch vs hydraulic
- Bdl belt rives
- Primary Noise
- Softail 180 Conversion
- Oh No!! IPB Failure: 07 FLHX...???
- 1987 FLH Clutch Problem
- Throwin belts help
- Inner primary off
- Hard shifting 06 Ultra
- RedLine Trans oil
- 6 speed transmission on a 2007 Ultra
- problems with my 86 FLHTC trans
- Replace clutch with Hammer & Chisel?
- Transmission speedometer drive
- Transmission lube
- Clutch Spring Tension
- Need new Clutch!
- Primary noise
- Inner Primary Bearing Race - I NEED HELP
- Freeplay in Rear Sprocket
- noise from primary
- Sucking fluid!!!!
- Over shift pawls
- 06 dportster noise
- Interchangeable Compensator Sprockets
- oil dripping
- outer primary gasket
- Clutch Basket?
- Help finding my Tranny oil fill/dipstick
- 97 Road King Shifter/Tranny Problem
- primary chain
- broken clutch cable replacement
- Aggresive Clutch
- Speedometer swap from '04 up to '03 older?
- Tranny sproket worn & belt Question
- Did I mess up? Primary adjustment?
- Drive chain problem
- Primary Chain too tight w/ Auto Tensioner?
- Final drive belt/ rear sprocket
- Baker DD6 Install
- Little bit upset.......crack in Primary Cover
- Rev Tech 4 spd. leak
- Tranny quit engaging; makes horrible noises
- WLC tranny question
- i need some info
- Screaming Eagle race clutch problem
- Primary drive noise
- Help with 6-speed gear set selection
- Release cover leak
- Barnett Scorpion clutch??
- Kick start on an EFI???
- 2008 Dyna Fat Bob, steering lock pushed in and key stuck
- Inverting tensioner?
- 1984 fltc
- Primary Drain Plug
- Changing primary lub
- Final drive multi-fit
- Six Speed
- Baker Shift drum?
- hydraulic clutch advise
- transmission sproket
- clutch cable melted
- Primary chain help
- need help with locking engine sprocket
- need help with my jockey shift install
- 83 FXRS Clutch Issues?
