- How does a Power Commander Work?
- got P0154 but I have PCIII w/ O2 elims.
- How do I tune bike with module?
- Sudden problem with pinging/knocking.
- How do you bypass a bank angle sensor on a twin cam
- Twin tec TCFI2 install
- remapping vs sert for unkown brand mufflers
- SERT comparison
- Battery and Check engine light '05 RKC
- PCIII location
- Accessory fuse keeps blowing
- couple of electrical problems
- 74 XLH 1000 not starting, or firing
- Here we go again...Fuelpak, pcIII, SERT?
- 07 just died???
- weird starting prob
- Speedometer/Odometer No Worky-Almost There
- Battery Tender recomendations?
- F.I. tech question
- What is the SERT Version for 07's?
- Help!! Cant locate 3 pin connector for siren install on an 06 sporty.
- Need Help
- SERT Map for '06 Street Glide
- Heat Managment question
- Champion RN12YC to Bosch Platinum+4 Cross Reference??
- DFO/TFI Location on Ultra
- re-mapping for the short-term
- how to bypass passin lamp
- ThunderMax
- Engine light, PCIII equipped
- SERT DYNO File
- PCIII
- front stop switch keeps burning out
- pulled my hair out!!!
- WIRING FUEL GAUGE
- Relay sizes ?(breakers)
- O2 Eliminators
- Custom Map
- Alternator output for a bagger????
- baffles
- SERT or Dealer Download?
- Installing passing lamp ?
- PCIII or FUELPAK?
- Dyno results
- Expert Tuning advice please
- How to figure out if theres an electrical problem?
- Screamin' Eagle Stage I Kit or K&N RK-3909 Kit?
- Help tuning with the crane hi 4
- hard starting
- Rear Cylinder Misfiring/Not Firing??
- mileage drop from 39MPG to 34MPG
- DFO Settings Advice?
- 06 fatboy stalls/ coughs help
- Sert tuner in Mo.
- Question regarding remap for SE A/C on '05 TC88
- here is a good website, have a look?
- Confused!!
- Sportster 98 electrical problem
- How to fix a muffled Horn?????
- popping on throttle letoff
- timing marks for 61 pan
- SERT tuner in Texas
- Dyna Ignition Module on EVO
- SERT Tuning/Loading question
- Good Dyno guy w/SERT exp. in St. Louis area?
- NEED SERT MAP!!!!!
- Here's a little SERT/ECM info for ya
- Injector problem?
- SERT models
- No Blinkie Blinkie
- PC III USB- Understanding the Numbers
- H-D pager II, no RCS signal being received
- PCIII
- PCIII and replace just the air cleaner
- do the factory screaming eagles come with a sert
- Cobra Fi2000R
- New PCIII Installed - Help?
- 2007 fuelpak?
- Magneti Marelli ECM Tuning ??
- spark plug wire resistance?
- HD SERT Question
- About misfire, bad ignition module.
- Vance & Hines MAP
- Aussie SERT's put on hold
- Fuel pressure test
- SERT questions
- Removing turn signals
- 99 Roadking Classic FI issue
- 2003 Night Train idle problem when coming to a stop
- Sert Details Question
- Started, backfired, wont fire.eas?
- Turn Signal malfunction
- SERT Data Mode
- EFI tuning for new bike
- 32107-01E On a 2007 Glide Question
- Start and die problem
- Highway lite problem
- SERT - V&H Ovals - map help
- Washed Bike, Now Have Starter Issue
- Quick EFI Question
- EFI Idle problems
- Great Tuner Overview Article
- 07 SERT owners question please.
- Headlamp Aiming
- Ignition Timing/Plug Heat Range
- Closed Loop Bias Opinions
- 93 Sportster
- tried a different PCIII map....
- I need some help please!
- PCIII
- 06 FLHRI idle ?
- electrical problem
- mufflers
- 06 dyna running hot
- Just installed a SERT on my '07 Heritage...
- odessey batteries
- Am I about to be screwed by the MoCo?
- air-fuel mixture
- Cobra® FI2000R Tripot Plug In Fuel Processor, 1995-2006
- HELP!!! Ignition Woes
- Electrical problem
- '04 883 Custom performance question
- SERT Down Load Original Program ?
