- Bleeding off fuel pressure?
- left turn flashes fast.
- Mytune
- 1990 Fatboy starter problem
- Fatboy just died?
- Ignition module test
- Question concerning batteries
- 2004 FLHRSI EFI Tuning
- Coils
- PC3- what is firmware?
- Thoughts about the Fuelpak????
- 95 roadking charging system
- Iron 1200 question
- Bad speed sensor....AGAIN!!!
- What Tuner or Fueler do you use???
- Comparing SERT to SEST w/smart tuner
- Loose fuel injector plugs
- Alarm Security Siren
- Stator, Rotor
- Map for FLSTSE2 ???
- 2009 sportster iron blowing fuses
- Question about Warmup Enrichment Table
- Ground wire was loose.
- Fat bob deccel pop
- 8 year old electrical problem solved
- Somebody please help!
- Carbureted Fat Boy Engine Light comes on radomly
- 08 XL1200C electrical problem
- Vance and Hines Fuel pak or Power Commander V
- Stator Life Expectancy Question
- 01 Road King poor idle
- sluggish deluxe
- Current version of SEST software
- EITMS and SERT question...
- dies when clutch released
- No Ignition Spark at front Cylinder
- what am i missing???
- dealer wouldnt change injectors
- Check engine light/ Battery light
- Want to lower IDLE RPM on 08 FXSTC
- 95 fatboy w/ 110' Revtech 45 mikuni, running on 1 cylinder
- pipe question
- Strange Idle
- Electrical issue, need advice.
- 99 Road King Carbed no crank!
- 01 fatboy intermittent miss firer and rough running
- SERT to TTS upgrade question...
- Starter kicking in as soon as you turn ign on????
- Bike shuts off under hard accelleration!!!
- 2000 road king fuel pump noise
- How precise are the V&H Fuel Pak Settings ??
- Interesting TSM/TSSM Question - Custom use on other vehicles...
- Battery has no charge
- Procharger on my 09 Street Glide
- Accel SLM?
- The Little Red Key Stays On
- ECM TSM/TSSM and SPEEDO lessens learned
- Race Tuner
- Where to get mine tuned...
- blinkers on my 86 softail custom
- 07 Road Glide
- slipon muffler help!
- Nightster Tune
- SERT map help
- TTS mastertune help file error
- Tuning Required for 2005 Fat Boy w/ Big Sucker and Big Radius?
- Does this make Sense?
- Life span of a fuel pump?
- After charging battery, odometer reads wrong
- O2 Eliminators with HD Download?
- 1999 flhrci need help!!!!!
- 2004 FXDL/I stator question
- 2006 Ultra Classic - I'm a new HD owner
- Please somebody help
- 09 Streetbob wiring harness
- o2 sensor upgrade
- TMax Smartlink troubles
- Bike wont start after a while
- AF Ratio adjust vs parade download
- 07 FLHTCU Stock Map - TTS
- Fuel Controller - before or after break-in?
- runnin lean w/ PCIII
- Super Tuner Buy Question
- Brand New ECM
- Won't Start
- Problem Today
- blowing 40 amp maxi fuse
- Can we trick the Bank Angle Sensor
- Speedometer and Tachometer just quit working
- Using 04 - 06 Speedo in an 2003
- Fuse on the battery tender connector?
- 04 fatboy fuel problem
- How to check/clear codes '02 Deuce
- Have to start twice
- A "Band-Aid"
- headlight dims with blinker on
- SEST Map Timing Adjustment
- Hogtunes on CVO Ultra with /tourpack amp?
- Battery volyage went 5.5vdc
- Rapid LED signal flshing- Help!
- ignition switch problems
- need help? efi to carb list
- Check engine and security light with tmax
- Stator bad? 1994 FLHTP
- 1993 Softail won't start, need help!
- Key not working
- The RK Died Today
- Jiffy Stand Interlock Switch
- "94 Heritage Charging Problem
- Weird PC3 USB problem
- Interesting Engine Temp Sensor Behavior
- Won't start after removing switch housing
- 09' XL883C Sportster Tach install Help
- tmax
- 07 sportster code P0107
- ironhead coil keeps shorting
- Dual Bulb Headlight?
- where to tune for roll on ping?
- Ignition, electrcial popping noise/crackle.
- looking for help!
- download or not???
