View Full Version : Electrical/Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Garage Door Opener
  2. Electrical Issue
  3. most likely cause for no spark 2004 Deuce w/ Carb.
  4. left control adjustment
  5. I need a PC3 map for my 113 build, anyone?
  6. tuners???? zippers,daytona twintec
  7. I need to richen my bike up
  8. Neutral Light staying on
  9. 2008 Ultra turn signs not working
  10. Spark Plugs
  11. Starter Opinions
  12. spark plug wires
  13. Wont Start
  14. DIY Tuning
  15. 2 different FI systems used by Harley?
  16. speedo/tach combo backlight help...
  17. Tmax Timing
  18. BigD
  19. Having trouble updating firmware
  20. 05 ultra relays
  21. What was last year for a carb on Ultra Classic?
  22. Turn Signals
  23. Air intake Solenoid Eliminator
  24. Ping in Neutral?
  25. battery probs
  26. Newb Here: 1998 Softtail Custom Electrical/Electronic Issue
  27. Strange - Fuel Guage, Fuel Light Issue
  28. Stereo question
  29. What about Vtune, glens
  30. Starter keeps running, '82 FXR Shovel
  31. Starter MAP file?
  32. SE Phat 10mm plug wires question
  33. dual map
  34. Tuning with PCIII
  35. SERT and low idle
  36. Major issue, please help EFI
  37. Help Troubleshooting Electrical Problem Please?
  38. 2000-FLSTC w/ carb., Where to pull temporary TACH signal...??
  39. Any Reason to Use XIEDs With Thundermax?
  40. EFI set up help needed with SE 113" kit
  41. springer classic pipes on deluxe help
  42. break light...
  43. new pipes really require a power commander?
  44. New cams, map needed
  45. Different FI systems usd on harleys?
  46. Harmon Kardon Problem
  47. Dual lights for brake/running
  48. rookie needs help...engine not cranking
  49. Fire through throttle body
  50. Thundermax Starting Issues
  51. Super tuner web update not working?
  52. TwinScan II
  53. Dyna 2ki Ignition
  54. Blinkers question wiring
  55. TTS question for Glens
  56. FuelMoto, Jamie and the new PC-V
  57. Pcv
  58. Need Help
  59. TTS usb cable
  60. IPOD Wiring
  61. 08 Throttle by Wire Help!!
  62. PCIII usb code 39
  63. xieds
  64. ECM Update for True Duals
  65. Kuryakyn Light - Need help finding "Run" wire
  66. thundermax issue for newbie
  67. Help--SEST or PCIII
  68. DTC P0261 on 06 FLHX
  69. Dyno tune 09 touring with stock pipes
  70. Dyno in 4th or 5th gear
  71. 2001 FXDL L/H and R/H switch harness's
  72. ecm pigtail pins ?
  73. Why adding harware over software solution?
  74. Hooking up my SERT
  75. Pc v
  76. SE Race Tuner Info
  77. Sert
  78. V-tune question
  79. circuit breakers
  80. SE Super Tuner Data Log
  81. No brake light...please help!
  82. horn inputs - polarity?
  83. EFI to carb swap?
  84. TTS starter Map
  85. Popping on Decceleration
  86. Cost of Stage 1 Reflash ECM
  87. 12V or magneto?
  88. VDC Batteryminder
  89. RPM Rev Limiter...??
  90. New power commander 5
  91. The 2009 RK fuel pump doesn't turn on
  92. Installed HD HID headlight kit-it works-won't start
  93. brake in map
  94. SE ignition module
  95. 98 EVO Jackshaft Problem
  96. Battery losing juice
  97. Spark plug help?
  98. 05 Classic NO FIRE ??
  99. SE Race Tuner
  100. New Super Tuner and 09 Ultra
  101. CB Radio Install questions
  102. Tmax and Auto Tune.
  103. 09 FLHX throttle failier
  104. Battery charger light won't stay red
  105. GPS instal...
  106. Which EFI do I have? Idle question?
  107. LC1 wideband ??
  108. This Is a I need thread
  109. ThunderMax has a software upgrade 2008-1-7
  110. Electical issues H/L S/L T/L ABS Passing/L
  111. 1985 FLHT Spark Problem
  112. PCIII error code 39 coming up! Need advise
  113. PCIII vs. SE Race Tuner
  114. High Air Flow and fuel delivery question?
  115. EFI Tuning / Reversion / Camshaft Dilution?
  116. tts step by step
  117. TTS Tuner: available in Canada ?
  118. Option,s for 2005 efi fuel upgrade
  119. 04 softail low fuel light.
  120. TTS Mastertune Information
  121. TTS Map for Stock 2009
  122. PC3 maps other than Dynojet's?
  123. 97 Springer Electrical ?
