- Thumping when riding
- Transmission problems
- In need of different compensator
- Clutch recommendation request
- Need help .
- 03 FLH Transmission Leak
- Shift shaft Seal Part# ??
- Charging Problem
- Clutch's
- EZ-Clutch
- Help identifying noise with video
- No longer hard to find neutral
- Beat grease for shifter spline.
- Brand new 2002 clutch slipping ??? Help please
- Jd transmissons help
- Primary fluid level
- Primarycase Noize
- 2003 Fatboy vibration
- Shifting issues
- 883 Sportster
- Down shifting issues
- Why the rear drive sprocket bolts fail.
- Dyna Inner Primary to Engine/Trans Alignment
- Won't shift 2014 Iron 883 just got it.
- Compensator wear
- Stuck in 6th
- Hydraulic Clutch Adjustment
- Howling/grinding noise from trans
- New bars now clutch cable sticking
- Foot clutch
- Transmission gears 2012 FLHT & FLHTP
- Primary gasket
- comp. spring broken??
- Primary chain
- C clip
- 2000 deuce transmission
- Rattling/Clanking @ 2-2.5k rpm
- road king 2003 belt uneven wear
- Clutch Cable Extender?
- Ping noise just got worse. Help needed.
- Open Beltdrive
- Starter. Clutch release sensor
- Primo motor plate + BDL drive
- 89 Springer transmission issues
- Torque specs
- Very frustrated, please help
- Inner primary bearing replacement?
- 2014 Transmission Compatibility
- Losing Primary Oil
- Primary chain noise "maybe?"
- Front pulley floats
- Surge forward when shifting into first after new build
- Ratio changes between 94 and 2000
- Improve your hydraulic clutch engagement!
- Muller Power Clutch
- Clutch adjuster nut stuck
- Rekluse Clutch and Noise
- Revtec transmission noise
- 2009 street glide atrter ring gear removal.
- 2009 street glide starter ring gear removal.
- Cracked transmission case on '04 Harley Davidson Road King Custom Trike AGAIN
- Screamin Eagle compensator install
- Primary compensator/clutch tools 2010 softail
- 2019 Fat Bob clutch problems
- Transmission Fitment On A Softail Frame
- 2019 Road Glide Clutch Issue
- Clutch slipping after 128 build
- Ultima 6 speed
- Primary clutch or trans knocking noise
- 09 fatboy clutch questions
- Love Jugs? Cooling jugs?
- Engine out of a 08’ crossbone 96ci
- Which way to loosen the nut?? Softail Deuce 2002
- 2013 fltrx issue
- Shudder from primary in neutral. Clutch handle released.
- Tranny question
- Clutch adjusting screw too short!!
- Hard Hit on First Gear after Changing New Clutch Cable
- starter locating pins
- What spacer for Timken conversion on 07 FLH?
- Transmission Question
- 1984 Softail Foot Clutch Conversion
- What color is formula +
- 2015 CVO A/S Clutch....will the SE high capacity fit?
- TC 88 Compensator
- Whistle Primary side
- Derby cover screws.....
- Clutch Lever Buzzing
- Noise and "surging" on deceleration.
- 07 FLHX Derby cover/outer primary sizes??
- Dsr1
- IDS drive pulley flht
- Starter problems
- ***NEED HELP*** Primary guts
- 2010 FHLX gearbox noise on jiffy stand
- Hayden primary tensioner 2001 roadking classic
- 2019 Softail Compensator Sprocket Failure
- Andrews adj push rod problem
- 2015 883 iron won’t move in gear
- aluminum shavings in my primary
- Shovelhead not engaging clutch
- Low Rider S Primary Question
- 1999 Roadking slipping in second and third question
- 2003 RK shift shaft seal leaking
- Dragging after adjustment
- Barnett scorpion Headache
- Ultima OD6 speed left side transmission question
- What are the differences between IPB 9231 and 9135?
- Primary chain slack after baker attitude adjuster 2009 heritage
- Sportster dies when letting off the clutch
- Shifter Problem
- 1990 sportster drivetrain swap
- 96 FLSTF shifter falls forward and back
- Clutch change over...
- Clutch won’t engage.
- New Member seeking info
- Final drive belt question
- Drive belt alignment 2009 heritage
- Does an open primary make shifting smoother?
