- Belt to chain
- Notching
- Bendix gear retracts when starting - 1976 Shovelhead
- Compensator wear -- what am I looking for?
- 2014 limited howling noise
- Primary fluid smells burnt
- Clutch Problem after new friction plate install?
- Is my clutch slipping?
- Baker Sales Tech Banned on HDForums?
- 2004 Swift Chopper Primary Tick
- trap door bearings / mainshaft walking
- Screaming Eagle Friction Disc Kit
- 3rd gear shutter under load.
- locating torque specs
- 2015 clutch cable help
- Main Shaft Gear won’t Budge
- Replace Inner Primary Bearing with Clutch?
- 4 speed gearbox
- Am I being cheap? Replace or refurb
- Anyone Recognize This Squeaky Rubby Noise
- Clutch won’t fully release with correct adjustment and oil level
- Self induced primary case leak
- Primary Fluid or Trans Fluid....
- Bike creeping with clutch in. slipping while riding
- New comp and chain - chain hitting cover
- Primary Oil seal not seating… help!
- Rocks rattling in the primary,, Barnett clutch?
- Shifting Diag help
- Possible broken shifter pawl spring?
- Anyone recognize the maker of this 2" primary?
- Bonehead move during clutch replacement
- EZ pull clutch kit…
- 6 speed swap
- Heeeeeelp
- 2003 Fatboy Sqeaking noise
- 2021 Road Glide Ultra Noise Primary side of the bike ...
- Starter
- Main shaft leak
- Clutch problems
- 2017 breakout 103..can the gearing be hanged
- Clutch/trans issue?
- Stuck clutch pushrod
- 88 softail loss of clutch
- 5 speed delayed clutch engagement
- Not sure what problem is
- Harley 45 to newer Harley electric start transmission
- Hard Shifting
- Whining noise
- Removing Trans Gearset...What else...
- Shifting issue only when passenger is on back.
- Speed Sensor Symptoms
- Primary belt noisy
- Drive belt tension questions
- Bel Ray Hypoid Gear Oil v Big Twin Transmission Oil
- Custom clutch cable
- Clutch engagement is off somehow
- Reinstalling 6 speed gear set after side door bearing fix
- 2007 RKC transmission Question
- Frustrating Clutch Issues
- Clutch
- Stripped clutch pack release plate
- Hydraulic clutch not disengaging
- Manual V/S auto primary chain adjuster 2016 FXDB
- compensator
- IPB Race Clearance
- New tensioner?
- 5th gear jump out
- M8 touring models, Transmission pan torque specs
- Retaining ring size
- Cannot find neutral after replacing clutch cable
- Transmission woes
- 2018 fat boy low 3rd gear slipping under rpm
- What else can a bad compensator mess up?
- New clutch cable: not enough free length to put lever back.
- Cause of missed shifts?
- Acceptable side play on shift paw?
- Stiff Shifter
- Transmission main shaft leak
- 2001 883 Hugger
- Clutch/primary noise
- remote starter button
- Drive Belt Deflection
- Offset transmission sprocket
- School me on reverse gear
- M8 compensator wear limits
- Replace M8 Softail Outer Primary Cover
- Transmission/primary questions
- Side Door Bearings Replaced, Now Gear set Won't turn Freely
- Primary or Transmission grinding under throttle
- '09 Dyna Clutch Hub
- Shifter linkage bushings not lasting
- Clacking Noise From Primary?
- Gears slipping
- Closed-End Countershaft Bearing Leaking Primary Fluid!
- Primary Drive Locking Bar
- MDG Issues
- Clutch wear
- Is my Transmission bad?
- 2009 FLHTC Electra Glide Clutch Crusher
- Gmr Compensaver
- Baker High Torque Inner Primary Bearing Feels Gritty
- 2004 Sporster Clutch not working and not starting
- Clutch basket removal
- Clutch won't disengage after changing drive belt
- Upgrade For 37707-84A Clutch Basket
- Motorcycle stuck in gear
- Stripped drain plug
- 1972 Shovelhead hand shift problem
- compensator
- Stock compensator replacement.
- 5 speed changing ratios on 4th and 5th
- Baker 6speed in 2002 FLHRCI
- Clutch lever delete kit
- Primary and Transmission fluid mixing
- Mathmatical speed calculations
- '87 883 Sportster Transmission Oil Vent Line
- Derby Cover Bolts
- 1981 shovelhead
- What did I do/how do I fix it/popped clutch
- Transmission bearing gone bad
- Shovelhead tin primary w/ rotary top?
- Trans slipping???
- Primary Cover Replacement
- "Clanky" Shifting
- Transmission issues?