  124. crane fireball ignition
  125. pc111usb ignition timing map
  126. Injector ?
  127. Electrical question on a 92 Ultra Classic
  128. Fuel Moto PCIII maps
  129. 80 inch Shovel, stage 1? also, Prog. Ignition
  130. LC-1 WBO2 sensor
  131. Lizard lights control
  132. Difference in Pro Super Tuner Part No's
  133. Symptoms of a bad starter
  134. Dyna Speedometer
  135. Fuel Gauge trouble
  136. Need some help tuning...or do I have a misfire??
  137. Need fitment help!!
  138. O2 sensor part number ?
  139. Battery Question
  140. Turn key to ignition and NOTHIN"!!!
  141. Power commander V Idle adjust?
  142. Newest SERT
  143. Tuners and Builders - A question on Dyno Charts
  144. Headlight Issue After Washing Bike
  145. Who's using a HQ Pro tuner
  146. Which fuel tuner??
  147. turn signal question
  148. Springer Won't Start, Just Clicks--Help!
  149. turn signal stoped working
  150. Power Commander Quick Shifter
  151. Ignition relocation question need info
  152. Braided cables
  153. Dynojet PC-V or TTS MaterTune
  154. American iron letters ?? tune not needed?
  155. no start
  156. NGK Iridium plugs and Ion Sensing system
  157. Need Help tuning a PCIII on a 2007 FLHTC
  158. SEST v1 update
  159. 2000 Road King Classic need some advice
  160. a good multimeter?
  161. Fatboy06 PC111 Map
  162. Super Sert Tuners
  163. Rev-Tech Stealth DFO v Cobra F12000
  164. Using Power Commander is Rear Cylinder #1 or #2 for fuel trim?
  165. Flashing Lights?
  166. Reno H D
  167. Intermittent problem
  168. Braided Fuel Fupply Line.
  169. Pro tuner questions
  170. No electrics when ignition switch is turned to "ignition" position.
  171. TTS Info
  172. inop turn signals
  173. TTS Update Sticky?
  174. DynaJet's new PC V?
  175. Tmax map for 103
  176. thundermax base map
  177. TTS Master Tune question
  178. 2005 Ultra audio schematic needed
  179. 2003 Fat Boy EFI Running Issues
  180. HQ 113 and Tmax
  181. Error Code 31
  182. When do you change injectors
  183. HD layback license turn signal relocation kit
  184. 05 dyna power commander
  185. TTS MasterTune speedometer adjustment
  186. 02 Softtail
  187. PCIII or SEST?
  188. VTuning at various temps???
  189. 2000 Road King EFI dies after 30 sec-no spark
  190. Help the dummy with SERT.
  191. Blinker system
  192. Radio problem on '87 FLHTC
  193. Need help understanding the cause of knock
  194. Data Link Connector
  195. Horn Fuse
  196. Blinker Problem
  197. HDs New Super Tuner
  198. No Spark! Sort of? 1966 Electraglide
  199. Which tuner??????
  200. TTS Warm-Up Enrichment
  201. TTS Warm-Up Enrichment
  202. Harley Davidson MP-3 Player
  203. anyone with a wideband AFR guage?
  204. Looking for a map??
  205. Mapping Differences?
  206. Advance curve question
  207. Pc v
  208. do I need a Fuel Management Controller?
  209. Bootloader Problems?
  210. Tuning option
  211. Bad Gas or Did Tune Change
  212. Mounting Circuit Breakers
  213. Anyone help me?
  214. Super Tuner Version Question 09 Ultra
  215. New wire old plug
  216. Well I searched to no avail....
  217. Ignition Switch Problems???
  218. Best place to buy Thundermax w/ Auto Tune?
  219. Spark Plug Gap setting 03 ElectraGile
  220. FI Remapping for 2009 Ultra
  221. Using TSII/Wego w/TTS Mastertune?
  222. Hesitation when accelerating
  223. 08 roadster 1200 idles high
  224. Need a good reliable PCIII Dyno technician - South Florida
  225. ied & xied's
  226. TTS mastertune speedo calibration for 09 ultra
  227. 2009 PC-V verses the new ThunderMax
  228. Single/Dual fire ignition
  229. TTS w/Stage 2 Dealer Flash?
  230. HD key # - any way to find this???
  231. 2007 96ci SERT MAP
  232. Which Alarm to choose ... HD or Aftermarket???
  233. Used PCIII USB ???
  234. Engine light won't go off.
  235. TTS USB Cable Kit?
  236. Are X14iED's the right solution? Advice please
  237. Poor fuel mileage
  238. Possible sensor problem
  239. Light Help
  240. Question about stage 1
  241. Brake Light stay On and Cruise Control does not work
  242. More tach instrucions...Help
  243. Tts?
  244. HD Garage Door Opener
  245. Will pay $100 for step-by-step TTST telephone help
  246. ECM 2007 dyna....fitting a harley mini tacho dont have instructions with it
  247. Gosh Dern Iron Head "
  248. 09 Power Commander/?
  249. Direct Link by Technoresearch released for 2009 bikes
  250. Rear turn signal brake controllers.