- 2000 Red Horse Chopper Starter/Pinion Gear/Ring Gear issue
- Primary side noise
- 6 Speed for 1990 FXR
- compensator noise 2008 Elecrta Glide UC
- Push rod adjustment
- Iron head transmission work
- Chunks in primary
- Replacement derby cover bolts with hex head
- New clutch
- 2009 FLSTC comp sprocket bolt #3368
- clicking noise when clutch let out
- 1998 Custom Sportster Anniversary 1200cc Clutch release plate explosion
- 6 Speed Reverse gear set
- 05 heritage softail classic- compensator nut fixed but now runs like c**p
- Bandit clutch hub
- 5 speed transmission interchange for 1990 softail
- Cam install
- Another primary issue.
- 2013 fatbob fluid changes
- Replacing clutch cable
- Main Drive Gear Inner Seal Naming Conventions
- 2000 Sportster 1200 primary/clutch mystery.
- 2001 dyna superglide inner primary leaking
- Clutch and Compensator compatible?
- Replacement Clutch Cable for '18 FLHC
- Transmission Mount not flush with frame
- Transmission mount to frame
- 1998 Harley custom sportster 1200c Anniversary
- fr33thomas
- Transmission off Frame mounts by 1/4"
- Primary oil change question
- Screamin' Eagle Manual Primary Chain Tension Adjuster
- Broken countershaft bearing removal
- Oil leak inner primary by Stator?
- Inner Primary Sealant
- 2005 FLHT Compinsator
- baker compensator
- SOMEBODY STOP ME!!! Or not... My dealer says don't do the 30T 70T pulley swap.
- clutch broken
- Clutch or Transmission
- 2016 Softail Deluxe Neutral issues
- 94 evo 5 speed tranny fluid choices
- Goodyear Falcon Belts?
- 2008 FXSTSSE2 new compensator required
- Changing clutch cable for ape bars
- Barnett clutch plate bolts backing out -- loctite?
- Need a little help
- Primary fluid for new barnett clutch
- Clutch cover question
- Softail Evo 6 Speed Conversion - Gear Assembly Only
- relocating foot controls
- What are 76 flh tranny output shaft oil leak upgrades?
- Trans Needle Bearing
- 75- SXT125-aermacchi-shifting trouble
- Clutch release push rod
- Cant find Neutral
- 2016 compensator questions.
- Clutch is sticky
- Seals for the Inner Primary Bolts
- Primary rotational parts (Best parts)
- Clutch/shift linkage problem
- A LOT of water in the primary
- Clutch basket nut
- oil from tranny toprimary
- Transmission
- M8 CVO Odd Downshifting
- 86 softail main gear nut
- Seal in fifth drive main shaft.
- 2019 HD Clutch Problems
- Transmission oil leak
- Primary cover interchangability
- 1966 FLH Electra Glide
- Transmission Oil transfer to Primary
- Troubled 00 5 speed
- Clutch squeal sound w/videos!
- where did I go wrong?
- Trap door bearings
- Stuck on primary....
- Need Some Help
- inner primary
- Shovelhead Trans sprocket
- Clutch Slipping or Trap Door Bearings
- 2001 Fat Boy always hard to shift from 1st to 2nd but this AM was nearly impossible
- Primary Chain Recommendations
- Armored Attitude Adjuster
- Ultima Six Speed Trans
- 6 speed questions...
- primary oil level
- Vibration 1600-2100
- BDL tranny problem
- 07 dyna trans output shaft
- which drive belt?
- Noise when clutch is engaged
- Is a new swingarm required for chain drive conversion?
- 1984 Harley Davidson Sportster
- rekluse clutch friction plates or stock?
- Clutch problem after VPC
- Hayden M6 BT-07
- Evil Engineering Clutch Springs
- Forwards to mids
- Clutch Release
- 2001 XL1200 downshifting issue plz help.
- 1967 sporster XLCH, 3rd gear jumping, only with no throttle, with throttle no problem
- Primary noise and burnt smell
- Push starting
- Neutral or NOT
- Good starter brand?
- Compensator Eliminator -Your experience with 32T or 30T sprockets
- Drive Belt
- Toe shift lever went limp - heel okay
- tranny swap
- Hydrolic clutch friction zone (solved!)
- burnout!
- Primary Leak
- broken clutch cable
- Stuck inner primary cover
- Which way to turn clutch adjustment screw?
- I can use this oil for primary case?
- Midcontrols convert
- Hydraulic clutch line heat concerns
- Red oil coming out of tranny shaft on clutch end?
- clutch issues
- No clutch lever tension. Cable good, moves ball and ramp
- starter gear and end play shovelhead
- 2009 Flhx transmission repair ?
- Clutch hub bearing
- 1975 ironhead sportster shifter playing
