- Red oil coming out of tranny shaft on clutch end?
- clutch issues
- No clutch lever tension. Cable good, moves ball and ramp
- starter gear and end play shovelhead
- 2009 Flhx transmission repair ?
- Clutch hub bearing
- 1975 ironhead sportster shifter playing
- Sportster Clonk and slack feel in driveline
- Sportster dies when put into gear
- torque specs
- Clutch Cable on Bagger
- shift problem
- Clutch problem brought to me
- homemade primary bearing tool
- What to update on 07 primary?
- Ugly rattling noise. Maybe primary?
- Evo 5spd Sticks in 1st gear when dead cold
- HD-34902-C - best tool?? (2008 and up touring) - primary bearing race removal/install
- EVO clutch adjustment gone wrong
- Clutch ID ?
- Good Primary Bearing?
- Replace hydraulic clutch with cable clutch
- primary "extra part?"
- Primary chain slack
- Alignment issues!?!?
- 30T pulley
- Using clutch tamer kit and bigfix???
- 1973 shovalhead clutch question
- please help
- 2003 screaming eagle cluch
- Lost.
- Chain conversion sprockets
- Need help please
- HELP 78 fxs shovelhead inner primary/clutch hub/front pulley/stator issue
- Gears in transmission
- Hydraulic clutch fitting leak
- 68 tooth rear drive pulley for dyna ?
- front transmission sprocket
- BDL Competitor clutch on Evo FLSTC
- Peculiar starting problems (transmission/clutch related, probably)
- hydraulic clutch
- Primary Cover Bolts
- 2001 Buell X1 Lightning that will not shift into 3rd, 4th, or 5th
- 88 electra glide classic trans upgrade
- 88 flhtc trans upgrade
- Primary belt replace
- Leak: Primary or transmission?
- Transmission noise
- Transmission Sprocket Nut Stuck
- Worn out inner race
- Stiff clutch
- 88 Sportster won't shift
- Final drive belt
- One Piece Inner Primary Bearing, or S&S race?
- Clutch Basket ID......
- Clutch adjuster rod overtightened
- Grinding on Hot Start
- 1996 HD EVO FXSTC Softail Belt Life??
- 1970 4 speed won't downshift
- Drive pulley bolts location
- Frozen Clutch
- Sportster clutch replacement: with a twist (HELP!)
- Different primary cover?
- Inner Primary Sealing Fasteners ???
- Chain Final Drive Pulley
- Clutch Recommendations
- clutch problem
- clutch adjustment
- dyna compensator question
- Heavy Clutch.
- Main Shaft Seal - 2016 FXDLS
- 194 FXSTS Outer Primary Cover
- Tuning lock up clutch
- Clutch slipping during shifting
- do I need a drive belt??
- Clutch Slippage 5-4
- Whining and clunking coming from primary !!
- Belt rubbing on clutch hub starter teeth
- Stop using synthetic oil in the primary
- Belt Deflection: Harley v Victory
- Not the usual Sportster clutch problem
- Cam and Oil Pump Upgrade for 2005 TC 103
- 08 6spd installed updated Main Drive Bearing and now have mainshaft end play?
- loose lever, shift rod
- Revtech 6 speed
- Too high RPM?
- Billet clutch parts?
- Clutch keeps burning out
- Primary oil
- Help ! After bleeding Clutch releases immediately
- 30/70, 30/68 30/66 pulley conversion on 2012 FXDB
- belt drive starter issue
- Can’t stop the grinding please help
- 2012 Dyna primary oil not draining .
- Compensator confusion. 2003 Softail
- 45 kicker problem
- Clutch help please!
- 5 speed or 6 speed
- 15 Fat Boy Lo transmission problem
- clutch cover gasket . 5 speed
- Downshifting (3-2-1 Metal Ping)
- trans wont shift to any higher gears
- Salvage / Rebuild 1968 FL.....
- Baker adjuster
- Clutch drag
- Final drive chain tension for 2013 FLS conversion
- M8 issue
- Drive Belt grear teeth marks
- Iron Horse Tranny
- Replacing clutch cable
- primary chattering noise
- Stuck inner primary case
- Clutch question
- Variable pressure plate
- Clicking from Secondary
- Screamin eagle six speed.
- 2003 Softail Deuce Shifter Pawl Adjustment
- Transmission Sprocket Installation Question
- noise from primary ONLY when in neutral
- Clutch/Transmission issue can't engage gears
- Primary oil capacity
- Tranny problem 2013 FXDB
- milwakee 8 clutch lever adjust
- Problem with primary drain bolt and helicoil
- 92 FXRS runs but will not move
- ATF Dextron for Chain Case Oil
- Clutch not disengaging when shifting into gear.
