PDA
View Full Version : Primary/Transmission/Driveline/Clutch
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
  1. Compensator going out already?
  2. Compensator Chain Sprocket Eliminator
  3. Occasional Noise in the primary
  4. Baker why no N1 ignition kill drum switch for 06+
  5. replacing my clutch
  6. Jims Trap Door kit.
  7. Final Drive Pulley Q
  8. Pulling in neutral
  9. Replacing Broken Shifter Centering Spring
  10. Clutch problems
  11. Primary Noise - Advice
  12. Small leak 2010 ultra
  13. 5 gear or dd7
  14. Baaaaaaaaaaad sounds under load
  15. Grey trans oil
  16. Inner Primary Bearing? It sounds like I put a Pro Charger on my bike!
  17. Oil leak from BDL open primary
  18. Clutch Hub and Plates Question
  19. Baker/Stock trans
  20. O-Rings for Tsubaki Sigma 530 Chain
  21. Does low clutch fluid influence the clutch point?
  22. Clutch Question
  23. o2 classic
  24. 2014 harley flhx problem
  25. Gasket question
  26. primary
  27. Where the *$%@# is neutral???
  28. What thread is the pinch bolt for the gear lever?
  29. Too much fluid in primary; not enough in transmission
  30. 06 Primary Leak
  31. Kicker is stiff all of a sudden?
  32. 2013 Iron 883 with an intermitten soggy gear lever
  33. Help with starter ring gear
  34. Front Brake Chrome Banjo Bolt
  35. What Would Cause This...?
  36. Clutch will not disengage gears on 2003 Sportster
  37. upgrading to a 111"....want to up the gearing...
  38. 64 mainshaft
  39. New clutch, anything else I should do at the same time?
  40. jerky take off?
  41. bdl open primary cover
  42. 2012 Street Bob knock in Primary
  43. locked ramp?
  44. High Pitched squeal from primary??
  45. 24t comp sprocket review
  46. Strongest 14mm x 1" drive belt?
  47. Now No Clutch!!
  48. Transmission Drive Sprocket
  49. Compensator or something else??????
  50. Pimary Compensator
  51. Main shaft seal
  52. Broke a Bolt
  53. cluch cable
  54. Clutch Plate Alignment ??
  55. Clutch Problem
  56. Howl coming from Primary??
  57. Shifter Centering Spring Broke?
  58. Compensator?
  59. Sticky/ catchy cluch lever after lubing with pb blaster
  60. Overfilled Primary - HELP PLEASE
  61. Is Clutch Damper spring seat needed?
  62. Transmission Compatibility 1997 FXD Dyna Super Glide
  63. I need educated opinions
  64. Transmission Q
  65. Shifter Shaft Question
  66. Shifter Shaft Seal Removal - Help Needed
  67. Softail standard floorboards
  68. Transmission Diagnosis Part 2
  69. Oil line on '06 FLHT
  70. Metal chips in Primary fluid
  71. slight "clunk" on declaration and acceleration
  72. SE spring installed
  73. General maintenance question...
  74. 2007 RK Classic Clutch missing Damper Spring Seat ???
  75. uestion About D Compensator
  76. Oil Leak--HELP!!!
  77. Is it the clutch or ...
  78. 30T pulley, another belt question
  79. compensator
  80. will this inner race bearing tool work?
  81. Clutch adjustment after bearing replacement
  82. Best final belt
  83. Primary issues - need expert opinions
  84. Quick question about forward controls.
  85. DYI transmission side door gasket?
  86. Primary cover bolts
  87. Primary slack
  88. whine in gear under load only
  89. SE vs. AIM Variable Pressure Clutch
  90. 2010 FLHXXX clutch problems advice needed
  91. weird slack in front pulley - 07 fxdb
  92. Neutral light on in 5th gear
  93. Extra Clutch Plate
  94. Rear 20mm Pulley swap question
  95. comp. sprocket
  96. Trans fluid thinning.... in persuit of the quiet shift
  97. Driveline Clanking
  98. pulsating clutch lever
  99. Installed Baker FF Hydraulic Side cover
  100. 1990 fxrs selector spring
  101. 1995 flstn
  102. drive belt ?
  103. Help! Fxr transmission
  104. Primary oh oh!
  105. '04 Dyna Tranny Failure
  106. losing power in gear
  107. 01 harley sportster clutch wont disengage
  108. 07 Ultra - Primary problems??
  109. Question regarding primary.
  110. compensator locking tool
  111. 30 68 pulley 07 softail
  112. Transmission 4 Speed
  113. Help finding compensator motor sprocket for Evo TP/SS 107 motor
  114. What in the world can cause this to happen???
  115. 09 heritage classic 10k miles noise from front of bike
  116. trans problem in 2003 electra glide ultra classic
  117. Hydraulic clutch adjustment ?
  118. Drive train lash
  119. Transmission Identification
  120. Harley makes grinding noise once motor starts
  121. Proceedure for starter ring gear replacement
  122. Diagnose compensator going bad?
  123. Missing teeth?
  124. instaling 6 speed trans in a ...
