- Rear Drive pulley Question
- Clutch and comp upgrade
- 2000 Electraglide not moving when in gear
- Gearbox issues
- Slick 50 in more then the oil case?
- Can't upshift from 2nd gear
- Primary Bolt Snapped
- Rear sprocket question
- 89 Springer Softail Dry Clutch Problem
- Unidentified Part. Just replaced clutch cable.
- Clutch Help
- 18 slim trans drain plug
- 82 Ironhead
- Inner primary rebuild question
- transmissions
- Dark Horse Compensator
- 2008 Fat Bob - to much Primary fluid
- Auto / electronic shift help?
- IDIOT - Most expensive burnout fail
- Lock Inner and Outer Clutch Hubs on M8
- For those worried about using gl5 gear lube in your tranny
- '83 shovel ratchet top issues
- Shifting when hot
- Clutch setup issue
- Clutch question
- Bummer Day
- Quad seal fit?
- Rekluse Manual Slave Cylinder
- Can't depress clutch handle
- Primary Shoe
- What the hell is going on inside my primary ?
- Evo dyna clutch issues
- 5 Sp Softail trans into Dyna
- Slip Ons or Full Exhaust
- Clutch adj question
- 19 slim trans drain question
- 02 sportster 883xl
- Can’t upshift at high rpm
- Rattle in primary after installing new stator
- Clutch won't disengage
- Inner primary 2000 FXD SuperGlide
- Aim clutch
- neutral switch
- Baker 6 Speed DD6
- I changed the Primary fluid and used Dexron VI ...
- Clunking noise in primary diagnosis
- Clutch for 124"
- Installed 30/70 pulleys and now have an issue
- Is this normal?
- Whining Primary
- Old style 5 speed to ball and ramp?
- Oil leak behind inner primary case.
- Comp Master 6 Speed Transmission
- EVO Engine/Trans (Driveline) Swap HELP !!
- Oil puddle under rear drive pulley
- Clutch stop disengage on FLHRC
- 2016 FLTRXS Shifter shaft issues
- Stuck clutch hub
- Clutch issue after motor build
- Rekluse clutch and Baker Grudge box?
- chirp sound from primary SOLVED
- sprockets?
- 5 speed for 69 XLCH
- Mainshaft Oilseal Problem
- Chain Size For 27t Engine Sprocket???
- Clutch dragging?
- 6 speed transmission skipping 3rd gear
- Clutch basket bolt spacer snapped ?
- 81 shovel starter problems
- 2000 Flht issues....
- Took off primary- can't tighten clutch cable enough
- Help with Sportster 883 starter!!
- Hydraulic clutch kit manual 46448-05 or 05A
- Transmission Sprocket...cosmetic?
- Transmission cover/ exhaust hanger bolts
- Which side ??
- Short throw clutch lever 2020 softail?
- Shifting into 2nd issue
- Went to 12” t bars and now clutch doesn’t engage
- Did a clutch pack change, now engages when kicked into 1st
- Iron 883 bent shifter shaft
- Anyone tried this comp?
- Timing and Tranny Cover
- detent screw access
- compensator sprocket
- Issue with changing clutch fluid on 2017 Road King
- Barnett lock up clutch
- 1998 Transmission With a Plastic Level Window
- 07 SG comp probs?
- Inner primary case wear
- Stuck tranny oil drain bolt....On Jims tranny
- And to all a good night!
- Clutch Hub Replacement 03 Road King
- Using a M8 comp on a TC? Might be possible.
- Cant push in gear with clutch pulled
- Barnett 303-30-10019 extra plate clutch install 2017 RGU
- Compensator Spring Pack Pressure
- Which would you recommend, Baker or Hayden Primary Chain Adjuster.
- 2006 streetbob trans compatability
- 7 Speed Transmission Upgrade
- 77 fxe speedo cable
- FXR Transmission Cases (Differences)
- Spacer
- 18 street glide 150hp blowing transmissions
- 1st 2nd gear grid
- 86 Sportster Transmission problems
- 2019 street glide clutch problem
- Primary belt & pulley
- Longtime clutch issue
- welp that happened..........trans toasted
- Ultima 6?
- 1st gear concern
- 2005 Electra glide classic main shaft seal
- 2009 Street Glide Shift Lever Oil Seal
- Will not downshift to 1st after stopping.
- Soaking clutch plates
- 2018 6 speed transmission
- No down shift to neutral or 1st at idle
- starter issues
- 2013 Heritage Sloppy Second Gear
- Baker Drivetrain Workshop 12/7/19
- Primary Issue? or not?
- 1970 sportster questions
- Sprocket cover missing piece.
