- Transmission pulley swap
- Starter Noise Warning!
- 76 Harley FXE Shovelhead Dry Clutch
- Adjuster screw
- 2009 Road King Engine Trouble
- Primary Bearing Race....34091-06 or -08
- Leaking Primary on '09 Ultra
- Axle Nut Size?
- Trouble finding neutral..
- trouble engaging second gear
- Derby Cover Problem
- clutch won't engage
- Fisher Damper
- Clutch Help on a 96' Heritage.
- transmission bearing for a 6 speed gear set?
- Clutch plate replacement question
- Shovelhead Clutch Overheated
- Where to buy heim joints?
- clutch inspection cover
- Removing transmission sprocket nut - use torch?
- Clutch not working
- Tranny whine
- Transmission Fluid Leak - I don't know where
- 2000 sportster rattle
- Shifter Shaft oil seal (behind inner pri)
- Strange sound after switching to RL MTL
- Remove outer primary on 07 Wide Glide
- 08 RKC Speed Sensor Oil Leak
- Teflon clutch cable?
- six speed swap
- shifter arm loose
- Re-use the red gasket?
- primary clutch or trans noise?
- FLHTC tranny leak input/output shaft oil seal
- pulley shaft seal
- clutch pack lock nut
- Bearing noise
- 75 shovel rocker clutch jockey shift Help!
- Excessive chaincase noise 2003 FLSTC
- Replacing a drive belt on '06 Street Glide
- 2006 roadking trans fluid
- to change sprocket,transmission
- torq spec for the bolt that holds the heel toe shifters????
- Questions on removing clutch hub nut
- New Road king-Primary Noise?
- Sticky shift lever
- 2005 Sportster Clutch is Stiff/Tight
- 69 Iron Head clutch adjustment
- How in the H3ll did Harley get away with that!?!?
- screeching noise
- Compensator Carnage!
- Clutch Cable Adj Moving:
- barnet clutch tension
- Clutch Lever/Cable adjustment
- Clutch problems
- primo brute v on 07 fxst?
- Question on turning over engine by hand - with picture
- 1989 ultra clutch adjustments?
- Motor oil in the primary case?
- hydraulic clutch question
- Inner Primary leak.
- will it fit? pulley ???
- Clutch Cable replace ?
- Venting on the primary case?
- Final drive belt. Aftermarket or Harley?
- Switched to severe gear?????
- Has anyone upped from a 5 speed to 6 speed?
- Gear case bolt torque
- ez clutch
- clutch hub play
- Need help....
- Automatic primary chain adjuster
- something musta broke??
- Extension Kit for Mid Controls
- slipping in fourth
- slipping
- High pitch "whine"
- '07/'08 FLH IDS pulley
- fgall4355
- Can anyone tell me
- 99 Evo Softail - Primary Chain Rattle at Startup?
- Clutch Cable Clicking?
- Offset plate question
- Crazy things happen while out on the road.
- Any Sportster Clutch Guru's around?
- jockey shift kit 07 fxdb
- Need some help here...please! Clutch adjust.
- open primary question
- 08 IDS bearing problem
- Tranny main shaft oil leak?? Little long
- Getting off clutch release plate
- Clutch release plate
- update on sloppy clutch problem
- clutch slipping
- gaskets
- Primary / Stator Job
- Thr deaded 5th gear sound
- Help - I messed -up
- Inner and Outer primary cover removal
- What clutch and how to adjust
- does clutch need adjusted
- Can't understand what's going on with my clutch
- primary chain tensioner
- clutch lever went sloppy
- Transmission Sprocket need an answer soon
- Mileage
- primary case oil
- clutch replacement
- Primary Drive Removal - Tools needed
- transmissions and clutches
- Clutch adjustment 08 FLTR Road Glide
- Clutch problems need help
- Any tranny masters around tonite?
- Pulley,belt
- Wobble in Clutch Hub Assmbly
- '98 FXDL Clutch Problem
- Is my clutch adjusted properly?
- Neutral light stopped
- should this be happening?
- belt and pulley
- Clutches
- clutch on 1986 softail
- Noob tranny question
- '84 4-speed tranny
- Stator, Rotor problem
- Oil leak question????