- '87 883 clutch cable replacement
- Transmission fluid
- Jackshaft Oil Seal R&R
- 2009 Heritage stator plug leaking
- Evo lock up clutch
- Lube Tranny leaking behind inner primary
- Clutch question...
- crashed and yet to fully burn
- continuation of the welded pushrod saga
- Rear Sprocket Bolts - NEAR SERIOUS ACCIDENT
- 2021 Touring Clutch Cable Replacement Source
- Easier Clutch Pull 2021 Sport Glide
- What’s wrong with this picture?
- Clutch hub woes. 2007 softail heritage custom
- clutch issues
- Pushrod welded together
- Release Plate Movement with AIM Actuator
- Changed speed sensor.....
- M8 clutch shifts weird
- Ratchet top issue
- Clutch threads broke inside cover! Help
- Re and re 5 speed countershaft bearing without specialty tool
- Clutch pack adjuster backing out
- This chain real
- Silver primary oil
- Replace stator, rotor, and compensator
- Fatboy 114 hard clutch lever
- Crank runout
- SE High Capacity Clutch Plate (Part# 37000258)
- Oil line leaking
- 2003 belt alignment
- primary cover without inspection hole?
- 5th gear seal
- Primary Oil Quantity and Level
- Pulley Fitment
- Help needed with TC88 - 95" clutch upgrade
- clutch release cover
- Debris in primary
- Lube clutch cable?
- primary
- Jack shaft seal questions
- Transmission Case Compatible
- Rub mark on inner primary
- 2006 dyna automatic primary chain tensioner
- Dark Horse Man O War?
- Harley Primary Oil - WFT !!!!
- Transmission neutral light
- Primary cover
- Primary cover
- 02 Ultra Classic clutch won’t work when dropping into 1st gear.
- Rear pulley question.
- SE Style Comp. Springs Still Lose Tension
- Reverse issues on Tri glides
- 5-Speed shafts out of aline
- M8 Clutch Question
- Rekluse vs AIM vs Muller
- 2016 Harley Ultra Limited Lunges forward on startup
- TC88 Compensator upgrade?
- 1985 FXWG Inner Primary Removal
- Any gearing suggestions for this setup???
- Baker DD6 with an S&S 124??? (Kinda urgent)
- Derby Gasket question
- Not accelerating in higher gears
- Clutch adjustment help needed to change the engagement / friction zone
- Reverse gear on 5-speed Evo
- coil spring vs variable pressure plate?
- Pushrod
- 1980 FLT inner primary
- help. bike wont hold a clutch adjustment/wont/hard shift
- Oil Leak 2020 FXLRS
- Could I screw up a Rekluse clutch install?
- SE or Barnett Clutch Spring...
- Evolution Industries Stage 1 Clutch
- Can I use the M8 Pulley 32T to my sportster?
- Starter bendix source
- Clutch hard to pull
- leak from transmission
- Clutch Cable Jacket Wear
- Inner clutch basket fretting
- Rear Pulley size 14 Deluxe
- Getting new drive belt...what else??
- Transmission mainshaft
- woohoo bt's are fun
- Transmission main gear sprocket removal
- M8 Clutch: Adjusted clutch, but then changed clutch cable to shorter. Do I need to re-adjust the clutch again?
- Help chasing a clutch creep issue - 2015 RGS w/approx. 78K miles on ODO - hydraulic clutch
- Shifter shaft from transmission
- Bolt Problem
- 2018 Low Rider lackluster rear brakes
- Clutch spring or new discs?
- Transmission drive pulley removal
- 1984 fltc 5 speed Evo with chain drive
- Left hand foot clutch
- Clutch adjustment problem.
- sprocket size
- '05 Fatboy 95"--Which compensator to use??
- Clutch basket removal??
- Primary Cover 60685-07A
- Replace small trans output shaft seal
- 2005 Softail Deluxe Clutch basket won't come off?
- Trams fluid help needed
- 2006 Deluxe 5 Speed shifting rough until hot.
- Metal flakes on primary drain plug
- SE Comp rattle
- Looking For Primary Case Cover With Inspection Access Opening
- Help with 86 Transmission.
- Right side shifter shaft, left side shifter.
- Big Twin Compensator - 42200064A
- sportster shifter pawl replacement
- American Prime Comp master Clutch Review
- Clutch wont disengage
- Inner primary drip
- Starter venting primary oil
- 1998 soft tail custom with a full s&s upgrade
- 2019 Ultra Noise primary side of the bike
- D.I.D. 530VGC-SO Pro "O" ring chain
- Gearbox Identification
- 84 FXR 1340 evo Vehicle Speed Sensor Location
- Hydraulic clutch cover - '82 FXR
- Metal flakes in tranny oil Noob question
- 3/4" or 1" 2018 Softail deluxe
- Final drive suggestions
- Another belt ratio question
- 2006 SH help