- Help for my 2014 Road King
- Stiff clutch
- Redline product question
- Rubber pieces of o-ring in primary
- Fatboy getting stuck in N when downshifting from 2nd to 1st
- Baker F6R
- compensating sprocket/shaft extension wear
- 2007 titan build
- 2017 street glide clutch issue
- Early 84 FXR Primary Isolation
- Replace the mainshaft
- Gears, rpms, and speed question
- Neutral Not Stopping The Power To The Wheel
- Baker OD6 with hydraulic clutch exhaust clearance
- shifter shaft bushings
- Primo Rivera pro clutch not enough
- Vented primary for a FXR3
- need help, how to reduce clutch pull
- 2012 Fat Bob Chirping noise inside Cam Cover??
- Deisel Harley. Which bikes had the same 5 speed internals as my 88flt?
- sportster 883 06 hard to shift in 3rd
- Loctited derby cover torx screw
- Comp Issues
- Inner Race Install & Puller Tool
- Baker 6od sprocket question
- 20mm belt life
- Should the primary level
- 85 fxrp tranny help
- Bike will not accelerate fully when you shift into gear
- Primary Heat
- Broken oil mount
- clutch cable recommendations
- Question on new clutch pack install
- Hard to shift into 2nd gear unless the bike's warmed up
- Primary noise or not?
- Clutch adjustment??
- only 1st and neutral no 2nd gear
- Inner primary removal
- stripped clutch hub studs
- primary locking tool
- possible bearing noise in primary, listen?
- Final Drive (rear belt) Sprocket Alignment
- Shifted into neutral on its own while on interstate
- 2001 Road Glide Sprocket
- chestnut
- Damper spring removal
- Belt tracking? (probably beat to death already)
- SE compensator noise
- SE Compensator Alignement with Clutch Basket
- Vulcanworks conversion compensation sprocket alignment issues
- Primary and transmission
- Screeching sound
- Clutch Lever Replacement
- Screaming eagle variable clutch plate
- Is there ANY yellow metal in modern HD 6 speed transmission?
- Energy One Clutch Kit 2014 Street Glide
- 5 Speed Clutch Ramp.....
- where
- 08 ultra classic downshifting problem
- Clutch kit for 113 twin cam
- Help
- Lost gears in Transmission
- sportster primary case
- Clutch cable semi sticks
- Timing Chain Tensioner Shoes?
- Chain drive conversion
- I just blew $200 on the wrong solution
- Switching to synthetic oil?
- Clutch Hub Nut Installation issue
- I ****ed up somewhere along the way
- Rear chain enclosure
- Belt size issues......
- Clutch Slippage
- Clutch went
- 2006 Deluxe Compensator Parts list
- Rear Pulley Bearing Repalcement
- Metal in transmission oil?
- Rear drive options for 2007 flhtcu
- 06 FXD TC88 to 103..help
- BDL extra plate kit
- ***fxdx wont start***
- 99 evo springer with primary leak
- '06 Softail - Shifting Issue
- New Clutch Reccomendations
- 04 xl 1200c shift through gears but wont move
- Crank Seal
- Alignment issues
- 96 upgrade to 193 or 110
- transmission swap
- Changing Rear Pulley On 07 Bagger Question
- Clutch Hub Mainshaft Nut
- Stripped shifter and shaft
- Gearing Higher
- Primary / Compensator / Clutch Wobble / HELP!
- possible compensator problem
- Trans
- Witch compensator to get?
- 1st Transmission Upgrade....
- Clutch cable leak....
- Transmission sounds like a fan belt
- Throw out bearing gone
- Trans Sprocket Locking Tool
- Chage both sprockets?
- Rear belt to chain conversion
- 2018 belt tension
- Buckhorns to Mini Apes - Clutch Length?
- FXSTC 20mm belt
- Difficult to engage clutch.
- 2014 street Bob. Rattling in gear box. Help ASAP.
- Clutch interlock switch
- Mystery part in primary..
- 4 speed to a 6 speed
- 2011 Softtail Heritage Classic
- 2005 Electra Glide Compensator noise
- Dry Clutch vs Wet Clutch
- Which 139 Tooth Belt to buy?
- 08 FXSTC 70t rear sprocket
- changing gearing on a 2016 Roadglide
- difficulties shifting out of first into second