  125. New Power train Install Started
  126. new guy from washington st
  127. Replaced shift shaft, now have primary/power issues
  128. After accident, bike won't shift out of nuetral!
  129. Aftermarket clutch plates
  130. New Baker Black Bully Primary Cover
  131. Problem Shifting and disengaging
  132. Slipping 6th gear after cams
  133. Possible IPB problem
  134. 5 speed to 6 speed
  135. custom length primary chain?
  136. Help! Something happen to my HOG
  137. baker compensator Ordered
  138. Bike takes off when put in gear
  139. Fluid change
  140. 2015 Street Glide Special and Clutch Wiz
  141. Shift pedal not engaging
  142. 83 fxsb inner primary belt
  143. Clutch drag when hot
  144. lost all gears
  145. Side Cover broken bolt
  146. What is this nut called?
  147. Drive belt dressing
  148. One Piece Inner Primary Bearing
  149. Trouble shifting 3rd & higher
  150. Switching from Suicide Clutch and Tank Shift to Stock
  151. Clutch not working
  152. Primary Chain
  153. Tranny clatter-Self adjuster, compensator? 2013 Street/G
  154. Sqeaking sound from primary area
  155. Great clutch adjustment video
  156. SE Componsator kit
  157. Starter pinion gear and clutch shell keep breaking
  158. SE Compensator?
  159. Inner Primary Leaking, need advise
  160. 2014 Deluxe ? Drive Train, Help Me out Please
  161. trans help
  162. New 2007 dyna super glide clutch noise
  163. 04 RG Max Tooth Drop Stock Belt
  164. clutch engagement are small
  165. HELP! Found Compensator Nut Completely Loose
  166. Not good
  167. Odd Primary Drive Sound
  168. Thread size???
  169. frame
  170. vibration issues with 97 road king
  171. 1973 Shovel, Clutch, Trans, Kick start??
  172. 2000 XL883C clutch problem
  173. chipring
  174. reverse
  175. 07 sporty goes into gear but doesnt move?
  176. Mainshaft bearing removal
  177. Inner primary seal????
  178. Another Clutch Question
  179. Sportster makes grinding noise when pulling clutch
  180. Locked out of neutral
  181. Grinding clutch
  182. clutch question
  183. Finding Neutral Difficult
  184. Inner primary bearing help
  185. How does that pesky clutch cable come out?
  186. inner primery seal replacement on 91 Tour glide
  187. Shift Lever Not Engaging While Down Shifting
  188. Primary Oil Level
  189. Thick Red Tranny Fluid
  190. Loosing Clutch
  191. 1"x 139 tooth drive belt
  192. Primary Belt Drives????
  193. 2006 heritage softail compensator?
  194. primary swap to belt.
  195. 2000 heritage softail transmission question
  196. Why would a tranny go out at 41K miles?
  197. 91 tour glide with Rivera pro clutch slipping after 3200 RPM
  198. Message to all Revtech tranny owners...
  199. Transmission drain plug question
  200. 1988 softail cracked inner primary
  201. Gearing Upgrade?
  202. Rattle in IDS
  203. clutch rod failure
  204. all balls bearings
  205. 2002 FLSTF rattle from shift rod lever
  206. Belt sprocket wobble
  207. jingling sound in primary after SE comp install
  208. heel shifter lever loose
  209. Pressure plate throwout
  210. Left stranded
  211. Removing trap door locknuts
  212. 2000 FLSTC tranny question
  213. 2014 ultra slight rattle noise from primary case
  214. Filling primary
  215. Cracked pressure plate on inner clutch hub
  216. Can't start bike in 1st *help!!*
  217. 2006 compensator torque
  218. Sourcing used drive pulley
  219. Rear and Trans sprocket alignment questions
  220. starter trouble
  221. Starter pinion and ring gear conversion
  222. Shifter Randomly Locks Up During Shifts
  223. Torque Setting for Primary Cover Bolts
  224. clutch cable free play question
  225. 79 FLH cannot shift into neutral or first
  226. appreciate a little advise primary
  227. 2007 Road King Compensator Nut Removal
  228. Fitment question
  229. What's wrong with my clutch
  230. 08 flhtp rear axle comes loose?
  231. Shovel/early evolution 4 into 5 speed transmission
  232. ATF with stock clutch
  233. shifter problem
  234. At wits end regarding clutch, can anyone assist?
  235. Main Gear Seal'
  236. Bert decided to test the Baker Compensator for himself.
  237. Transmission Identification.??
  238. Sealant on Primary Gasket?
  239. New comp install problem........HELP!!!!!!
  240. Jumping out of third gear
  241. tranny life
  242. 1974 ironhead shifting problems
  243. Finally,what looks to be a viable fix for hd's compensator oiling issue!
  244. Baker Auto Transmission?!
  245. love the new Baker compensator! Works great! Pics.
  246. Tapered mainshaft to splined?? good idea?
  247. Twisted off DS Cable
  248. how to drive a speedo on 90s softail trans.
  249. Starter pinion gear
  250. SE comp with new clutch fluid qestions