- '97 XL 883 problems
- In Search of a 2005 Transmission Housing/Case
- Leaking main seal on 4 speed trans
- shifting problem
- EZ Clutch Problem
- bike has difficulty shifting gears and going into neutral
- Twist throttle, revs but dont jump
- Andrews 30 tooth drive gear and belt breakage...
- Final drive pulley
- 4th gear whine
- Jackshaft removal??
- noise in drive train
- 20mm BELT AND 1" REAR PULLEY
- 07 Dyna Primary case leak
- Trans Leak?
- What's wrong with my bike?
- 66t to 72+
- clutch removal troubles
- skill level to replace?
- 65t pulley vs 70t causing my belt squealing?
- Rear Sprocket
- Nylon guide on primary chain tensioner
- Red Line Heavy in 08 street glide
- 1995 Heritage Tranny Drain Location
- Shorter Belt Length
- Gets stuck in neutral
- How to check trans oil?
- Problems with Neutral
- Synthetic Oils
- Noisy engine when hot
- High Perf Clutch spring
- Suddenly shifting got hard....
- Oil leak from switch?
- Clutch Replacement
- Baker DD6 Tranny
- Thunder Mountain Baker 6 Speed Failures...
- clutch adjustment - can't get 1 1/32 inch clearance
- 06 dyna wide glide
- engine noise advice
- dyna 24t sprocket
- Clutch inspection cover
- Clutch Adjustment (Again!)
- Knocking noise in tranny
- 30t front sprocket how to?
- putting in gear loud klung
- Clutch noise
- home made mainshaft nut wrench. photo
- adjusting clutch
- Clutch doen't work
- DD6 install
- Going from 3rd to 4th.
- clutch question
- Removing Clutch Plates
- Clutch problem?
- Clutch problem?
- Revtech neutral Problem
- How the heck to get compensator nut off?
- Hard Clutch
- 07 dyna primary
- 2005 sporster shifting problems
- 84 Low Glide drive train leak
- Stuck in second gear
- Starter spits out jackshaft bolt
- Adjusting drive belt on 08 dyna SE
- Transmission Fluid Leak - Shift Seal?
- ate starter gears again
- Squeal from clutch/primary on decel
- 1986 softail HELP
- Any other suggestions, shifting problem 93flstc
- 4 speed to 5 speed change over
- 2009 softail custom noise
- 30 Tooth Trans Pulley
- Changing Clutch Cable
- 94 wide glide shifter fork check
- broke belt put new on ?
- Beating the 6th speed topic to death
- shifting problem? return spring?
- 35,000 Mile Service
- Just got a 95 wide glide
- ATF in primary
- What year is this tranny??
- Primary Leak
- 2007 5th Gear Ultra Clatter
- Fyi
- Tranny Noise Coasting in First
- Winding noise coming from my kicker cover
- I get nothing
- Inner primary seal for starter shaft
- 3" install on a suicide shift NT
- Clutch chatter
- 06 twincam milage estimate?
- Transmissiong Dipstick
- fxr clutch release cover
- changing the rear sprocket
- 89 ST clutch?
- Changing the compensating sprocket and chain
- Clutch Cable replacement 08 Road King
- 07 Softail Trans clunck
- "Buzz" in first gear
- Tranny internals case swap
- 97 Road King shifting issues
- B & M TRICKSHIFT ATF fluid
- Jimmy shovelhead
- Clutch Removal
- 2000 883 Countershaft leaking?
- 5 Speed Tranny Bearing replacement
- 09 Rear Pulley change out
- recess in or out on fxs front sprocket ?
- Clutch rod stuck, need help.
- Hydraulic clutch problem
- shifting trouble
- Removal of Transmission Trapdoor
- Should I or shouldn't I???
- 03 night train slapping sound fron the left
- Any help ? On Speedo ?
- Ratling between second and third gear...
- changing gearing
- Speedo stops working
- Tranny drain plug washer
- Shifter Spring assy 2003 Fatboy "HELP"
- Missing Identity of Harley 4 spd...Can you help it remember?