- Broken exhaust bracket stud in transmission side door
- 1982 tranny swap
- Clutch disc life
- Healtech Quick Shifter
- final gear ratio help
- Kickstarter not straight up
- Transmission ID
- Oil temperature
- Baker Drivetrain is alive and well!!!
- Baker redesigned their compensator
- Baker smooth shift kit
- Shovelhead open primary
- 2001 Ultra Cycle Fatpounder
- Trans fluid burn resistant?
- Clutch Adjustment with AIM VP
- Anyone have experience with SE Clutch Friction Disk Kit (PN: 37980-10)?
- 84 fxr, how to remove inner primary?
- Helicoils in the primary case bolt holes
- 91 Softail Custom Gearing
- Easy fix for primary leaks
- New Clutch Cable
- Barnett scorpion problems
- Periodic gear grind from first gear into second ?
- Six Speed Tranny Noise 2015 103 Freewheeler
- main gear puller/installer
- Clutch cable
- -rear wheel alignment
- 124 S&S motor and type of tranny question
- Inner clutch hub damage
- Clutch Finger Release
- 2011 Ultra Classic Trans
- Ultima gear set with baker mods
- Transmission swap
- Clutch job from hell
- 4 to 5 speed swap
- Light force slave cylinder
- shovel clutch basket
- S&S 124/Rivera Primo clutch
- Baker Compensator Install on 09 Fatboy
- 97 sportster shift fork shaft retaining ring?
- Belt rubs against tire on reverse
- HD ROAD KING CLASSIC inner primary cover reinstall
- Compensator noise? .. Lube?
- 2016 103 6 Speed issue clutch lever stuck
- My baker comp finally arrived.
- Sportster 94 - 5 to 6 gears transmission
- Where is the drain plug on Revtech Tranny?
- Transmission problems
- rusted derby bolts?
- Shift paw spring swap
- How to service the hydraulic clutch?
- Clutch Issue
- Get in the Grind with a Harley-Davidson Six-Speed Transmission
- HD 5 speed vs 6 speed
- 2007 streetglide 6 speed fit into a 2014 Dyna FXDB?
- Missing 2nd on upshift finding neutral instead
- Shimming jackshaft on bdl ques.
- baker driveline
- New clutch cable super hard pull
- Clunk when braking
- Kevlar vs. Carbon fiber discs
- Neutral is tight. I think i damaged something
- Transmission ID help
- Dyna clutch noise and engagement problems
- Final drive belt tracking off of front pulley
- 11 FLTRX Main Shaft Slop
- Clunk sound from primary
- Hydraulic Clutch to Cable Clutch
- Need Some Advice
- Mainshaft play 2002 fxdwg
- Primary noise.
- Harley 6 speed tools
- Primary????
- My tranny just wasn’t up for it today...
- New softail has less than 400mi on it..Got a bolt stuck in the pulley and damaged my belt
- Broken clutch safety switch
- Installed forward controls
- Champion Mechanical Reverse
- M8 trans doesn't want to downshift
- starter bang
- Tranny oil leaking under outer primary cover
- Front drive pulley spline blowout - ?causes/prevention?
- Quick clutch question
- Shift shaft seal leakage issue
- Confused on what part goes on inner primary starter hole..
- 9 or 10 tooth starter jack shaft for EVO setup?
- Clutch diapharm color code
- 2012 flhtk
- Baker Compensator after 30,000 miles (estimated)
- In gear no movement!
- OEM auto chain adjuster
- Does anyone have information about primary chain tensioner issues?
- Clutch adjustment wierdness.
- my 85 FXR clutch not disengaging
- Old parts unknown
- Which spring is this and what HP can it hold?
- Baker Options For 1989 Evo
- Starter gear gets stuck on clutch basket..... sometimes!
- 5 speed evo over drive?
- Tranny problems
- Big problems
- 09 Ultra Clutch and other issues after replacing handlebars
- '07 King not shifting
- Jam bar lenght for 09 primary
- '97 XL1200s Lost all gears, help diagnosing
- miss in 3rd gear or surge
- Clutch recommendation for modified motor
- Baker compensator wait times
- Motor-to-gearbox transvission
- Replace the clutch basket, too?
- Dynojet quickshifter
- Lost all torque until it just stopped moving.
- Tranny dipstick question
- Internal Primary Leak
- Transmission oil is there a difference?????
- Primary grinding sound
- Thick primary gasket
- Engine swaps
- Compensator eliminator , afraid to ask
- Stator, tensioner and SE Compensator installed without Torquing 2007 Fltr
- 2018 FLHTK Transmission Issue
- New Clutch cable\shift rod...now shift lever stays down
- Transmission? Bike is not going into gear.
- Trans to Primary Oil Migration on M8
- Since I have to change my compensator
- Quick clutch question.