- Will low (bad) Battery effect EFI?? 03 Roadking
- Engine Light
- Arcing spark when wet
- PCIII took a dump
- 06 Softail Electrical Diagnostic Manual
- 06 electric glide
- fuelpak problem
- TMAT Communication Problems....
- 09 stock dyna pinging
- Need spark problem help please!!!
- Won't Start
- Another Tuning Question
- Question about SE Pro 50MM Throttle Body
- Need a little troubleshooting help..
- Speedo/Odometer
- Auxiliary lights on Fatboy...
- Tune Question??
- Erratic Idle, anything else I can check?
- Need Help
- B1145(HFSM) Security Antenna Open
- I dont know sh**
- 1997 roadking missfire
- Not Starting
- Will an ied give a p131 and p151 DTC code?
- Starting issues when attempting restart...
- Trouble code 06 Fxst
- Best place to buy Power Commander III?
- Went to bike show and put bike on the dyno
- Automatic Signal Cancel and Speedo problem
- Screamin Eagle Race Tuner for a 88 Twin Cam Help Needed
- 95 Electra Glide Overcharging
- Stage 1 Flash Question
- Replacing left side heated grip
- stall at stop
- 99 Night Train - Brake light not working
- here a tuner, there a tuner, everywhere a tuner... ole McTuner....
- 1992 Softail wiring question
- 1975 FL wiring
- 92 electra glide left me stranded?
- Error Codes? Something to be Concerned with?
- Adjusting idle mixture MM
- '06 1450cc FI - cough/stall when warming up then OK
- Fayetteville NC, PCIII tuning
- my head light and passing lights
- Heat Demons Grip on a hd muscle
- Bike missfire shut down
- Volt Meter on Bike
- Bike Shut Down, Kind Of...Safe Mode?
- Can someone explain this?
- Power Commander Problems
- Help!Anyone ever had this problem before?
- Rk engine missing
- Fuel Map Failing to Load
- in need of 2010 bagger for TTS tuning
- intermittent stall
- New notebook and SERT?
- SERT And pics of plugs
- Disconnecting battery and alarm
- Will not start without security code
- 89 FLHTC Won't Start
- 2006 flhti backfires
- 04 Fat Boy - diagnosing 'bus er' - Help!
- TPS Setting on 01 Ultra Classic
- electrical problem
- 07 street glide stalls...
- Wrong Colors??
- tuner & map?
- 1991 fatboy runs fine then bogs/sputters after 20miles
- horn,turnsignals and brake lights not working
- Bad Regulator??
- anyone had trouble with system relay?
- thundermax w autotune
- 05 harley chopper starting problems
- How can I tell which tuner i have?
- 02 FLHTC - Weird odometer display and electrical burning smell
- CEL steady after start for 5-6 seconds
- Dyno again because of pinging?
- New firmware in the Race Tuner
- Bad decell popping
- Outstanding Service
- Do I have to get a...
- Fuel injector cleaner??
- EFI Help Needed/Poor Running
- it just quit
- Loss of throttle on 08 Street glide (1200 rpm max) Throttle grip clicks in forward mo
- Need Help- Sert
- Question about RideMax installation
- Recommended tuner for an '08 FLHR?
- To Hot?
- Dead Wide Glide
- Factory Alarm Problem
- Air cleaner shooting spurts of air
- Question About Popping and SE Pro Tuner
- thundermax and timing
- Headlight not working?
- for the tech folks.....fuel or electrical?
- Broken Stud on Starter
- New Scooter, maiden voyage - Dead battery
- Installed new Rear Turn Signal assembly and in Trouble -1988 FXSTS
- Need help please.
- Question on Super Tuner and Stage 1 Down Load
- rear right directional problem
- tmax midwest tuners
- Blinker nightmare...
- need power commander map
- Heritage stalled
- bike shut off in rain
- 07 FLSTC Ignition switch
- 2001 fat boy
- check engine light
- 08 ultra ?
- SE airfilter vs K&N airfilter
- electronic throttle
- Rev Xtend on the PC V
- 02 duece p0374ckp code
- SERT Question
- Electrical issue
- TBW wiring?
- Tuning out heat and decel pop with TTS
- FLH headlamp electrical and radio display problem
- Tmax map 401
- Tmax problem
- PCV and timing tables
- 1986 harley sportster no start
- SERT - What to adjust for decel jerk
- low fuel lite
- brake light stays on
- Code U1097
- Ground Strap Location