- Finally someone listened
- Fuel guage
- crank sensor. Crank position sensor. I opened the cover and this is what I have
- New SERT install
- Screamin' Eagle Pro EFI Race Fueler
- TSM/TSSM error code 31
- Here goes nothing
- XM and Sirius radio questions
- Electrical woes...
- Looking for Dyna 2000i interface cable
- Is this the dreaded 8 degree injector problem?
- Recommended PCIII USB Map
- PCIII Accelerator Pump
- 32107-01F SERT Questions
- Power Commander or SERT?
- Who'd of thought.....
- Lost in tuner land
- ECM stupidy question.....
- ??? for SH Bob
- Starting idling problems...
- another electrical gremlin
- Dual Points Installation
- Spark GAP
- Which Ignition Tuner for 00 Carbed Dyna?
- Sert Question?
- SERT Tuning
- Hooker Tuned Flow exhaust ?
- cam pick up sensor...where?
- Touring Vance and Hines Fuel Pack
- Exhaust Y-pipe crack/ Glowing Red hot!
- 06 Roadglide no spedo, tach,turn signals HELP!
- RJ's New Hampshire
- EFI ON A CUSTOM TANK
- couple of SERT questions
- downloads
- are there round keyed ing. for '94 fl models
- RPM wire????
- Turn signal problem
- Security system question
- FXR No spark
- Help, broken throttle cable!
- 07 Road Glide Fresh Off The Dyno!!!!!
- starter
- brake light not operating
- Stage one download?
- Oil gauge is whacko
- Loaded Map #228
- Help install Mini Tach on 97 FLSTF
- Intermittent firing on one cylinder
- What is plug "arcing" ? What causes it?
- would not start
- Starter Relay - radio problem fixed
- Dyno Run 510g cams, 95"
- Speedomter not working
- Hyper flash with Radiantz LED turn signals
- PCIII on an 06 Dyna - Any Tips?
- terrycomp and the 07's
- Dyno Tuning
- Ness Big Shot Question
- DFO issues
- It happened again! where to check now?
- Load Balancers?
- Help me solve this electrical problem
- Which Race fueler is this one, its Chrome??
- Power commander
- passing lamp's
- What is SERT / Map / PCM III
- Cold engine/warm ambient temp
- Kill switch won't kill the engine...
- idle question
- Fi2000, TFI and Fuelpak, Same thing???
- starter not engaging belt drive
- 06 Deuce problem
- 1970 Shovel draining battery
- Taillight/License bracket for 2006+ Bobtail Fender
- Code U1016
- Living with the Big Sucker II
- NEED DIAGRAM OF WIRING
- Sportster turn signal shuts off too early! Can it be adjusted?
- PC III usb Placement for a 06 softail
- 1995 Fatboy
- 93 Hertage Softail starting problems
- PC III questions
- turn signal does not blink
- Race Tuner
- Air temp sensor
- HD download vs PCIII usb
- Better Fuel Mileage?
- Recommended SERT map 2006 Deuce ?
- What Map
- what to do when removing tachometer?
- S&S IST Ignition
- Lose all electrical power
- Warning Light
- Fuel Pak .... Yea I know ....
- SERT Data Mode
- SERT instruction help
- Shutting your bike down.
- Packard Connectors
- race download / setup
- 98 road king gas mileage
- pcIII 95" download where do I start?
- PC III USB Map For 1550?
- Headlight bulb top bottom?
- race download?
- Cruise Control
- What did your dyno work cost?
- 1995 Fatboy
- Hd alarm is it worth the cost?
- 1987 FXR Ignition Problem????
- International vs. Domestic Lighting?
- Fuel Pak on my new 06 Fatboy
- reading the sparkplug
- Easy upgrade
- 73 Ironhead Starter Problems
- Newbie Post- SE Slip-On & Mapping Question
- 2007 PCIII
- Spedometer Odometer potential problem
- 2nd regulator bad!!!whats up???
- SERT map files for 2007
- PISSED !
- Dyna FXD not staying charged please help
- Pinging under load?
- Fuel Management
- Engine check lamp
